Burning 3.9qts every 1000 miles
Discussion in 'Gen 2 Prius Main Forum' started by Fatmatt86, Dec 5, 2018.
  1. Leadfoot J. McCoalroller
    8,289
    7,802
    Pennsylvania
    2018 Prius c
    Fatmatt86 likes this.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,104
    6,967
    Texas Hill Country
    I would say yes you are correct sir!
  3. theory816
    theory816 Member
    112
    23
    It went out with a bang. 330k miles is impressive.
    #263 theory816, May 31, 2024
  4. oschn
    oschn Junior Member
    26
    Over half a million km! What a great story. So my Prius should have another 30 years in it!
  5. pasadena_commut
    pasadena_commut Senior Member
    3,065
    951
    Southern California
    Any obvious signs of what might have precipated the rod throw? For instance, a hole in the oil pan or evidence that the oil pump failed?
  6. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    Well, enjoy your new car!
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Well, now you know! :D Sounds like you had a good run. It lasted longer than I thought it would.
  8. Toy Engine Builder
    Toy Engine Builder New Member
    When you use Shell Rotella 15W-40 do you eventually get any engine timing codes like P0011 or P0012? I'm looking to switch but I'm wondering how strict the ecu is.
  9. Leadfoot J. McCoalroller
    8,289
    7,802
    Pennsylvania
    2018 Prius c
    The ECU won't care about rotella, but if your car burns oil, burnt rotella can ruin your catalytic converter due to its sulfur additives. Might not matter for inspections where you live.
