Broken bolt on battery cell
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by danielac86, Oct 18, 2020.
  1. danielac86
    danielac86 Junior Member
    Saint Petersburg
    I
    So I've been replacing a cell on my hybrid battery and had a stubborn nut. Like an idiot, I over-torqued it and broke the bolt. My question is, anybody know a way to ensure a proper connection here without replacing the cell? If not, do you think with the surrounding nuts there's enough contact to trust this with one broken bolt? I appreciate any advice you've got.
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    No, you will need to replace the broken module.
    strawbrad and Raytheeagle like this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,226
    5,910
    Columbia, SC
    This depends entirely on what you're actually talking about.
    If you are talking about snapping off the threaded stud that fastens the busbar, then you need to replace the module.
    If you're talking about the mounting bolt that is under the module, fastening the module to the steel case, then no, it will have no effect on the integrity of the battery.
  4. Albert Barbuto
    102
    95
    Northeast USA
    A strong hybrid pack will deliver 150 amps during a full throttle acceleration, from a dead stop. All modules/connections MUST be able to support this. Your broken stud has rendered that module as "toasted".
    PS: Purchase a proper torque wrench before working on your pack.
  5. danielac86
    Saint Petersburg
    I
    Thanks for the tips. New modules are in the mail and I definitely learned a lesson here.
    Raytheeagle likes this.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    3,465
    1,505
    NJ-USA
    You also might want to completely clean or replace those bus bars. Any corrosion or high resistance will cause problems. Check the battery ecu connections for corrosion as well.
    If you are "just" replacing some modules (no charge/discharge cycling), then good luck.
