Burning 3.9qts every 1000 miles
Discussion in 'Gen 2 Prius Main Forum' started by Fatmatt86, Dec 5, 2018.
  1. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    You REALLY should put a :ROFLMAO: after your comments like that.
    Somebody might take it seriously.
    Prius Rising, Fatmatt86 and Skibob like this.
    52,855
    i know, i'm a bad boy:oops:
  3. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    Sorry for not responding to any messages. I guess I thought I would get an email after every comment. But guess since I'm linked to Facebook it doesn't send them. Anyhows, just to clearify, I am not the original owner so I haven't a clue if the oil was changed routinely or not. I have had this Prius for close to 2 years next month, and the lost oil has been there from the day I got it, so for those who think the engine is shot, or will fail shortly, I still think there is Alot left in this old thing. I've had my share of clunkers in the past, and this is not one of them. I can deal with a few extra oil changes. Just to let y'all know, the car is still running and I've added a few more miles to it since I posted before:
    240715 added 1qt Pennzoil 5w30
    241060 out of oil
    241300 oil change at Napa Alta mere
    242124 out of oil
    242200 topped off oil at Napa Alta mere 3.9qts?
    242997 out of oil
    242302 Race pro senthetic 2qt
    243507 out of oil
    243568 added petromerica 2qt semi senthetic
    244596 added 2qts of Petro
    245000 12/30/18 replaced auxiliary battery.
    245700 out of oil
    245714 added petromerica 1qt
    I am currently at 246,232 miles today.
    I would like to add that the vehicle does not have any signs of leakage, no puddles, no smell, no nothing. It drives well and everything. Just had an excessive oil problem. I would also like to note, that when the out of oil light comes on, there is a little over 1qt-1.25qts in the engine. I have never run it dry as to speak. I have tried using 10w40 and when the engine turns on while idling, it is a little rough and jumps. I haven't tried any other grade, but the 5w30 seems to be what this engine likes the best. So if anyone else has any constructive advice, I'd love to hear it. I'll check back here more often from now on... Thanks
  4. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    As it’s been said, there is no low oil light. What you see is the low oil pressure light. It will be interesting to see how long the engine lasts. Please keep us informed and let us know what the mileage is when you throw a piston.
    Prius Rising, SFO and Raytheeagle like this.
  5. Aztechmaster
    Aztechmaster Member
    38
    76
    S.D.
    Look for my post on this, it may be of some help.
  6. Rmay635703
    Rmay635703 Senior Member
    2,702
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    I would recommend a little 2 cycle and mmo in the gas tank. I would also run Run e15 to help keep things cleaned out.
    Try 5w40 or 10w30, if it runs rough on those grades add mmo to the gasoline.
    It’s running rough because it’s chugging oil.
    There may be life left but I would just use cheap heavy oil.
  7. ETC(SS)
    7,555
  8. sam spade 2
    7,035
    2,804
    2017 Prius c
    Letting it get down to the "low oil pressure" point that often certainly is not good for it.
    The only good news I see in this story is:
    If you are adding almost 4 quarts every 1000 miles, you theoretically should never have to do an actual oil change.
    My guess is that it will die completely before you really need a new oil filter.
    davecook89t and Mendel Leisk like this.
  9. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I didn’t see a compression test, seems like engines should be available at the junk yard, cheap. If you want to go that route.
  10. Andyprius1
    2,327
    859
    Cool CA
    I see no more comments from the OP.
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I have to say...I don't think the odds are forever in your favor here.
    I pretty much think...your engine is shot.
    Without being too snarky, I would ask, if you discover the vehicle is burning Oil at very high consumption rate? Why would you wait until the vehicle threw a red triangle of death code? Until it was "empty"? The common reaction is to check it more often and NOT let it get low.
    Because if you had a problem, each time the engine is run down to that level of emptiness, it only exacerbates the damage.
    Given your symptoms, and description of the problem and reaction....I don't see how your engine could NOT be shot.
    But?
    I could be wrong.
  12. padroo
    padroo Senior Member
    2,763
    2,253
    It would be interesting to see the compression numbers. I wonder how much blowby it has
    Engine Blowby
  13. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    Hello.
  14. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Linked here: Oil consumption...what I did to correct it.
    @Aztechmaster Since you haven't updated the above thread in some time, can you please post your current rate of consumption?
    And not to mix up threads too much, but I've read that modern ATF doesn't have large quantities of detergents like back in the day.
    Any truth to that, or additional thoughts?
    Prius Rising and Fatmatt86 like this.
  15. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
  16. The Electric Me
    9,083
    5,801
    That's good to know. However, you're still replacing and adding oil at a alarming rate.
    If you are losing oil at the rates you are saying, despite not seeing a leak or smelling anything..the oil is "going somewhere".
    IMO if it's not a leak, the other alternative is the vehicle is burning the Oil.
    If that is the case, I would think you'd see significant smoke.
  17. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    This thread is awesome............
    If the car burns through a quart of oil about every 250 miles....that's one quart of oil for every 6 gallons of gas. (24 quarts of gas + 1 quart of oil) Ah - ha.....you have a 1.5 liter 2 cycle engine!!! No,, actually that's even more oil than most 2 cycle engines mixtures...
  18. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    I’d be about the right mix to run this:
    Hard to believe an engine will ALLOW this condition to occur:eek:.
    Fatmatt86 likes this.
  19. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    No smoke, no smells. Gonna try a compression test next and will let y'all know.
  20. Mendel Leisk
    42,347
    Huh, I was thinking the same thing, lol.
    Try a leakdown test too.
    This image keeps popping into my head, from video 1 of @Ragingfit 's engine swap, cleaning out the hatch:
    Be prepared!
    #40 Mendel Leisk, Jan 28, 2019
    SFO and Fatmatt86 like this.
