BT Skid Plate installed--summary
Discussion in 'Gen 2 Prius Accessories & Modifications' started by efusco, Feb 16, 2008.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    There's really no contact now that I added some spacers/shims. There was one spot that was very close and I chose to add some padding to avoid any contact of metal on metal, but otherwise all is well.
  2. Doc Willie
    1,717
    144
    Out there, somewhere
    For some reason, the plate did not contact any part of the engine. There is at least a 1/4" clearance at the part the Evan had touching. I suspect there may be some variablility in engine mounts or chassis connections or the location of the intermix flow sensors to the dilithium chamber.
  3. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    would most people consider this addition necessary?
    does it block airflow, or does it hinder cooling?
    does it obstruct the ease of changing oil or other regular maintenance items?
    i do realize that it protects the bottom of the car from road debris, but does this skid plate really help? i guess what i'm asking is that has there been many incidents of road debris damaging the engine?
    i would assume that my 08 is similar to the earlier models, but has toyota addressed the issue in my year?
    last, would most people consider this a necessary modification?
    thank you
  4. efusco
    19,891
    1,194
    Nixa, MO
    If you'll search for the 'big' BT skid plate thread you'll find a plethora of discussion of your questions.
    I'd say that most people don't consider there to be an "issue" and hence the plate is not "necessary". I think it's like a belt and suspenders...it adds a modicum of safety, may help reduce air flow around the engine a little when used with grill blocking (an advantage in winter). With the grill unblocked there'll be no issues with cooling as there's plenty of air flow.
    It's a nice little unnecessary mod that may, one day, save someone from buying a new inverter/PSD assembly...or maybe not.
  5. Gadgetdad
    Gadgetdad New Member
    462
    Modesto, California
    Evan, I haven't installed my skid plate yet, :mad: but now I am thinking of puting in the Fumitomo oil drain valve. Should I install the valve first or do it after the skid plate is on....or not at all?
    Also, when you touch a parking curb does it sound like metal crunching, or is it higher than the plastic parts and not easily scraped?
    Thanks,
    Lee
  6. efusco
    19,891
    1,194
    Nixa, MO
    And you were harassing me for delaying installing the strut brace huh!!! Big talker!
    Fumoto valve...I think this is sort of an "it depends" question. It might be smartest to install the skid plate first, see what YOUR clearances look like (as they're apparently different vehicle to vehicle) and then decide. The cut out was not designed with the Fumoto in mind, but I think the oil will still shoot out the hole just fine. I don't see any reason you would have significant trouble putting the fumoto in later as long as your clearances look ok. Worst case is you might need to loosen the rear-most screw on the oil plug side to give yourself a little room to work a wrench in there then tighten it back up later.
    Get on it...what else you gotta do this sunday afternoon.
  7. Gadgetdad
    462
    Modesto, California
    :whistle: Yeah, sorry for the big talk! Weather is too nice (93) today, and I want a few hours of just-in-case time to pad the project.
    I still have several mods awaiting my time: Mud flaps and LED footwell lighting (al la Nathan's timer circuit and Cyron lighting). I did get my Bazooka Sub-Woofer in thanks to help from Circuit City.
    :cool: Lee
  8. wile-e
    wile-e Junior Member
    50
    Clearance hasn't been a problem on my skid plate. (so far, I am almost done and had to get upright for a few minutes.)
    I also painted mine with a rubberized sound deading undercoat. I discovered this trick years back when installing any "sound board" type parts on my vehicles. The thin coating makes an incredible difference as far as wind noise transmission. It creates a 'pebbled' flat black finish which is paintable.
    Be careful with spraying this stuff in enclosed spaces. TOXIC FUMES! If you decide to use it the proper prep for a powder coated finish is to use 0000 steel wool on the entire surface and then clean it with a denatured alchohol soaked rag. (careful with denatured - toxic irritant that can melt plastic.) The alchohol will dry within seconds and you should paint immediately. Follow the can directions for application.
    Allow to dry for at least two days.... I know what the can says but take it from someone who knows the product. You are at the mercy of far too many environmental factors to trust that this stuff is completely dry before that point.....
    Enjoy!
  9. HomeandRanch
    HomeandRanch New Member
    78
    Boy I am glad I paid the money for the dealership to install mine. Sounds like a pain :)
  10. BT Tech
    BT Tech New Member
    885
    South Florida
    It is definately easier to have a tech install it for you but the average "shade tree" guy can get the job done in about 2 hrs.
  11. CBarr31
    CBarr31 Active Member
    436
    225
    Charlotte, NC
    Evan,
    I was looking for an update on the longer front piece and wondering if it closed the gap between the front piece and the skid plate? If so what is the gap and do you have any pics? I didn't seem to see them on your site but if they are there let me know and I will look again thanks.
    If anyone else is out there that has a skid plate installed that has their oil changes done at a dealer have you gotten any comments on the plate? Heck, some may even like it because the underside of Prii are somewhat more vulernable than other cars. Just wondering if any have given you a hard time about it though.
    Thanks for the info.
    Chris
  12. efusco
    19,891
    1,194
    Nixa, MO
    Chris,
    I got the longer nose piece and it did, indeed, extend further back and covered the gap, though I wouldn't use the term "close" the gap b/c the nose piece rests below the main part of the plate by about 3".
    I ultimately removed the longer piece for the shorter one b/c the longer piece was so heavy it actually sagged and put a lot of stress on the plastic front pieces it attached to.
  13. CBarr31
    436
    225
    Charlotte, NC
    Evan,
    Thanks for the info. Good to know about the longer piece being to heavy for the plastic. Now the questions would be for Brian as to which one comes with the BT Skid Plate if I ordered one today.
    Thanks agian,
    Chris
  14. efusco
    19,891
    1,194
    Nixa, MO
    Chris,
    Brian had planned to send me a nose piece somewhere b/w the lengths of the short and long one...I think if he did one with the little bend at the back similar to the main skid plate to add a little rigidity to it that it would work great at a middling length.
  15. earthman
    earthman New Member
    47
    Vermont
    Not long ago I had my free oil change done at the dealer, I did bring my own Mobil1. The mechanic came over and asked about the skid plate afterward, he is a Prius owner also. He was impressed, the access panels were placed exactly right & the protection complete. He wanted one for his own Prius & asked where to get one. Don't worry Brian, I pointed him in the right direction.
    Also I live about 3 miles up a dirt road which gets especially rough in the spring. Lots of frost heaves & mud to contend with. Just the other day driving up my hill I heard a rock bang off the skid plate. Glad it was there.
  16. CBarr31
    436
    225
    Charlotte, NC
    Evan/Brian,
    I received my skid plate yesterday but there weren't any installation instructions with it. Were there supposed to be or are we just supposed to reference your photos for the install?
    Since it is unlikely I will be doing this installation myself some sort of basic reference or guide would be helpful. I believe there was mention of a PDF file in another post but I can't seem to find it.
    Any help would be appreciated.
    Chris
  17. BT Tech
    BT Tech New Member
    885
    South Florida
    You should have received an instruction set with your BT Tech skid plate. Please provide me with your email address and I will send them over to you right away.
  18. CBarr31
    436
    225
    Charlotte, NC
    Brian,
    Just sent you a PM with my email address. Thanks for the immediate response I really appreciate it.
    Chris
  19. BT Tech
    BT Tech New Member
    885
    South Florida
    Hello Chris,
    I just emailed you a copy of the instrucions. If you have any questions please let me know.
  20. CBarr31
    436
    225
    Charlotte, NC
    Evan/Brian,
    I had a shop do the install of my skid plate today after I attempted to install the tower brace, that is another story in the tower brace thread. And we got to looking at the front chin piece and there is no support other than the plastic front clips?
    It was VERY flimsy when installed and would surely flap in the wind something fierce at interstate speeds. And since I do a lot of driving on interstates and at highway speeds we decided to leave the stock plastic front piece and attach that the large metal skid plate. Do you forsee any issues with that?
    I haven't seen the final install because I am also having them spray the wheel wells with GMuff sound deadening spray to augment my dynamat install and we wanted to let it sit overnight to dry.
    Thanks for all the help and excellent instructions. Happy driving to all.
