Broken plastic "spoiler" on lift gate
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jerpag, Feb 5, 2013.
  1. jerpag
    jerpag Junior Member
    illinois
    I forgot I had my lift gate open and backed out of the garage...crunch! Broke off the plastic air spoiler thing. It was attached with some kind of adhesive covering 5 bolt heads and a snap on grommet at each end.
    I drilled out the old adhesive on the plastic panel and chipped it off the bolts. I hope I can get two new plastic fasteners at Toyota or a body shop. Question...should I just use a two part epoxy (or what else is recommended) on the bolt heads to mount it again?
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Use low expansion foam in a can,very strong stuff but be careful not to overuse
  3. jerpag
    illinois
    Do you,ean the stuff they use for insulating around windows and doors.
  4. tankyuong
    1,555
    662
    Central MO
    Yes works like glue when dried
  5. ksf
    ksf Junior Member
    lawrence NJ
    I had the same thing happen to my 2010 prius. I used 2 part epoxy to re glue the bolts back to the spoiler. the difficult part was getting them aligned correctly.
  6. Scott McGregor
    Scott McGregor Junior Member
    Llandrindod Wells UK
    My 2005 Prius' rear handle assembly broke and was only held on by a couple of plastic fasteners. Every time we would forget the thing would flop down slapping the hatchback and hanging by the electric wires to the hatch release. I also JB Weld'd the bolts back in and it's working great! This lift gate assembly is $148 and up. Happy to help other DIY rather than buy overpriced plastic pieces of shit.
    Garnish SubAssy Rear Emblem Panel Lift Gate Garnish
    76801-47060
  7. retired4999
    2,652
    627
    Eau Claire, Wi.
    I feel better that I am not the only one to do this to the rear hatch! Good luck with your fix! :)
  8. brin wood
    brin wood Member
    100
    upstate NY
    I opened the hatch and the unit came off. All the plastic tabs broke. Had to put 2 bolts through to deck lid in special bolt adapters; but it works! Saved a bunch of money.
  9. Mendel Leisk
    42,108
    Interesting, I'll keep that in mind.
    I've used that stuff in it's usual application, sealing opening in a crawl space. Next time I'll wear gloves and wear a hat...
  10. Mendel Leisk
    42,108
    I've hit our spoiler maybe 3 or 4 times now. One time sort of derailed the the garage door, lol. So far the spoiler's survived, I've buffed it out and used black lacquer touch up paint. At least I'm getting cagier about it:
    Tube insulation added, extends an inch or two beyond metal arm at bottom, secured with Velcro tape.
    #10 Mendel Leisk, May 31, 2015
  11. vknwny
    vknwny Junior Member
    Inland Seas
    Would love to know more about the "special bolt adapters", since my 2007 Prius' rear handle just came off and is currently duck-taped in place.
    Also: has anybody here tried the $23-$33 "garnish" currently available on eBay? If it works well and holds better, it might be worth the spend. It's almost $30 bucks for fresh JB Weld and two-part epoxy.
