BT Tech Strut Tower Brace install pictures and Text
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Gadgetdad, Mar 1, 2008.
  1. Gadgetdad
    Gadgetdad New Member
    462
    Modesto, California
    :car: If you would like to see pictures and the complete installation instructions from BT Tech, click on this: BT Strut Tower Brace Install (by Gadgetdad) - a photoset on Flickr
    This is a fairly easy installation that requires a few common tools and a torque wrench. I installed mine and took pictures in about an hour. :cool:
    The Strut Brace looks sharp and fits perfectly in the tight engine compartment. The handling feels much more responsive and precise with definite improvement in cornering and any "slalom" maneuvers. Well done, BT Technologies!
    Lee
    moderator note: Galaxee has posted a 'how to' for replacement of the PCV valve. If you are anywhere near 60k miles I strongly suggest you consider doing the PCV replacement simultaneously with the BT brace install as you'll 'be right there' and will save the cost of having the dealer do it or the frustration of doing all this disassembly again later.
    http://priuschat.com/forums/knowledge-base-articles-discussion/56852-pcv-replacement-how-photos.html
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Thanks for the great pics and comments, Lee!
  3. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    Thanks Lee. The photos with text are great.
    EDIT: Below is my Post #32 of this thread. I've included it here so that newcomers could easily see and download my Microsoft Word file of Lee's photos with text (if that's their preference).
    Lee,
    Thanks again for your flickr set
    BT Tech Strut Tower Brace Install Pictures and Text. Great stuff.
    Because I won't have internet access on the NYC street where I'll be doing my install, I've put your flickr set of 41 photos and text (plus efusco's post and your response thereto) into the attached Word file. That way I (and others similarly situated) could access it while doing the install.
    [​IMG] BT Tech Strut Tower Brace Install - By GadgetDad (Lee) v2.doc
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Well done...any photos you want me to take to add to the set when I do my install?
  5. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    Gadget..., those are great pictures. While looking at them I had an idea. It would be nice for maintenance to have the nuts on the rear end of the flanges that the bar drops down into be captured. That way, one could just pull the long bolts out from the front, and lift the bar out of the bracket and pull it forward and out of the car.
    This could be done with a block of aluminum alloy, possibly. The block would have a hex pocket, and on axis through-hole. It would also have slots to position it over the flange. Another way would be a hex through-hole, with pins at the far end to keep the nut captured.
    Ford did allot of this type of thing on the Tempo. Which made it easy to work on. I specifically remember the exhaust system had nuts with long tangs welded on. So, one could just crank the bolt and the tang would wip around till it caught on something and the bolt would unthread. I was able to replace the whole exhaust system on that car in a about an hour thanks to these devices.
  6. Gadgetdad
    462
    Modesto, California
    Thanks... I wish I had taken a close-up of the strut brace flange where the bar bolts on. Also as I was getting finished with the install, my excitement grew and I didn't take as many shots of the replacing of the various removed parts. It may be good to note any maintenance things to do while you have the covers removed... like cleaning up the debris or even installing an EBH from the top side.
    Lee
  7. jammin012
    jammin012 The man behind The Man
    510
    Cali
    Beautiful install. I started getting worried after the first few pics thinking "this was supposed to be an "easy" install?". Turns out it seams that way. Hand it to BT, that is one great looking install and goes very well with the look under the hood. If you didn't know, you could almost miss it.
  8. BT Tech
    BT Tech New Member
    885
    South Florida
    Thanks Gadgetdad for your in-depth review and for taking the time to post great pictures of your installation. Your install looks awesome!!
  9. Bobbyb
    Bobbyb bobbyb
    62
    Long Island
    Much thanks for the pics and your time .
  10. mrichman
    mrichman New Member
    Would adding Tom's front lower brace in conjunction with the BT upper front brace add rigidity over just the front upper brace? Any drawbacks to doing so (other than to my bank account)? Do the BT folks plan on a lower brace for the front or rear?
    Mike
  11. Bobbyb
    Bobbyb bobbyb
    62
    Long Island
    Good question !
  12. Gadgetdad
    462
    Modesto, California
    I don't know, but there would seem to be a point of diminishing returns! I have the BT stiffening plate installed on my Touring '07, and since adding the strut brace, the front end feels stiff enough. I do sense the back end a bit soft! The floor brace and/or Tom's rear brace may be the next way to spend $!!
    Lee:cool:
  13. mrichman
    mrichman New Member
    I thought I read that one (or both) of these pieces interfered with the stock exhaust system. Any particulars on if the floor or rear brace will fit the stock exhaust? Also, isn't the floor brace simialar to the BT stiffening plate in function?
    M ike
    Lee:cool:
  14. BT Tech
    BT Tech New Member
    885
    South Florida
    My understanding is that the toms lower front brace interferes with either the exhaust system or catalytic converter. There are some people here tht have installed it so they will be able to comment on it first hand.
    I have driven lots and lots of high performance cars and with the addition of our BT Tech stiffening plate and our BT Tech Strut Tower Brace, I think that 99 percent of the people that drive the car that have our parts installed would not feel the need to go any further.
  15. Boo
    5,051
    483
    97
    Flushing, NY
    Now you've made it harder for me to wait until the NY weather warms up some more so that I can put on the Strut Tower Brace (it's been in my closet for over a month now). But that should be real soon ... probably within a week.
  16. patsparks
    10,664
    567
    Adelaide South Australia
    Great pictures and instructions.
    I feel tempted to get a brace but I know the colour of the creek I'll be up without a paddle when my wife finds out and it isn't blue!
  17. Gadgetdad
    462
    Modesto, California
    Brace is also a safety device for the car I would wager. Forces in a head-on or lateral blow would be ameliorated and transferred to other parts of the car body rather than the precious passengers...... Perhaps that would give you a paddle on the creek;)
    Lee
  18. patsparks
    10,664
    567
    Every respect to BT Tech but I think Toyota have the crumple zone thing pretty right. I'm not planning to have a crash either.
  19. Gadgetdad
    462
    Modesto, California
    Boo, they are installing the latest shipment now. How is yours coming along?
  20. Boo
    5,051
    483
    97
    Flushing, NY
    I know. I'm being lapped left and right. In NYC, it's still too cold for my tastes to want to spend an hour outside installing the brace. But it's doable and I'm getting antsy. So my guess right now is that barring rain, the brace is going in on Thursday -- a mere 6 weeks after I received it. :)
