bubbles on fan control glass, any suggestions to fix?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by josh17, Aug 18, 2020.
  1. josh17
    josh17 New Member
    Southern California
    I'm seeing these bubbles on the glass display screen for the A/C fan settings. I've tried wiping it clean but doesn't appear to do anything.
    Any suggestions?
    49,466
    is there a factory plastic film on there by any chance?
  3. josh17
    josh17 New Member
    Southern California
    I'm like 99.99999% sure that's not the case but i'll double check. thank you for the suggestion!
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    That would have been my first guess too.
    Or a "screen protector" that a previous owner has added.
  5. ASRDogman
    ASRDogman Senior Member
    6,088
    3,273
    What are you using to clean it off?
  6. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Some detailer must have sprayed some detail stuff and it dried without being wiped. Slab some goo gone on it.
    #6 Grit, Aug 19, 2020
  7. ASRDogman
    6,088
    3,273
    I've used "Meguiar's Mirrow Glaze" plastic cleaner to clean up really dirty plastic visors for motorcycle helmets.
    Maybe this, or some other type of plastic cleaner can remove the spots.
  8. sam spade 2
    7,035
    2,788
    2017 Prius c
    A close inspection should tell the story.
    If they really ARE bubbles, no amount of "rubbing" will solve the problem.
  9. ASRDogman
    6,088
    3,273
    I mostly agree. :) If you rub enough, you'll get rid of them. But there might not be any lens left! :whistle:
