Broken Plastic cover under front of Prius
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by sumathisubra, Apr 17, 2013.
  1. sumathisubra
    sumathisubra Junior Member
    Houston, TX
    Vehicle: Prius Hybrid Car, 2010 model
    Hello, 2 weeks ago, when we were driving to the next city, we noticed a loud scraping sound from front. So we stopped and checked and this mangled broken plastic (black color) was getting dragged on the road. We didn't have any tools, but the plastic was so damaged, I was able to twist it off. But I am worried if this is an important part and needs to replaced.
    1. Has anyone had this problem?
    2. did you fix it?
    3.What did you do to fix it?
    4. how much does it cost?
    5. where is the best place to get it done?
    6. Is there a proper part name for this?
    Thanks so much.
    49,490
    welcome to priuschat, all the best!(y)
  3. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Welcome to PC. Likely this is your under belly Pan/Shroud, or part of it. The oil change "door" is a known issue. Picture would help.
  4. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Disclaimer: I am not a mechanic. That plastic piece is a just a shroud to protect the heat of your engine from contacting whatever you drive over. I heard this on Click an Clack. If you drive over tall grass for example, you could start a fire. If the car stays on pavement, it doesn't matter. It has broken off on a couple of my cars. I just remove it. Cost depends on which shroud was broken I'd ballpark it at around $200 with installation.
  5. frodoz737
    4,297
    2,348
    33
    http://priuschat.com/attachments/t-sb-0032-11-engine-under-cover-warpage-pdf.32703/
    If you are within the 3/36 you are covered with this TS-B. If not, my parts dept. quoted $250 for the shroud plus pins as required for $2.50 ea. They will give you 10% off if you ask, usually. If it is just the oil door section of the shroud, you could choose to ignore it as many are missing on cars out there it is already. That's why the TS-B. Jack it up to take a look, then you can decide.
  6. Brian Adcock
    Brian Adcock Junior Member
    NC
    I have a 2008 Prius. Is the shroud one piece or two? Mine is shot from the previous owners neglect.
    I would like to replace it.
    Source or a link to replacement???
    Any help is greatly appreciated!!!
    Brian in NC
