Breaking question.
Discussion in 'Gen 3 Prius Technical Discussion' started by priusfella, Apr 8, 2012.
  1. priusfella
    priusfella New Member
    Surfside Beach, TX
    I have had my 2010 Prius for 6 months and have noticed that when I'm breaking over an uneven surface my car seems to speed up. It's a very uncomfortable feeling. Is this a characteristic of regen breaking or is there something wrong?
  2. mdsinger2
    mdsinger2 DynamicBrake
    23
    Virginia
    Sounds alot like you're not actually speeding up. You may be losing braking power due to the ABS doing its job. It is slightly removing pressure from the brakes to keep the wheels from sliding.
    52,923
    this is a feature that comes at no extra charge, enjoy! :)
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I am going to discuss braking, if you really meant breaking, I am at a loss.
    When you stop the car normally you use regenerative braking, which uses Motor Generator 2 (connected to just the front tires) to make electricity and store it in the HV Battery.
    When you have an uneven surface, this can apply stresses to the drivetrain and also may let the rear of the car get loose, so when you hit bumps while braking, the ECUs switch to Friction braking (Disc Brakes) which uses all 4 wheels to slow the car but has a slightly different 'feel' than Regen.
    The short gap and the different feel can cause you to think you are accelerating. This is a kinetic illusion, like an optical illusion can fool the eye.
    When the Gen3 first came out, the gap between Regenerative and Friction brakes was longer, if you have an early 2010, make sure the recall was performed.
  5. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    This is old news. The car is not really speeding up. There IS a decrease in braking deceleration when the car switches from regenerative braking to mechanical braking. Your brain interprets this as acceleration. There was a recall that changed the car's programming to minimize this. I suggest you check with the dealer if the recall was done.
  6. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    This issue has received much discussion in various threads on this cite. Simply stated, light braking activates the energy regeneration system, with more aggressive braking activating the ABS system. If you start braking and then drive over a bumpy surface, both of these systems are momentarily inactivated, giving the feeling of acceleration. In reality, friction braking is unaffected, although continued stopping at the same rate will require additional braking pressure.
  7. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    (if it seems we are ganging up on you, I bet all of us read the question and composed answers thinking ours would be the only answer. At least we don't disagree, it would be more confusing if we gave different stories)
  8. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Listen to JimboP..... He has nailed it on the head.
    Just depress the Brake Pedal harder. Find some crappy rough surface street that is not well traveled. Drive up and down the street at varying speeds, then Brake, get the feel for it, how to manage it, and then how to master it, lastly how to ignore it.!
  9. mad-dog-one
    1,181
    421
    Whereabouts Unknown
    +1
    We're a helpful group :)
  10. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    The Runaway Prius returns! :car:
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,082
    Northern Michigan
    So this isn't a breaking question about braking, but instead an old question about braking.
    :D
    For the OP: ABS brakes do this. They allow some wheel rotation to maintain directional control. Given the two-wheel nature of regenerative braking, the Prius is more likely to go into ABS over bumps than an ordinary car. The resultant short reduction in braking effort feels like acceleration, but it isn't. It is actually a reduction of acceleration, or what we engineers call "jerk" - you feel the car jerk forward.
    Tom
