Bubbles in coolant system can cause P1121?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mahal, Aug 11, 2021.
  1. Mahal
    Mahal Junior Member
    16
    Panamá
    I recently (about 5 months) change the inverter coolant pump on my 2008 prius. And by month ago it starts showing the engine light with P1121 code.
    I was wandering if I didn't bleed the bubbles of the system properly, that could cause the error?
    Also have p0420 for a while, I try to clean the catalyst sensor but it shows the code again. How could I solve that and they could have any relation?
  2. ChapmanF
    18,956
    It might be possible for bubbles in the engine coolant system to lead to a P1121—I've never tried that.
    But bubbles in the inverter coolant system cause that code? No. The systems are separate.
  3. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    How many miles on the vehicle, or the upstream and downstream sensor(s)?
    Are you able to use techstream to diagnose the vehicle?
  4. Mahal
    Mahal Junior Member
    16
    Panamá
    Around 270 000 miles
    Sorry, which sensor are you asking for?
    I have carista device.
  5. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
