Bridgestone Ecopia 422 Tire Question
Discussion in 'Newbie Forum' started by Laurel007, Sep 14, 2013.
  1. Laurel007
    Laurel007 Junior Member
    Fairfax, VA
    I put the Ecopia 422 tires on my 2010 Prius two weeks ago, and they seem very noisy at 50 mph and above. I am returning to the store where I purchased them tomorrow (TiresPlus) to see if the noise is caused by the tires or something else. Has anyone else experienced excessive road noise with the Ecopia 422 tires?
    Follow up: The mechanic said that the Ecopia 422 tires will not provide as soft a ride as the OEM Yokohama Avid S33D(?) tires they replaced. And that the tire noise should improve after about the first 1,000 miles. Should I see if the noise dissipates or should I replace these tires with the Michelin Energy Saver A/S tires? Comfort, low noise, LRR, and high MPG are priority considerations. Will the Michelin Energy Saver A/S tires be similar to the Ecopias? I understand that they are a softer tire than the Ecopias. Thanks for any advice /sharing your experience with one or both tires.
    CLARIFICATION: I am happy with the MPG and ride comfort - but can't stand the NOISE these tires make above 50 mph. So, no one else has experienced this issue?
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Definitely not the experience with my 05. The Ecopias are much quieter than the Goodyear Comfortreads that were on it before. After 20K miles, they are still quiet.
  3. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    i have ecopia 20 on my 2013(OEM) and they seem fairly quiet.
  4. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    My new Ecopias are quiet.
  5. jadziasman
    1,355
    488
    District 6
    So OP, did you exchange the Ecopias for another brand? You must be one of the few with noisy ones.
  6. Laurel007
    Fairfax, VA
    I haven't decided if I am going to exchange the Ecopias for the Michelin Energy Saver A/S tires. The Ecopias weren't noisy when they were installed, but became noisy after a couple of weeks. The mechanic who checked the tires this weekend said that he could find nothing physically wrong with the tires, but agreed that they are noisy. I'll make a decision about whether to exchange them in a couple of weeks.
  7. bisco
    52,863
    i would get the michelin's, best all around tyre.
    Laurel007 and sdtundra like this.
  8. Laurel007
    Fairfax, VA
    Update on my earlier post: I am going to trade the Bridgestone Ecopia 422 tires for the Michelin Energy Saver A/S tires. The Ecopias are way too noisy, even after 1,000 miles of driving on them. I'm also considering the Michelin Defender and Yokohama Avid Ascend tires. I'll decide in the next day or two. Like other Prius owners I've read posts from on this forum...I would appreciate hearing others' impressions of the Yokohama Avid Ascend and Michelin Defender tires. I would give up a few MPG to have a quieter, comfortable ride. But MPG is extremely important, too, since I drive about 50 miles round trip each day. Thanks!
