BT Tech Introducts 2 new products for the Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by BT Tech, Dec 6, 2007.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Underbody does not have much drag to begin with. Blocking the grill would improve the most. See the chart from a Volvo with 0.29 cd.
  2. BT Tech
    BT Tech New Member
    885
    South Florida
    While this is true that the underbody does not contribute much to the overall cd, it is always desirable to have a smooth transition to reduce turbulence.
    In other words, our BT Tech skidplate was primarly designed to protect the engine/transaxle/generator components and at the same time reduce undercar turbulence by creating a smooth transition for more laminar airflow.
    Blocking the grill is something that I do not advocate due to the reduced air flow/cooling the engine would receive.
  3. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    If the skid plate doesn't conflict with the TOM'S front lower suspension brace, you can put me down for one too.
  4. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    ditto... it'd be handy for that 40km of gravel road i like :)
  5. Tideland Prius
    16,680
    Jeez.. where'd you find that and why? lol (I'm guessing the Interior somewhere)
  6. apriusfan
    6,050
    205
    S.F. Bay Area
    Always a comedian.... How about mud? Snow ultimately would melt - sooner with global warming; but mud, that gets harder with temperature increase (with the right composition (as in clay), it becomes brick-like).
  7. BT Tech
    BT Tech New Member
    885
    South Florida
    The picture that I posted has been our prototype. The production part will have only one round hole for access to the oil filter and 2 oval holes on each side of the skid plate for easy access to the oil and transaxle drains.
    There will be a removable cap on each access hole to prevent snow, mud, sand, dirt, salt, lunar dust, cosmic rays and anything else from getting up in there and accumulating... :)
    I hope to be able to post a picture next week of our finished production version. It will have a very durable textured powdercoated black finish and strenghthing ribs stamped into the plate.
  8. mrbigh
    3,686
    699
    Long Island, NY
    This is really a very good idea and an improvement for a product not yet released for sale, I vote for it and count with my order if the price ($$ x AL x Lb) is right.
  9. mrbigh
    3,686
    699
    Long Island, NY
    I was thinking about the same concept while reading the full thread.
    I sign-up for this idea to..... lets make it happen!!
    and How about to install a periscope or a video camera to check the conditions of the skid plate ?
  10. BT Tech
    BT Tech New Member
    885
    South Florida
    Maybe on a "future" revision... :) :)
  11. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    ooh... woe be to the tech who drops a socket in THAT engine compartment!
  12. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Hmmm....yeah, that could be interesting. Is there any little 'drain hole' at the lowest end for water and grit and...sockets? Is there any stiffening effect of the front end? Where does it attach? How many bolts to remove the plate? Do I need to drill and tap holes? I'm liking your idea so far, Brian. Would you consider taking an unused spoiler back in trade?
  13. apriusfan
    6,050
    205
    S.F. Bay Area
    Or, for assisting in parking to eliminate the blind spot in front? The skid plate is a perfect mounting point for a video camera.
  14. apriusfan
    6,050
    205
    S.F. Bay Area
    A magnet could drag the socket (or wrench or whatever was dropped) over to the access hole. No big issue compared to the protection for the expensive bits.
  15. apriusfan
    6,050
    205
    S.F. Bay Area
    Brian, what was the second new product? (Your thread title refers to 2 new products.)
  16. HolyPotato
    HolyPotato Junior Member
    92
    Toronto, Ontario
    Hmm, good question. Does this impact the crumple zone's ability to crumple?
  17. fruzzetti
    fruzzetti Customization-Obsessed
    377
    California (Pulled over 6x, ticketed 2x for tint)
    ... If you're looking to lose it?
  18. patsparks
    10,664
    569
    Adelaide South Australia
    I was wondering the same thing.
  19. galaxee
    9,810
    471
    MD
    no offense meant, Brian, but DH would be asking his customers to remove that prior to him working on it. flat rate's tough enough without spending a half hour trying to dig a $50 socket out of a prius NOT equipped with an undershield. where he worked, he knows for a fact they'd charge extra to work on it.
    you've accounted very well for regular maintenance as far as the access ports go. but part of maintenance is visual inspection, which gets a lot harder with that part on. looking for oil leaks, mouse nests, whatever. can't be done without removing it.
    Brian, have you looked at any increases in engine/trans temps in response to this mod? the picture doesn't show the back end of this very well, how much clearance is there to allow exhaust heat to escape?
    how much does this plate weigh?
    he doesn't mean to dog on you Brian, honestly. but skid plates and prius seem a highly unusual combination. he hopes you can use his viewpoint to improve your design, because he does support modification and innovation like what you're doing.
  20. apriusfan
    6,050
    205
    S.F. Bay Area
    One approach that is followed by other skid plate manufacturers is more holes: http://new.minimania.com/web/Item/N...SKID PLATE SUMP GUARD - MINI COOPER & S 02-06
    Another approach is to make the skid plate more of a set of longitudinal bars connected at each end by a cross-bar that is in turn bolted to the chassis. The concept follows the skid bar model for off-road vehicles. Indeed, the H1 Hummer has a number of the skid bars mounted to protect the engine, transmission, transfer case and differential areas.
    I would think the the skid bar model would address most of DH's concerns.
