BT Plate
Discussion in 'Gen 2 Prius Accessories & Modifications' started by peanutmac, May 1, 2007.
  1. dogfriend
    7,512
    1,190
    Carmichael, CA
    <div class='quotetop'>QUOTE(darelldd @ May 1 2007, 09:27 PM) [snapback]433752[/snapback]</div>
    I didn't notice any handling improvement with the mud flaps, but my fenders seem to be staying a little cleaner :p .
    I haven't installed the rear mud flaps yet, so maybe they are the ones that improve the handling.
  2. TheAnnoyingOne
    TheAnnoyingOne New Member
    318
    -118.15476, 34.112134
    My Voodoo advisor told me that the BT plate works because it is (I) black and (II) non magnetic. She also said that if there is enough interest she will elaborate on the reasons. :unsure:
  3. Gadgetdad
    Gadgetdad New Member
    462
    Modesto, California
    B) The plate works, guys, get over it! Spend a few bucks and find out!
  4. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(dogfriend @ May 1 2007, 09:38 PM) [snapback]433755[/snapback]</div>
    There you go! Don't even think of talking about the issue until you've installed the item in question! No soup for you!
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(dogfriend @ May 1 2007, 11:38 PM) [snapback]433755[/snapback]</div>
    Ah, but do you have scientific proof that the mud flaps are keeping the car cleaner. I could just be placebo affect after you spent your $60 and expect it to reduce mud and that's what you percieve when you look at your car now.
    We need someone to design a scientific test to see if mud is actually blocked, it should be blinded and a carefully calibrated mudometer used to determine the weight and density of the accumulated mud and debris. :p
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    <div class='quotetop'>QUOTE(efusco @ May 2 2007, 09:09 AM) [snapback]433861[/snapback]</div>
    It could be that the drivers are subconsciously avoiding mud now that they have mud flaps. In order for this test to have any credibility, they need to drive blindfolded. If their passengers are also blindfolded, then we have a double blind test.
    Tom
  7. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(qbee42 @ May 2 2007, 08:16 AM) [snapback]433863[/snapback]</div>
    Excellent point.
    So, our null hypothesis must be that "the use of mud flaps does not reduce mud and debris on the car sides".
    Double blind drive as you describe both with and without the mudflaps installed.
  8. dogfriend
    7,512
    1,190
    Carmichael, CA
    <div class='quotetop'>QUOTE(efusco @ May 2 2007, 06:25 AM) [snapback]433868[/snapback]</div>
    I invite you to go ahead and run the double blind test with your vehicle. Unfortunately, I have other commitments which do not allow me the time to complete the study. :)
  9. TheAnnoyingOne
    318
    <div class='quotetop'>QUOTE(Gadgetdad @ May 1 2007, 11:30 PM) [snapback]433787[/snapback]</div>
    Know that, had one installed two months ago. :)
    My Voodoo advisor was very impressed and attempted to explain the behavior based on her beliefs. Sorry if you misunderstood me. :(
  10. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(The Annoying One @ May 2 2007, 07:27 AM) [snapback]433912[/snapback]</div>
    Excellent. You are hereby knighted as "Worth To Post." Please continue.
  11. John in LB
    John in LB Life is good
    399
    27
    Orange County
    You guys are on the right track. Be aware that by design, the extra couple of inches of the BT plate beyond the bolt pattern do provide additional and significant torsional stiffness. Here is a photo showing the loading and the differences between the 2 plates.
    [attachmentid=7804]
  12. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(efusco @ May 2 2007, 06:09 AM) [snapback]433861[/snapback]</div>
    I think that you're just trying to cover up the fact that you have less mud perception than the *professional* drivers that have noticed a drastic improvement of mud rejection. Those guys can tell the difference between ONE splater and TWO! Everybody who's put these flaps on says there's less mud. $60 is a small price to pay, just in case they DO work as advertised. Hell, you probably used the wrong torque on yours anyway. And this assumes that you actually have them installed - which I'm beginning to doubt!
  13. John in LB
    399
    27
    Orange County
    <div class='quotetop'>QUOTE(efusco @ May 2 2007, 05:25 AM) [snapback]433868[/snapback]</div>
    You should be ashamed of yourself for making a mockery of the post (and for posting large photos...) :rolleyes:
    Can a moderator kick himself off the PC? Has that ever happened? :p :D
    <div class='quotetop'>QUOTE(darelldd @ May 2 2007, 06:57 AM) [snapback]433941[/snapback]</div>
    Just for that, I am going to give you some depressing news....
    Mud Flaps increase your wind resistance and therefore hurt your gas mileage... there!! Fester on that for the rest of the week.... :eek:
  14. Syclone
    Syclone Member
    540
    <div class='quotetop'>QUOTE(John in LB @ May 2 2007, 11:17 AM) [snapback]433954[/snapback]</div>
    I really resent the tactics of the "mud flap contingent" piggybacking on this BT Plate thread and trying to usurp our silliness with their obviously contrived silliness.
    BT'ers unite! Stop this plot in its tracks. Otherwise, someone will try to sneak in a thread about the relative benefits of metal tire valve caps as opposed to plastic ones.
  15. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(syclone @ May 2 2007, 10:35 AM) [snapback]433966[/snapback]</div>
    You're just defensive b/c you know you don't have any scientific proof that your silliness is more valid than our silliness. We now need a silliness study to confirm or refute whether your impression that your silliness is greater than our silliness is valid.
    Stop the insanity!! :eek:
  16. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(rvancil @ May 1 2007, 09:16 PM) [snapback]433748[/snapback]</div>
    Out of curiousity, what is the width (195, 205, or???) of your new tires? I am starting to wonder if going to 205 series (or higher if that is possible) is in fact a solution to the buffeting issue. I have had 205 series tires on my car from day 1, and have not noticed any issues with buffeting (in 40+ mph crosswinds on the highway as well as passing trucks on the highway). There is a slight movement (roll?) of the body (which tells me the car is getting blown by the wind), but no issues with the car wandering on the road.
    Oh, and I don't have the BT Tech plate. I have the TOM'S Upper and Lower Front Suspension Braces on order, but they have not arrived as yet. So, other than the tires and wheels (and ceramic pads, but the pads have no effect on resistance to buffeting), my car is a box stock Touring Edition Prius.
    <div class='quotetop'>QUOTE(syclone @ May 2 2007, 08:35 AM) [snapback]433966[/snapback]</div>
    But there is a difference... it is in the magnetic forces of the metal tire valve caps and the resulting efficiency increase of the HSD.... Check with any spiritual advisor - they will set you straight....
  17. priussoris
    priussoris New Member
    1,005
    Ok a test for BT plate go down the highway open the right rear window first see if you get a weird vibration and noise if not open the left rear window and notice, if not open right front window now if you do not get the vibration I would say the plate works
    now get out there and check :)
  18. Gadgetdad
    462
    Modesto, California
    I actually think the metal tire caps both improve the ride and the fuel echonomy. Scientifically, the metal has a lower coefficient of drag than the plastic..... ;)
    However many will point out the extra dynamic weight of the caps will cause a decrease in FE.......
    Lee
  19. Syclone
    Syclone Member
    540
    <div class='quotetop'>QUOTE(apriusfan @ May 2 2007, 01:51 PM) [snapback]434082[/snapback]</div>
    Coming back to reality.... After I installed the bt Plate, I got rid of the UN-Integrity's and put a set of Michelin MXV4 Plus tires, because of the Integrity's poor traction on wet roads. It had the desired effect, plus the slight residual rear end instability that still existed after installing the BT Brace totally disappeared. The rear of the car became 'truly dead' as it should be on a front drive vehicle.
    What effect the metal valve caps have doesn't seem to be measurable. :lol: :lol:
  20. bobc
    bobc New Member
    361
    Durham, NH
    Let's discuss the benefits/disadvantages of 22-24 lbs of torque originally spec'ed for the bolts compared to the commonly understood 20 lbs of torque compared to the new revelation of 17 lbs, shall we?
    I can't believe it: I just posted this and just find a post specifically on torque values!!
    This site isn't called Priusyack for nothin'!
