Bridgestone Ecopia EP422 Plus as replacement for OEM tires?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SuperGLS, Oct 1, 2016.
  1. SuperGLS
    SuperGLS Member
    200
    52
    Washington DC
    My 2013 came with some Yokohama tires when I got it. They've been good as far as I can tell (I've only had one tank of gas that I made fewer than 50mpg and average more than that.) They seem to be fine for driving. At 45K miles though they are done.
    Are these Bridgestone Escopia tires worthwhile? Will they be pretty similar to the OEM tires? I know they are the same size. Here are the specs at Costco. I care most about maintaining the good fuel mileage and getting at least another 45K miles out of them. The one thing that concerns me is that they don't say anywhere that they are low rolling resistance tires.
    Bridgestone - Ecopia EP422 PLUS
    Item #: 990416
    Manufacturer Part #: 006036
    Tire Size: 195/65R15 91H
    Season: All-Season
    Warranty: Platinum Pact Limited Warranty
    Sidewall: Black Letter
    Run Flat: N
    Any feedback would be great. Or any feedback about buying tires from Costco in general.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Last set I bought were from Costco. Bridgestone Turanza Serenity. Bought them when Costco was running a sale on Bridgestones for $360 out the door with 80000 mile warranty:). I have had them on for 20 k miles now and are nice and quiet and have been getting around 50 mpg.
    There are a lot of factors with improving mpg. I leave mine at 35 psi , so there is more available mph increase.
    My main factors were longevity, quietness, then mpg. The Serenity tire was a good choice for those order of options. The EP422 is a good choice though.
    Costco gives the free rotation and balancing every 5 k miles. I will be doing that this morning along with getting some brownie points from the wife by saving her a trip to Costco;).
    IMO Costco and the EP422 would be a good choice.
  3. Mendel Leisk
    42,361
    There's two variants of the Ecopia EP422 plus, in 195/45R15: 4-Rib and 5-Rib. One's manufactured in the 'States, one in Mexico. There's also two different wear indexes. And different max sidewall pressures. In 215/45R17 there are also some variations: the wear index, country of origin.There's no mention of different rib number, but tread width is different, not sure what that means.
    TireRack screen grab:
    My 2 cents: Bridgestone is playing silly beggars with this tire. You can see the specific variations by going to tirerack, and selecting the two variations for a comparison.
    There was someone here who even managed to be give two of one variant, two of the other. And the tire shop first dug in their heels, didn't see the problem.
    Consider also the Bridgestone Ecopia EP20. It only comes in 195/65R15, so any published pictures reflect the actual tread pattern. I've bought these a couple of times for another car. My take: they're very good for LRR, decent traction, stable/planted feel. They are not that long lasting, maybe about the same as your Yoko's. They're a menace in any kind of snow once worn, and also get a bit noisy as they wear.
    But all considered I'd buy them again.
    Costco is good for price, and when there's mail-in discounts, Costco takes that off at the till. This means reduced sales tax, and no hassle/delay. If you don't want green valve caps, or in any event, take the caps off your current tires before going in. Also, up to you, but I would decline the "TPMS refurb kit" or whatever they're pushing. Also, and they're pretty good about this, but verify: they should be using hidden weights, nothing clipped on the outer rim. And assume they will only put in the spec'd air pressure (well nitrogen, lol), plan accordingly if you want more. There is no harm in adding regular gas station air.
  4. SuperGLS
    SuperGLS Member
    200
    52
    Washington DC
    Thanks for the thoughts guys. Anyone else want to share?
  5. JC91006
    16,937
    8,647
    When buying items in Costco, we always get taxed for the full amount and then discount is taken. There's no savings in tax
  6. Mendel Leisk
    42,361
    Just liking that to say interesting to know. Maybe always the case in the 'States?
  7. SuperGLS
    SuperGLS Member
    200
    52
    Washington DC
    As a follow up I got the 422 Plus tires and after 178 miles everything seems fine. Costco is using gray valve stem caps now and not green. Or at least they put gray ones on mine.
    One question though, this is the first time in my life getting new tires when I've had a garage and the tires are making the garage smell really strange. It's not the normal new rubber smell, it seems to be chemical in nature. Is this the nitrogen in the tires?
  8. Mendel Leisk
    42,361
    More likely the tires? No smell to nitrogen, it's 4/5 of atmosphere btw. I've noticed slight "new tire" smell,but barely noticeable. Mainly when you walk into the tire shop, where they're surrounded by tires, lol.
    The only time I've noticed objectionable off-gassing is with obscure made-in-East rubber items, some wheel chocks for one. Clears up in a while.
    But strange to me, to have strong smell from new tires. We're garage stored too, btw.
