Bridgestone ECOPIA EP422 PLUS: Very Squirrely
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by tomfcb, Apr 19, 2019.
  1. tomfcb
    tomfcb Junior Member
    16
    Scottsdale, AZ
    These tires replaced Michelin Defenders. They are much smoother/quieter. MPG seems about the same, but it's only been a week. Around town they are great, but at freeway speeds they are all over the place and do not want to track a straight line. Car serviced two weeks ago and I was told the alignment looks fine. Tire guy at Costco said the same.
    Any chance this will get better? Purchased at Costco, so I assume they're returnable for the first 30 days.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    They might get better once they break in, but then it's too late to turn them back in if they don't.
    I've noticed that, if I had more than 40 psi in my Yokohamas, the steering felt extra light. Not quite twitchy, but not dialed in either.
  3. Prodigyplace
    12,717
    11,849
    Central Virginia
    Unfortunately, there are at least 3 very different tires with that same model. The Japanese ones are OEM on some Gen 4 Prii.
    I would tent to return them & get a different tire if they are acting that badly.
  4. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    Costco is usually very good on returns, so I would start there.
    Prodigyplace likes this.
  5. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    How many miles on the chassis ?
    Rob43
  6. tomfcb
    16
    Scottsdale, AZ
    About 62,000
  7. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    OK.
    This "probably" is a tire issue, But:
    The reason I asked about your overall mileage was this, at ~62K you're nearing the end of the useful life of your dampers. Under performing dampers, or worse, bad dampers can cause similar issues. Food for thought....
    Rob43
    #7 Rob43, Apr 23, 2019
  8. tomfcb
    16
    Scottsdale, AZ
    Thanks for the insight!
  9. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    That's pretty soon for swapping out dampers. My son has a Gen 2 Prius and we swapped front struts at 100K. There was no noticeable difference in the ride or handling and the old ones were still solid.
  10. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    I disagree. You are not accounting for all the different variables, sometimes dampers are spent at ~40K to ~50K.
    I build BMW street & race suspensions for my customers...I've seen and dealt with a lot of suspensions from all over the USA.
    Rob43
  11. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    In this case, the car got squirrely immediately after new tires. Tires would be the first place I would look, then suspension. At minimum, try the tires in different positions and ensure they are mounted properly and not defective to rule out the obvious.
    Merkey likes this.
  12. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    What don't you understand about this statement:
    "OK. This "probably" is a tire issue" .... from post #7 ?
    Rob43
  13. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Nothing - I understood the entire line.
    Merkey likes this.
  14. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    Good, we're making progress...
    Rob43
  15. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I may be a high school dropout, but I reed goode.
    Merkey, Yea Right and padroo like this.
  16. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    Again, we are making progress... ;)
    Rob43
  17. tomfcb
    16
    Scottsdale, AZ
    Super impressed with Costco tire people! They could not have been nicer or more helpful. They didn't have Michelin Energy Saver AS in stock when I went today, but will get a set by tomorrow. Hopefully I'll be in them by the weekend. I'll report back.
    Prodigyplace, Merkey and jb in NE like this.
  18. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    Excellent !
    Hopefully they completely solve your issue, try to put 50 to 100 miles on them for a good assessment.
    Rob43
  19. Yea Right
    232
    115
    Seattle
    2014 Prius Plug-in
    So why go back to the Michelin instead of your original choice?
