BT Tech Stiffening plate
Discussion in 'Gen 2 Prius Accessories & Modifications' started by BethlehemPrius, Feb 4, 2007.
  1. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(windstrings @ Jun 17 2007, 08:24 PM) [snapback]463745[/snapback]</div>
    Now the sights can be set to 800 posts. Thank you to all who have posted in this thread and not started a separate thread; the thread count appreciates your diligence.
  2. TheAnnoyingOne
    TheAnnoyingOne New Member
    318
    -118.15476, 34.112134
    Is there a way to cross-link the BT posts?
  3. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    I think it would be cool if BT would mill its initials or (for an extra fee) the owner's initials, out of the plate material...instead of that boring 'x' pattern...
    Come to think of it, I wish that my xootr said 'xootr' underneath, instead of that boring 'x' pattern, too...
    Maybe it's just me.
    702!!
  4. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(Pinto Girl @ Jun 18 2007, 02:42 PM) [snapback]464290[/snapback]</div>
    Or maybe something like
    For one of your own, call Brian at XXXXX
    for the mechanic that sees it when the Prius is on a lift.
  5. apriusfan
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(The Annoying One @ Jun 17 2007, 11:35 PM) [snapback]463847[/snapback]</div>
    Out of curiosity, what are you attempting to accomplish with cross linking the BT posts?
  6. Pinto Girl
    3,093
    350
    <div class='quotetop'>QUOTE(aaf709 @ Jun 18 2007, 05:14 PM) [snapback]464312[/snapback]</div>
    YES!!!
    'btbrace.com' or somesuch.
  7. Tyrin
    Tyrin New Member
    272
    <div class='quotetop'>QUOTE(Pinto Girl @ Jun 18 2007, 07:03 PM) [snapback]464366[/snapback]</div>
    Except, unfortunately, Brian doesn't have a website, so that would point you to a nonexistent page. :unsure:
  8. TheAnnoyingOne
    318
    <div class='quotetop'>QUOTE(apriusfan @ Jun 18 2007, 03:18 PM) [snapback]464314[/snapback]</div>
    Get faster to 800 posts :p
  9. apriusfan
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(The Annoying One @ Jun 18 2007, 06:10 PM) [snapback]464384[/snapback]</div>
    Ahah! You mean consolidation of threads.... Yes, that might even get to 900 posts.
    For the record, I want to state my recommendation that all threads relating to the BT bracket be consolidated into one single thread. The single thread would provide a single point of reference for all subjects related to the BT bracket/plate.
  10. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    I am no longer using the BT plate (Sorry, Brian!). After much frustration, with lining up the bolts, I installed the main piece of Tom's rear brace. There was noticeable difference, right away, although, I thought it was placebo. After a few hard turns at my favorite curves, I was convinced that the improvement was definitely better. It's the BT Plate+.
    Upon removing the plate, I gave it a quick examination. The side that makes contact with the chassis was dusty, but otherwise perfect. The area where the bolts went in showed no signs of wear. The anodization was still fully intact. I can't say the same for the otherside, though. There's various scratches here and there, where I can see bare aluminum. Those scratches are completely my fault. I expected damage after hearing scrapes while taking the Prius over some rough, unpaved terrain. Those scratches are not in contact, or even close, with the chassis. I'm at work, but I hope to get some pics posted later tonight!
    I really appreciate the beautiful, simplicity of the BT plate now. Tom's rear brace was 10x harder to install due to it's size, weight, and precise points of connection. The BT plate was a 30 second job for removal, and I'm sure if I was to install another BT plate, I could get it done in under 5 minutes including jacking up the car, setting the jack-stands, removing the old plate, and installing the new one. There's, essentially, nothing that can go wrong (unless you don't have opposable thumbs) with installing the plate yourself. I'm not sure what I'm going to do with the BT plate, yet. I'm wondering if I could find someone locally to do a test with, otherwise, I'll see if my cousin wants it.
  11. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    <div class='quotetop'>QUOTE(madler @ Apr 8 2007, 02:41 PM) [snapback]419965[/snapback]</div>
    ROFLMAO!!! A procrastinator!! Man after my own heart :D
  12. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    <div class='quotetop'>QUOTE(windstrings @ May 24 2007, 03:46 PM) [snapback]449411[/snapback]</div>
    Sorry... at the time I posted that, I did not understand the geography of the underside of the car. I thought that the chassis stiffener would be something that was duplicated on each side of the car.
    I've read the entire thread now (OMG what a day!), and I think I've got it now.
  13. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    <div class='quotetop'>QUOTE(Rae Vynn @ Jun 19 2007, 07:32 PM) [snapback]464946[/snapback]</div>
    :lol: :lol: WOW!! the whole thing???!!!?!??Q$%@%^@%&@
    Bet you're gonna need new glasses!! :lol:
  14. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    <div class='quotetop'>QUOTE(Rangerdavid @ Jun 19 2007, 07:00 PM) [snapback]464953[/snapback]</div>
    and a nice nap!.... but sorry for the confusion about installing 6 of them.... only if I had 6 prius's!
  15. BT Tech
    BT Tech New Member
    885
    South Florida
    Thank you for your kind words Presto regarding our BT Tech plate.
    <div class='quotetop'>QUOTE(Presto @ Jun 19 2007, 04:16 PM) [snapback]464857[/snapback]</div>
    WOW!!! If you mean to merge all of the posts/threads into one, then there would way too many posts for anyone to read!! :)
    What you will find happen is that some of the same questions will be brought up later down the road once a thread grows old. In other words, everything comes full circle many times over.... :) :)
    <div class='quotetop'>QUOTE(apriusfan @ Jun 18 2007, 11:18 PM) [snapback]464458[/snapback]</div>
  16. alexilic
    alexilic Member
    120
    Wauconda, IL
    Wth!!! :eek:
    I don't have the patience.. what's this whole thread about? I know you want to get to 800 posts or something like that, but is there any substance?? WOW, you all are crazy..
    BTW, I think "BT PIMP" would be an appropriate engraving on the plate.. :rolleyes:
  17. windstrings
    6,280
    378
    Central Texas
    <div class='quotetop'>QUOTE(chitown guzzler @ Jun 19 2007, 08:54 PM) [snapback]464994[/snapback]</div>
    yea, but this trick last more than one night and you don't have to keep paying for it!
  18. apriusfan
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(Rangerdavid @ Jun 19 2007, 05:00 PM) [snapback]464953[/snapback]</div>
    Or, possibly a visit to the ophthalmologist for a convergent strabismus therapy.
    <div class='quotetop'>QUOTE(BT Tech @ Jun 19 2007, 06:46 PM) [snapback]464985[/snapback]</div>
    Rae Vynn did it.
  19. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    <div class='quotetop'>QUOTE(apriusfan @ Jun 19 2007, 07:59 PM) [snapback]465031[/snapback]</div>
    Fortunately, I have new glasses B)
    It was a way to fill up the time at work today. I'm between projects at the moment, and with nothing in my queue, I tend to surf my days away....
  20. BT Tech
    BT Tech New Member
    885
    South Florida
    I wish I could do that at work all day!!! :) :) :)
    <div class='quotetop'>QUOTE(Rae Vynn @ Jun 19 2007, 11:01 PM) [snapback]465034[/snapback]</div>
