Brz wheel tpms sensors vs prius
Discussion in 'Gen 4 Prius Technical Discussion' started by Recian, Aug 15, 2021.
  1. Recian
    Recian Junior Member
    58
    New Bern, NC
    I've got a set of BRZ wheels with sensors. Since apparently Toyota changed something in TPMS registration process in 2018 prius my Signal Tech 2 TPMS learn tool can't pick up pirus 2018+. It will only read 06-17 even with the newest 2021 update. My snap-on tpms tool also only does 06-17. I can't confirm if these will work on my 2018 prius because I can't read the data on my existing sensors. Theyre shaped the same but from what I'm reading they're different frequencies. Can anyone confirm? I'd like to get another set of sensors rather than dismount and swap my sensors from my other rims so I've got 2 sets.
  2. ISFdude
    ISFdude New Member
    Queens New York
    They are the same part number, I installed BRZ wheels on my 2017 Prius and had to reprogram the sensor ID’s to the computer and everything is good. Just make sure the sensors are part number PMV-C010 and you are good to go.
