Bugs? (A/C and auto-high beams)
Discussion in 'Gen 5 Prius Main Forum' started by RogerPriusTX, Mar 4, 2025.
Tags:
  1. RogerPriusTX
    RogerPriusTX Junior Member
    57
    Dallas, TX
    2024 Prius
    I haven't toyed with the custom mode yet, but I do like the idea of having the A/C run fully... perhaps... perhaps the Auto mode can handle it.
  2. RogerPriusTX
    57
    Dallas, TX
    2024 Prius
    Noted. The 2018 Prius Prime worked like your 2017 as well. I still think it is weird to have Auto off and no indication as to whether the A/C compressor is running or not. But the compressor hurts mileage, so next time I drive, I'll make sure to expressly set the A/C off and also set the air to outside air.
  3. ChapmanF
    18,959
    Main difference with a heat pump is a reversing valve so the electric compressor can send refrigerant two different directions.
    Prodigyplace likes this.
  4. RogerPriusTX
    57
    Dallas, TX
    2024 Prius
    The manual mostly supports what you say... to quote from p362 "Using automatic mode":
    If the fan speed setting or air flow modes are operated, the automatic mode indicator goes off. However, automatic mode for functions other than that operated is maintained.
    As you will note, however, it does not mention the A/C setting in the description. It may be that the Auto does not automatically turn on A/C, and that's why it isn't mentioned.
    The manual also says that it stores the Climate settings to the key, and restores them when that key is used to unlock the car, so maybe it's never been right for me. Experiments are definitely needed the next time I drive the car.
    I will repeat: this is not a very good design. I don't mind turning off all the indicators when the Auto mode is on, but ANY change that turns off Auto should light up EVERY control so the operator knows what state the system is in.
  5. RogerPriusTX
    57
    Dallas, TX
    2024 Prius
    Okay, and how do I re-enable AHB?
  6. KMO
    KMO Senior Member
    2,026
    751
    Finland
    2023 Prius Prime
    Hammersmith already covered that - there's a config option to control whether Auto does.
    I don't use any of the online stuff, so no experience with that extra complication.
    Something of an overworn phrase now generally used in place of someone saying they don't like something - makes it sound objective. One should really have a better design with no additional downsides before making such a bold statement.
    That would just cause a different problem - you wouldn't know what was still auto and what wasn't. This version decides it's worth trying to indicate what is and isn't auto, and prefers that to showing current state of auto things.
    Personally I would prefer for auto controls to always show their current state - whether the system is in partial or full auto - I can remember what I've set to manual. That would suit me. I wouldn't claim it's an objectively better design though - just a different choice.
    I don't understand what your proposal of "don't show any state when fully auto, show all state when partially auto" would achieve. Toyota's design is more logical than that.
    Problem is the flexibility (complication?) of the system has exceeded what the physical buttons can display. You'd need more lights or multi-colour ones to fully indicate the complete state. Or do what others are doing and give up on the physical buttons.
    The A/C button on the multimedia screen is a tristate with On/Off/Auto.
  7. KMO
    KMO Senior Member
    2,026
    751
    Finland
    2023 Prius Prime
    I've no first-hand experience with this. I already posted the manual text. Maybe you missed it?
    "the low beams will remain on for a certain amount of time. After this, the Automatic High Beam system will operate."
    I would assume the "certain amount of time" is several seconds - long enough for a car to pass. Can imagine it might end up being off for longer than you want, in which case you should be able to toggle the main beam (not as a flash) to get it back on.
    So pull the stick and release to turn off AHB temporarily when it's high and you don't want it to be.
    Push the stick to get high beams if you haven't got them (either cos auto hasn't put them on or because auto was suppressed by the above), and when you bring it back, it should go back to auto. (I'm assuming that the push forward to select manual high beams will cancel the "no high beams" effect of the pull).
    A little bit too "smart" for my taste, but a reasonable way of reinterpreting the stick control in the context of auto, letting you override in both directions without changing the mechanics of the stick, trying to avoid the need to reach for the button.
    #27 KMO, Mar 5, 2025
  8. Prodigyplace
    12,710
    11,848
    Central Virginia
    since you have a heat pump, heating or AC is just a matter of valves within the heat pump. There is no separate AC compressor.
  9. Prodigyplace
    12,710
    11,848
    Central Virginia
    My 2017 was a Prius Two with a compressor. :(
  10. RogerPriusTX
    57
    Dallas, TX
    2024 Prius
    I thought only the Prius Prime had a heat pump.
  11. RogerPriusTX
    57
    Dallas, TX
    2024 Prius
    I DID see that you wrote "a certain amount of time". I'll have to see how this works. Toyota engineering does not impress me thus far.
    They should have left it as it was... the stick needs to be in the high beam position to enable AHB; putting the stick in the low beam position cancels AHB. This behavior is unintuitive.
  12. Prodigyplace
    12,710
    11,848
    Central Virginia
    Your profile lists a 2018 Prius Prime which had a heat pump
  13. ChapmanF
    18,959
    What in heaven's name do you think compresses the refrigerant to push it through those valves?
  14. Prodigyplace
    12,710
    11,848
    Central Virginia
    Either an AC compressor OR a heat pump containing a compressor & valves that can also heat the cabin. In a car with a heat pump, it is generally running when the HVAC is turned on, especially in Auto mode.
  15. ChapmanF
    18,959
    So either way one part of the system is a large electric variable-speed compressor whose power consumption likely falls in the same range of around 250 to around 2500 watts.
    In the A/C system, it'd be more surprising to see the compressor running when you're asking for heat (though it sometimes does, say when you have defog or feet+defog selected). With the heat pump it's maybe unsurprising to see it running at any time.
  16. RogerPriusTX
    57
    Dallas, TX
    2024 Prius
    Ah. I should update that; we have both a 2018 Prius Prime and a 2024 Prius.
  17. RogerPriusTX
    57
    Dallas, TX
    2024 Prius
    Well, I think that whether or not one likes turning off the indicators in Auto mode is subject.
    However, I think the current design is objectively a bad one: one never knows if the car is in full auto, semi-auto, or manual modes.
    A MUCH better design would be to have Auto either be on or off. When Auto is engaged, A/C, Fan, and air source (recycle/outside) should be controlled. As soon as ANY of these are changed, the Auto light should turn OFF, and the current state of the others should be indicated. Much less confusing and easy to understand.
    Alternatively, have some way to show "partial" auto.
  18. RogerPriusTX
    57
    Dallas, TX
    2024 Prius
    Drove the car today and paid special attention to the climate system. Comments are in curly brackets {like this}
    When I first started the car, no lights were on, and the fan was running at low speed. I set it for outside air, and pressed the A/C button twice to verify it was disengaged, per the discussion in the threads above.
    I then turn on Auto, and verified that things turned off. {well, the air source definitely turned off; I don't remember if the A/C indicator did or not; I think it did because I remember the feeling that it worked as has been described.}
    I then followed the same initial steps to put everything back in manual mode and drove to my destination, where I engaged in some work. I locked the car using the door handle.
    At my destination, I did my work for the day, and then ran an errand. When I came out to the car, I unlocked it using the door handle, got it, and started the car. The air source lights were both off, the A/C indicate was off, and the fan was on the lowest speed. Thinking that the car had reset to some partially auto mode, I again set the air to outside and pressed the A/C button twice to ensure manual mode. {I was surprised at this because I would have expected the car to leave it at the last setting. The only thing I can think of in hindsight is that I was using the lock/unlock function of the door handle instead of using the "lock" and "unlock" functions on the key. It is not clear from the manual if using the door handle counts as "unlocking the door with the key". I should have tried using the key, but I'm so used to using the door handle that I forget.}
    After getting back out to the car after the errand, I found the same issue when I started the car. The fan speed was where I had left it, but the air sources were BOTH off, and the A/C light was off. I put in back into fully manually mode again.
    For what it's worth, I think the car has been starting up in partial A/C mode, with the A/C light off, but the A/C compressor engaged, and the air source also in auto mode, since it's light was off. The air seemed to be more like outside air that A/C air today. But why it keeps starting up in that mode is uncertain.
    It wasn't dark when I was driving, so I didn't get to play around with the AHB temporary disabling.
  19. KMO
    KMO Senior Member
    2,026
    751
    Finland
    2023 Prius Prime
    I never have a problem, but that's probably because I just leave it in full auto. And you always know when it's in full auto - the AUTO light is on.
    The only ambiguity is between full manual and partial manual. Even then, I tend no know where it is because I set it. The visual feedback is a reminder - it's not vital.
    If someone else was changing your controls regularly, I guess that would be annoying. And whatever per-user memory function there is with the key could well count as that sort of annoying - I've never used that. Mine just remembers the last setting. I'm conscious of put the climate back into full auto before leaving so I'm not leaving in a silly mode for the next start-up - something that's caught me out before.
    To you, maybe, but I don't understand what you're suggesting.
    Are you suggesting ditching partial auto, so as soon as you change anything it's fully manual?
    #39 KMO, Mar 6, 2025
  20. Prodigyplace
    12,710
    11,848
    Central Virginia
    Based on my former Gen 4 Prius, I suspect the AC reacts differently depending on drive mode. In Eco mode, for instance. it always put the HVAC in Eco mode when starting the car. On the Gen 4, the AC light lit in auto mode but I do not see that lit on my Gen 5 HEV Camry.
