Brief Hesitation After Accelerating
Discussion in 'Gen 4 Prius Main Forum' started by 303inthe510, Jan 3, 2018.
  1. 303inthe510
    303inthe510 Member
    65
    70
    Oakland, CA
    I've now had two isolated instances of acceleration hesitation in the past 4 weeks. Both times the weather was dry and warmish (50's/60's), vehicle in regular drive mode (not eco nor sport). The vehicle has 4,200 miles.
    1st time: approached and slowed down to turn right at a green light. Upon coming out of the turn, I depressed the gas pedal to experience no response. It momentarily felt like the car had died. It resumed normal operation within 1-2 seconds. I didn't think much of it until ....
    2nd time: today, after stopped at a red light for approximately 45 seconds, I depressed the gas pedal to experience brief acceleration, then no response for 1-2 seconds, then normal operation resumed.
    I called San Francisco Toyota to chat with a service advisor but the receptionist was far more interested in scheduling a visit rather than transferring me. I'm sure a trip in will be fruitless since it cannot be reproduced on command.
    Has anyone else experienced this with their 2016+? Any advice? My only real thought is bad quality gas -- (?).
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Need more info, like state of charge of battery, driving mode, etc, etc.
  3. 303inthe510
    303inthe510 Member
    65
    70
    Oakland, CA
    The vehicle is always driven in 'normal' mode. Battery charge today was at about 50%. I do not know where it was at the first occurrence, but likely not drained as I had a decent braking period approaching that right turn. Fuel level today was just above half tank, I don't know where it was at the first occurrence but I never drive with the gas light on (always refuel around 1/4 tank). As mentioned, both times the weather was 50's/60's, and dry. Climate control off in both instances. Radio on in both instances. Windows up in both instances.
    This is my 2nd Prius, 4th hybrid. I've never experienced this hesitation in any of them except for this Prius.
    RCO likes this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    It could be worth letting the dealer look at it - hopefully it left an error code in the computer.
    RCO likes this.
  5. Tideland Prius
    16,680
    A swing in the dark but are you using your left foot to brake?
  6. 303inthe510
    303inthe510 Member
    65
    70
    Oakland, CA
    True, it could have thrown a code. I wonder how long these are stored (ideally I'd prefer to wait until my next service unless this issue worsens/occurs more frequently).
    Good thought but no, right foot only.
  7. Tideland Prius
    16,680
    Hmm, could be software I guess.
    Not sure. I was under the impression that it gets wiped on the 4th start up of the car.
  8. padroo
    padroo Senior Member
    2,763
    2,253
    Could be some issue with the fly by wire gas pedal. I would take it to the dealer like others have said.
    Raytheeagle likes this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Had you gone over any rough surfaces prior to the hesitation?
    I notice when I go over a set of 4 railroad tracks leaving work that I get a bit of pedal lag on out Gen3 .
    Could be the wire harness on top of the pedal or something the software is detecting.
  10. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    I noticed a few instances myself. Can happen if gas engine just shut off and takes a second to fire back up. Usually if you look at the MPH speedo it does go up when slamming the accelerator, it just doesn't have that instant Wide open throttle and noise associated with a normal car. OP, do you know if it was really 2 seconds or just felt like a couple seconds?
    RCO likes this.
  11. krmcg
    2,592
    2,393
    Whittier, CA
    I had my first incident of this today. Speeding up - then coasting in line for the green light at the signal and then when I stepped on the gas there was nothing but sponge for what felt like1 or-2 seconds (but was probable <1.
    RCO likes this.
  12. Tideland Prius
    16,680
    We have to ensure it's not the drive-by-wire.
    Drive-by-wire do have a lag time. If you mash the pedal, it will take up to a second for it to respond. (Well anything other than a light and gradual acceleration which is more common than you think).
    RCO and Raytheeagle like this.
  13. krmcg
    2,592
    2,393
    Whittier, CA
    I've driven a Prius since 2008. This was a new feeling. It felt like I was out of gas - and yes I have experienced that in a previous Prius.
    RCO and Tideland Prius like this.
  14. Tideland Prius
    16,680
    I remember the lag in our 2002 Camry. Much worse than the Prii (Gen 2, 3 or 4).
    Ok just checking :)
  15. 303inthe510
    303inthe510 Member
    65
    70
    Oakland, CA
    I don't believe so on the first experience, definitely not on the second experience earlier this week (it was a routine drive and occurred 3 blocks from my office -- smooth sailing. Yes, odd for Oakland. ;)
    As krmcg commented, likely 1 second, maybe a fraction less. When you're needing to accelerate to get through a light, though, it likely feels longer! Regardless, it was long enough to discern and look at the instrument panel/gauges.
    Exactly that. Just a mushy gas pedal with no reaction.
  16. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    It sounds like the engine could’ve still been in the warm up cycle.
  17. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    The torque from the electric motor would have been available even before the ICE kicked in if it was the warm up cycle.
  18. jaqueh
    341
    199
    San Francisco
    I haven’t tried this in my prime yet because I don’t want to abuse the car, but I remember in the Gen 2’s warm up cycle if you push the throttle past 90%, there is hesitation as I’m guessing the electric motor is prepping to take the ice’s overspin.
  19. priusman09
    priusman09 I used to be a TDI
    67
    76
    wisconsin
    Is it possible that there was a moment of wheel spin? The traction control cuts the power way back momentarily.
    RCO likes this.
  20. jaqueh
    341
    199
    San Francisco
    Yes this might be it as it recently started raining here in SF and the stock tires do not perform well with wet surfaces.
    RCO likes this.
