BT Tech Stiffening plate update
Discussion in 'Sponsored Commercial Sales' started by BT Tech, Nov 14, 2005.
  1. hobbit
    hobbit Senior Member
    4,089
    470
    Bahstahn
    Well, the oil drain is way on the other end of the crankcase; I
    was thinking of a somewhat smaller plate, mostly for the transaxle.
    Cooling should be a non-issue since that whole thing has its own
    radiator whose coolant loop runs all the time, and a set of holes
    through the plate could probably provide sufficient airflow and
    access to the various fill/drain plugs and electrical connectors.
    Research is definitely warranted. I thought of this because I was
    poking around under my parents' Corolla and their auto trans has
    a very tidy and fairly close-fitting skid plate mounted under it.
    And I'm pretty sure their tranny doesn't have a separate cooler..
    _H*
  2. hobbit
    4,089
    470
    Bahstahn
    Okay, I took another look under the Corolla. It looks like the
    "skid plate" is smaller than I thought, and is just an additional
    bit of metal that's actually spot-welded over the front half of
    the ATF pan and not actually bolted to anything. So it's nothing
    like I had in mind for a Prius housing.
    Then I crawled back under the prius and looked for solid attachment
    points, mostly in vain. Mounting points would have to either be all
    on the transaxle [so it moves with the engine/trans], or all on the
    frame so the engine moves behind it. And toward the front, the
    potential points are piteously scarce. But if y'all at BT did come
    up with a good solution, I'd definitely buy one and evangelize them
    locally! Having had my share of dirt-bike crankcases saved by such
    things in the past, I see a real need here.
    _H*
