Bringing a Prius back from 4+ years parked
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Vgk, Aug 8, 2023.
  1. bisco
    52,904
    i would put the car back together and try using tech stream. if you are capable of building a grid charger, you should be able to get a mini vci up and running
  2. Vgk
    Vgk New Member
    Utah
    I don’t have tech stream but I have a nice scanner. It’s a Zurich ZR15. It will read all modules down to a headlight module if needed. The problem is I can’t get the scanner to make contact with the computer. The obd2 has 12 v at the port but I can’t get it to scan the car. I do have an update-
    Pulled battery from keyfobs to test them. Both weren’t in great shape so I changed them. But it didn’t do anything- I don’t think it would matter as I’m using they key slot anyways. I’m going to send the combo meter off today since I have it out. I’ll re visit the car when I get back from a work trip. Hopefully the combo meter is back so I can at least get that all put back together. I have heard people talking about the inverter water pump shorting out- my fuse is fine though. I might still try and unplug it to see if it makes a difference.
  3. Vgk
    Vgk New Member
    Utah
    Tried to unplug the inverter water pump and have no luck. I have the combo meter boxed up and ready to go. If anyone has any ideas on this let me know and I’ll try it. I won’t get back home for a week but hopefully the combo meter is finished and done by then.
  4. dolj
    dolj Senior Member
    8,657
    4,406
    Wellington, New Zealand
    You can disconnect the inverter pump at the plug shown in the image below. This is a more convenient place than at the connection on the pump housing.
  5. Tideland Prius
    16,683
    Done
  6. JC91006
    16,939
    8,647
    When messing with the HV battery, did you lock the interlock properly?
