Burned Rubber Smell & Banging under hood
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Tam2, Sep 17, 2025.
  1. Tam2
    Tam2 New Member
    Fort Wayne, Indiana
    First time Prius owner here. I just bought a 2012 Prius v, and as I was driving it home all of a sudden a loud banging/thunking noise started under the hood and then a burned rubber smell started. I turned the ac off and the noise and smell stopped immediately. Any ideas? Is it safe to drive for a few weeks until I can get it fixed?
    For the record, it has about 202k miles on it.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,049
    6,924
    Texas Hill Country
    I would check the radiator fans first to see if they are hitting something or burning up. Typically they only run constantly with the ac on.
    Next is the electric ac compressor. Run it and see if the noise is there.
    I would not drive too much if a radiator fan is bad since it can try to run with high coolant temps, usually in traffic on very hot days.
    If you do see the engine temperature light come on, shutdown as soon as it is safe. These cars love to blow head gaskets and don't need overheating to do it.
  3. Air_Boss
    Air_Boss Senior Member
    4,248
    1,195
    New Yawk
    If it wasn’t a Prius, it sounds and smells like a fraying belt or frozen belt tensioner or both…
  4. Mendel Leisk
    42,305
    Keep an eye on the coolant level in the engine coolant reservoir. It’s the larger of two (pink) coolant reservoirs, at the passenger side fender in engine bay.
    any gen 3 Prius or Prius v for sale, odds are good it’s got a failed head gasket, with symptoms possibly masked by stop-leak product in engine coolant.
    was the “banging and thunking” during a cold-start, say in the morning?
  5. Tam2
    Tam2 New Member
    Fort Wayne, Indiana
    No, I was literally driving it. Had been driving it for about 20 minutes and it was in the afternoon on a mid 80° day.
    See that was my first thought until I learned there’s no serpentine belt
    Guess I’ll drive around the block a few times lol
    #5 Tam2, Sep 18, 2025
  6. rjparker
    11,049
    6,924
    Texas Hill Country
    Just open the hood. Start the car in Ready and immediately push the ev button to keep the engine off for a few minutes. Stand on the passenger side and observe under the hood as someone turns on the ac.
    The radiator fans directly behind the radiator will come on and make a medium whirling air moving sound.
    The ac compressor down low on the front passenger's side will come on as well and make a low motor running sound.
    Both are normal and the ac in the cabin should be blowing cool and progressively colder air.
    Any banging and clunks should be obvious as to their location.
