Building stationary power system using old HV packs
Discussion in 'Gen 2 Prius Technical Discussion' started by Dxta, Sep 30, 2018.
  1. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I have some Highlander hybrid, Camry, and Prius battery packs in my shop for some months now.
    I'm just thinking if it's possible, to use those packs as a storage system for energy, since in my location, power disruption has being a big problem over here.
    I know Musk's has something maybe similar setup in a region in Australia, providing power to a community.
    Has anyone ever done this before using used HV packs?
    Could you PLE share your experience? Would want to do same too.
    Dxta
  2. brdmb
    brdmb Junior Member
    17
    Ohio
    Here is some good reading on how folks have used the Prius (and its battery) for home power backup. Lots of good information on this site!
    The Correct Answer
  3. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Thanks a lot! Would check em out
  4. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I have just gone through that site right now. It doesn't say much about what my thread is talking about.
    The site is dedicated to using a Prius as a generator.
    Dxta
  5. padroo
    padroo Senior Member
    2,763
    2,253
    I don't think it would be worth the trouble and how would you charge them back up?
    Portable generators are a pain but they do work. I have a 20KW Kohler whole house generator that starts automatically within ten seconds after power goes out.
  6. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Is your generator "green enabled"? No emissions generated?
    I intend to use a solar panel, or just get a custom charger that could charge any of those.
  7. brdmb
    brdmb Junior Member
    17
    Ohio
    It says everything you'd need to know to be able to find a proper inverter that would allow you to supply AC loads from the DC battery packs you have while providing isolation. (The load side of your question.)
    The only piece you would have to figure out is the charging side, which would not be trivial with the battery packs operating at over 200 V DC.
    Be safe.
  8. bisco
    52,896
    how does musk recharge the power wall, solar?
  9. Leadfoot J. McCoalroller
    8,293
    7,809
    Pennsylvania
    2018 Prius c
    What an opportunity! The only thing that has prevented me from building something like that was mostly the lack of scrap hybrid cars... Hmm...
    You can possibly build yourself a great setup. Put a few batteries on a bus, put inverter(s) on it to supply domestic power, then put a charger on the bus and run it when grid power is available. You might get it all to balance so that you can enjoy constant power, even with low average grid availability.
    Be careful and have fun!
    Dxta likes this.
  10. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    I don’t think the battery’s in Toyota’s would make a very good Backup for your home power going out. It was not designed for that and 6.5 amp hours won’t go far beyond some light bulbs.
  11. Leadfoot J. McCoalroller
    8,293
    7,809
    Pennsylvania
    2018 Prius c
    No, but when you're in Lagos and the grid is only available a random 9 hours per day and you happen to already have some big batteries from cars? I'd be pretty motivated to solve this puzzle myself.
    davecook89t likes this.
  12. padroo
    2,763
    2,253
    When you are in the dark and your sump pump is overflowing, and your freezer is thawing, who cares about being green.:)
  13. Skibob
    2,912
    1,505
    Northern California
    Having battery packs are cool but i thought most solar equipment used 24 and 48 volts thru deep cycle batteries that tend to not throw off heat. How are you going to keep the battery packs from overheating under load? How are you going to convert 240 volts DC to 115?(220?) AC?
  14. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    The modules only have around 6amp hours of total energy when new. (6.5)
    That means you can run a 6 amp load for 1 hour.
    Or a 1 amp load for 6 hours.
    That is not much power.
    Skibob likes this.
  15. bisco
    52,896
    but he has lots of highlander, camry and prius packs. that's a lot of power.
  16. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    But they are likely quite dissimilar.
    Dissimilar capacity.
    Dissimilar discharge rates.
    Dissimilar charge rates.
    Dissimilar internal resistance.
    Dissimar internal resistance.
    This can cause big problems
    You would need to do some serious monitoring of things if you. Would be b stbto stay in the middle of the SOC.
    That said, anything is possible.
    If you were stuck in aremote area and these were your only means for power, you could definitely make it work.
    Skibob likes this.
  17. Skibob
    2,912
    1,505
    Northern California
  18. Skibob
    2,912
    1,505
    Northern California
    Anything is possible, given enough time and money. If you are going to go to the expense of building a solar/grid charged UPS you would be better served by some Golf cart Batteries.
    brdmb likes this.
  19. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Yes, the Powerwall can charge from solar. Fully off grid is not technically supported at this time, though. As backup for outages, no problem and solar will continue to charge.
  20. bisco
    52,896
    so the same for toyota batteries i assume.
