Bridgestone Ecopia EP20 or EP422 plus for 2010 Prius?
Discussion in 'Gen 3 Prius Main Forum' started by wliangy, Jul 25, 2017.
  1. wliangy
    wliangy Junior Member
    33
    ??? o_O :)
  2. Witness
    Witness Active Member
    115
    117
    San Francisco Bay Area
    Came here looking for reviews, because I'm about to pick them up at Costco.
    It's $70 off and $0.01 installation, so it's a savings of $130.
    RMB likes this.
  3. Gen3PP
    Gen3PP New Member
    29
    Maryland
    I replaced my EP20s with EP422s on my 2010. With my 2010 with EP20s, I had a flat and it turned out the sidewall was only a 4th the thickness of the EP422s. I would say the thickness is on par with 2x of an inner tube. This equates to have greater rotating mass for the EP422s. After I changed to the EP422s, I had a 5mpg mileage drop. The EP422 which are almost worn out have never given the mpgs of the EP20s. EP422 are lasting longer (65k vs 90k).
    There may be an safety issue with the thinner side wall??? but then there is the mileage.
  4. Mendel Leisk
    42,368
    I liked the EP20's. (y)
  5. BurkPhoto@aol.com
    56
    High Point, North Carolina
    I use the Ecopia 422+ on my 2010. I have 17" wheels. They ride better, and I get a couple more MPG, than the Nexen tires the last owner had on it.
    Bay Stater likes this.
  6. Mendel Leisk
    42,368
    If you're shopping 17's it a moot point: the EP20 only come in 195/65R15
  7. GreenApp
    GreenApp Junior Member
    43
    I don't know why, but when I swapped out my ecopia summer tires (discontinued) to the all-weather ones, I dropped like 7 mpg. Always on the lookout for the best tires.
