Build a "battery cart" to charge our 2015 PiP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by wsalopek, Nov 29, 2019.
  1. Rob43
    Rob43 Senior Member
    1,373
    1,048
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    As a PriusChat 240v adapter / extension cord builder, I'd recommend a 9 AWG extension cord at 150 feet long.
    My proposed cord would yield roughly a ~2.35% Loss, this falls within the 3% rule of acceptable extension cord loss. How's your personal DIY skills ? I'd recommend that YOU build it. A guess on cost with you doing things would be roughly ~$160 shipped.
    If your plan is to leave it in place, then this will work well. If your plan is to roll this cord out everyday & then when done pull it back in; then I'd reconsider things because that would be a PIA after awhile.
    WARNING: Extension Cords | PriusChat
    Rob43
    #21 Rob43, Nov 30, 2019
    MTN and jerrymildred like this.
  2. wsalopek
    wsalopek Junior Member
    70
    Morro Bay, CA
    2015 Prius Plug-in
    The cord will stay out all the time...no need to roll it up...it would be out of traffic and out of sight and 99% in the shade as well.
    Yep I hear you guys about the needed gauge, etc. Sounds like 10 or even 9. Would the needed gauge do down (skinnier) if I was able to access 220 volts?
    And what would be running thru the cable at 110 volts? Would it be a relatively constant 15 amps? A little less? I'm guessing that 110 volt outlet is a standard 15 amp circuit.
    Thanks...
  3. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    Can you access a 240 volt outlet ? That would be great if you could, then I'd recommend a 10 AWG extension cord, your loss would be about ~1.46% at 240v using 11.7 amps over 150 ft. BUT, you would REALLY need to implement something like a lock box on the 5-20R end so no one could ever access your 240v cord. Cost is still roughly the same.
    EDIT: Based on safety factors & the fact that this is a "Condo", I'm going to recommend a 120v line for your extension cord. There are just too many risk factors here that you might not have control over unlike someone with a single family home on their own private lot. If anyone ever accidentally got a hold of your 120v cord, it would not likely be a problem; but if someone got a hold of your 240v cord, it could be Bad. So after some thought, be safe-ish & go with a 120v cord if you go ahead with any of this.
    Rob43
    #23 Rob43, Nov 30, 2019
    MTN and fuzzy1 like this.
  4. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    The US electrical code is that for extended use, a 15 Amp Breaker should only have 12 Amps running through it. 5.5 hours is certainly extended use. 240 volts wold be the same Amps, but half the time, so you want the same gauge.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    I agree, 130 feet is WAY too far for an "extension cord".
    And that is sure not to fly for very long anyway because YOU won't be paying the bill for the power used.
  6. fuzzy1
    10,344
    As the links in post #8 point out, if you use existing state law for force this issue, then you are agreeing to pay the power bill.
  7. wsalopek
    70
    Morro Bay, CA
    2015 Prius Plug-in
    Thanks for that Rob...good point.
  8. wsalopek
    70
    Morro Bay, CA
    2015 Prius Plug-in
    Sam I'd put some sort of power use meter in line with the extension cord...weatherproof and rated properly...something like this (but not necc this one):
  9. Rob43
    Rob43 Senior Member
    1,373
    1,048
    2013 Prius v wagon
    If you plan on building a 10 AWG or better 9 AWG ~130 to ~150 ft long extension cord for 120v operation, send me a PM for a build list.
    Rob43
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,146
    Tampa, FL
    No, the current would remain the same, so the wire gauge would also need to be the same. And if you sprang for an L2 EVSE cable and had a 220 outlet for it, the current would actually increase. Rob's adapter would keep you at the original current while letting you charge twice as fast with twice the voltage assuming a 220V outlet is in reach.
    Input current on the stock EVSE is 12A. That's because most 120V outlets are 15A and should not be run at more than 80% of capacity, which is 12A.
    Rob43 likes this.
  11. Griogarach
    Griogarach New Member
    27
    16
    Germany
    Charging carts are freely available to buy in the UK and Germany.
    Breakdown services can have had them for a while now with enough capacity to get you underway.
    Larger units can be hired for events and are available both with a cable to run mains power, or as a battery back that is taken away and charged when needed.
    I am not allowed to post links as a new member, but any search engine has results aplenty.
    Search "mobile EV charging"
  12. fuzzy1
    10,344
    You should be over that new member limitation now, with five posts.
  13. Griogarach
    27
    16
    Germany
    Yeah, I will be now. At that point all the posts were awaiting approval at the same time.
    It's quite frustrating - If the posts need approval, then it's just as easy to allow the attachment of a link and approve that link at the same time.
  14. MTN
    MTN Active Member
    306
    276
    SB, CA
    Hire an electrician to put an outlet in the garage. Tell the HOA they can stuff it - er, refer to the appropriate CA Code section. No extra insurance should be required for a standard 120v outlet. Most garages have them. Pay for the install by a licensed electrician and the HOA can't stop you. This would likely follow code a bit better than a 150' run of extension cord. That would be more likely to trigger insurance issues, I would think.
    Rob43 likes this.
  15. Elektroingenieur
    2,515
    3,281
    Three Touring
    I don’t think this is quite how it works. The law I mentioned isn’t carte blanche; associations can still require owners to apply for permission and to follow “reasonable restrictions,” including architectural standards. They just can’t have a blanket policy, formal or otherwise, against installation of EV charging equipment.
    If just reminding the association of the law doesn’t get things moving, I’d think it would be best to speak with a lawyer familiar with the Davis-Stirling Act, the California condominium law, before resorting to self help. The law allows courts to award a penalty and attorney’s fees to owners who prevail in a lawsuit, but experienced counsel may be able to help convince an association board to go along, without the need for litigation.
    The exemption from the insurance requirement (Cal. Civ. Code § 4745(f)(4)) applies only for an “existing . . . power plug [sic].” (I assume “receptacle outlet” was meant.) If an electrician has to install anything new, I think the owner has to provide insurance, which seems fair.
    #35 Elektroingenieur, Dec 4, 2019
    MTN likes this.
