BT Tech Rear Aero Spoiler!!
Discussion in 'Sponsored Commercial Sales' started by BT Tech, Aug 7, 2005.
  1. BT Tech
    BT Tech New Member
    885
    South Florida
    Thanks for your comments below.. When I first started testing the various locations on the car the main objectives were that it had to be functional and had to have an OEM (stock) appearance.
    Placing our aero spoiler on top of the rear hatch had 2 major problems.
    1: It caused too much drag
    2: It looked AWFUL
    When I design these parts, I ALWAYS try to think about how to do it in the MOST unobtrusive matter possible. Just like the factory would do on a vehcile they would sell to the public. To me, when it is done this way it LOOKS like it belongs and is NOT an afterthought.
    Thanks!!
    Brian
    BT Tech
    305-652-3115
  2. BT Tech
    BT Tech New Member
    885
    South Florida
    Yes!! You will shortly be able to specify your vehicle's color for your new aero spoiler!!
    I will keep everyone posted.
    Thanks!!
    Brian
    BT Tech
    305-652-3115
  3. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Brian
    How far up the glass from the bottom edge does the spoiler measure?
    Wayne
  4. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    This sounds interesting, but would someone explain how this works? I think I basically understand the airfoil effect, and how wing and splitter spoilers are basically inverted airfoil/wings. I believe this spoiler is a lid spoiler and hyo silver was talking about a roof spoiler. I suspect both work on the same principle, which I can't seem to visualize.
    Also, can you give some details such as lift/drag ratio (or is it downforce/drag ratio)? I expect this to have little effect both to drag and downforce at low speeds, and to make a significant difference at high speeds. Is that correct?
    Where is the downforce applied to the car? Is it relatively distributed or toward the back where the spoiler is located? If it is to the back, isn't this sort of imbalanced?
    Does the spoiler affect rear visibility at all? Or is below the portion of the rear window which is transparent?
  5. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I don't profess to be an expert on this, but I will attempt an explanation. Brian, or anyone else, please correct me if I'm wrong.
    Because of the shape of the prius, air flows faster over the top of the car than it flows under the car, and generates lift, just like an airplane wing. It's not enough to make it fly, but it is enough at higher speeds to make the steering feel lighter, and to increase the sensitivity to cross winds.
    The spoiler adds a bit of drag, slows down the air, and reduces the lift. My intuition tells me it's not a matter of adding downforce, but of reducing lift to let the car's weight keep it on the road.
    I can't quote lift/drag ratios, or say how the centre of pressure changes with the location of the spoiler. I would guess that the spoiler might appear a little thicker through the rear view mirror, and that mileage would be slightly affected. But, if you spend much time at highway speeds, particularly in a windy place, these trade offs are more than welcome.
  6. djasonw
    djasonw Active Member
    962
    123
    Coconut Creek, FL
    That seems to make a lot of sense. Now you have me wondering... at what speed can I safely rotate to take off? I'd LOVE the idea of a flying Prius!!!!
  7. popoff
    popoff New Member
    560
    western NC mountains
    Brian, in the flurry of messages since your announcement, you may have missed my request to post a photo of just the device.
    It's hard for me to visualize what it looks like when I see it in the photos you have posted.
  8. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Sorry, I don't think you'll see any flying Prii anytime soon. Unless of course they're pink and you've had too much of a good thing. :lol:
  9. ryogajyc
    985
    165
    Reseda, CA
    <div class='quotetop'>QUOTE(hyo silver\";p=\"115379)</div>
    Interesting. When I was trying to visualize how it worked, all I could see was that it would slow down airflow and I discarded that as a useful mechanism for a lid spoiler to use, since that seems like drag penalty is pretty high to gain downforce compared to a wing or splitter spoiler. I guess I neglected the possibility that it may have a worse downforce/drag ratio, but still be a useful tradeoff.
    Brian, how about a photo from the interior through the rear window to see how it affects visibility/looks from the inside?
  10. NuShrike
    NuShrike Active Member
    1,378
    How fast do you have to drive before the car starts experiencing body 'lift'? I had understood anecdotally was around 90mph and higher. Basically, you have to approach race-track speeds.
  11. BT Tech
    BT Tech New Member
    885
    South Florida
    Thank You HyoSilver!! You saved me A LOT of typing. :D I could not have explained it better myself!!
    Thanks!!
    Brian
    BT Tech
    305-652-3115
  12. BT Tech
    BT Tech New Member
    885
    South Florida
    Hello Nushrike... I am not sure where you got your figures but a Cessna 152 will get airborne at less than 50 kts.
    The faster you go, the more stable the car does become due to the downforce being generated but with my spoiler in place, you can generally start to feel its effect at 50 MPH and up.
    Thanks!!
    Brian
    BT Tech
    305-652-3115
  13. BT Tech
    BT Tech New Member
    885
    South Florida
    As soon as I receive them from the machine shop, I will take a picture so everyone can see it un-mounted.
    Thanks!!
    Brian
    BT Tech
    305-652-3115
  14. djasonw
    962
    123
    Coconut Creek, FL
    Very true... I used to own a C152 and I would push down on the yoke to keep it on the ground until 80 knots. The I would pull back and takeoff like a fighter pilot. Only did that a few times.
  15. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    How much pressure is exerted on an airfoil that is doing a lot to hold the car down? Is even really tough superglue going to keep it in place?
    What kind of under-car additions would work to equalize the pressure and lessen the lift?...
  16. BT Tech
    BT Tech New Member
    885
    South Florida
    Yup!! I have done that more than a few times. :) That a/c had a pretty low stall speed too but I do remember quite vividly once when I was on my downwind trying to keep my distance from a banner puller.. I had my flaps at 10 degrees, power pulled way back and I was still gaining on that banner with the stall warning blaring away!!
    Oh well, let's not talk about the full power stalls to induce a nice spin!! :)
    Thanks!!
    Brian
    BT Tech
    305-652-3115
  17. popsrcr
    popsrcr New Member
    232
    Richmond, VA
    yeah, I'm thinking there isn't enough pressure exerted at 55 mph that you couldn't hold it on with Blu-tak.
    If people here start gluing thing on, I just won't believe it. This is a group of folks who pride themselves on 60 mpg, and their going to take an MPG hit for this? Seat of pants dynos are sooooo cool.
  18. BT Tech
    BT Tech New Member
    885
    South Florida
    Hello Mike. We are not holding the entire car down with this part. We are merely changing the direction of the airflow to reduce the amount of lift that is being generated on the vehicle.
    Thanks!!
    Brian
    BT Tech
    305-652-3115
  19. mikepaul
    1,763
    Columbia, SC
    OK, I mis-interpreted one of the previous posts and thought downforce was an important aspect of this part doing its job. Lots of downforce would probably need a welded-on part.
    Since I think, IMHO, that the car's main problem is being blown off course due to aerodynamics, I'm willing to look into an effective solution for that. Early adopters should post freely... :mrgreen:
  20. Godiva
    Godiva AmeriKan Citizen
    10,339
    That isn't the only think this part is supposed to adjust.
    My car was rocked by a (not that big) truck going by.
    Supposedly this part is going to help with the shimmy when a larger, faster vehicle is passing you.
