Building oil pressure after a service ?
Discussion in 'Gen 3 Prius Main Forum' started by Juntuner, Jun 25, 2019.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    This is the second instance of oiling armpits this week:LOL:.
    Sounds like this occurs more than I thought :whistle:.
    Or more than each of us individually will admit to(y).
  2. ChapmanF
    19,014
    I figured since the Gen 3 filter doesn't even have an outside, the idea of trying to fill it before installation would be humorous at a glance.
    Raytheeagle likes this.
  3. ASRDogman
    ASRDogman Senior Member
    8,062
    4,086
    You could just fill the housing with the filter installed and let it soak and absorb the oil,
    then pour the remaining oil back in the bottle or in engine.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Yes, I suppose the horizontal filter could add a few extra levels of difficulty. One more item to put on my list of reasons to keep the '07. I wonder if there is a market for an adapter? Something similar to the oil cooler adapters used on trucks, where it allows a filter to be mounted vertically.
  5. ASRDogman
    8,062
    4,086
    It really doesn't matter. ALL engines run a few seconds until oil pressure builds up.
    And there is oil left on the bearings and would have to run for a while before damage is done.
    I've always filled the spin on filters with oil and let it soak in then fill again until it more or less stops
    soaking up the oil. Any oil spilled is just an ounce or so.
    AzWxGuy and Raytheeagle like this.
  6. Mendel Leisk
    42,335
    ^ I really like that first sentence. :)
  7. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Not enough to select “like” though:p.
    RMB and Mendel Leisk like this.
  8. ASRDogman
    8,062
    4,086
  9. Mendel Leisk
    42,335
    Second and third sentence too: approved! (y)
    RMB and Raytheeagle like this.
  10. ASRDogman
    8,062
    4,086
  11. bisco
    52,839
    wait until you get to 400,000 km :cool:
  12. Mendel Leisk
    42,335
    I'll be long gone before that happens. :coffee:
    Raytheeagle and bisco like this.
  13. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Can you transfer your PC “likes” onto my account when the day comes? Thanks.
  14. Mendel Leisk
    42,335
    You're likes per post ratio is almost 1:1. (y)
    RMB, Grit and bisco like this.
  15. bisco
    52,839
    let's not go there...
  16. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    Isn't the engine start spin-up sequence done with MG1 sort of under reduced pressure or stress since no combustion is occurring yet? There is the stress of compression, but with the modified Atkinson cycle maybe that is reduced also. If the oil gallery is indeed dry after an oil change, I would think these few seconds of spin very near idle speed, plus the oil film on everything, wouldn't pose a problem for increased wear. I can't explain the noise that is heard though. When I was doing the oil changes on my Gen II I may have heard a brief half-second hiss during the start sequence on the first start after a drain and fill. We need an oil prime button perhaps.
  17. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    But I’m th typical American, Im never happy w
    Ith enough.
    Raytheeagle and Mendel Leisk like this.
  18. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    A person could go overboard and install a one quart accumulator system. Install it with an isolation valve, so the valve can be shut while the engine is idling. Change the oil and filter, open the valve to let the accumulator pressurize the oil system and crank it up. These systems work great on cars that operate while under risk of losing oil pump suction/flow.
    Only disadvantage would be instant dilution of the new oil.......
  19. ASRDogman
    8,062
    4,086
    MONEY! And they aren't needed for a car for the average user.
  20. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Awww, jeez. Let me have my fun, lol. The average user doesn't disconnect COP wires, fuses, fuel pumps, etc so they can crank the engine to "prime" the oil system either. A 3 quart accumulator system is only $200. Certainly that's less expensive than a new engine, which would be needed after about 5000 oil changes with "dry" startups....:D
