Burning 3.9qts every 1000 miles
Discussion in 'Gen 2 Prius Main Forum' started by Fatmatt86, Dec 5, 2018.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    I'm still thinking oil is being pulled through the PCV system. The underside of the valve cover should have a large baffle (piece of sheet metal) that blocks a direct path to the pcv fitting. Wondering if this baffle is missing. An oil catch can would provide an answer to that question.
    Matt's previous post about running dry and knocking may make it a moot point.
    Fatmatt86 likes this.
  2. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    do they still sell STP??
    Samuel Williams Jr likes this.
  3. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    I have changed the OCV valve, president seem to make no difference. Im gonna look in more on the PVC system, and as far as this car being a death trap, it has been this way since I bought the car almost 3-4 years ago. This car has only left me stranded once in all these years, and that's because the inverter coolant pump went out, and this forum helped me find the solution and even got me in contact with someone who made the repair. Love this Forum
    #143 Fatmatt86, Mar 12, 2021
    Aaron Vitolins and SFO like this.
  4. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    Okay so these are all the codes that popped up. I took the fuel injectors, coil packs, spark plugs, throttle body, and all the air hoses and MAF sensor and cleaned the crap out of them all. One of the fuel injectors had a broken O ring as well so I ran up to o'reilly's and bought a new o ring and put everything back together and by golly the engine sounds and feels 10x better and is so quiet and purrs like a kitty. I reset the codes, I'm sure a few will pop back up related to the coolant stuck (which I changed the part) and I expect the CAT code to pop back up, but overall cleaning the air hoses and fuel injectors and sensors made a huge difference. I'm really shocked on how smooth it rides now. I bought a new thermostat, but that's for another day.
    Aaron Vitolins likes this.
  5. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    Currently these are the only two codes that have came back up since I cleaned all the parts. I changed the spark plugs and the coil packs last year. I have also changed this part less than 6 months ago. I might change it again as this code keeps popping up with the coolant control stuck. I do know my heater doesn't blow as hot as it should. Screenshot_20210312-082648_FIXD.jpg Screenshot_20210312-082818_Google.jpg Screenshot_20210312-082648_FIXD.jpg
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    And so.......how much oil does it burn / lose now ??
    About the same, I bet.
    AND......driving a car with that many problems ON THE HIGHWAY is not a smart thing to do.
    It just isn't.
  7. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    All right, so I just had the sparks plugs and coil packs replaced as well. All of the spark plugs were drowned in oil, and two of the coil packs were broken, as well as a broken O ring on one of the injectors. reset the codes and have drove 566.8 miles and everything runs a whole lot smoother now, also getting better gas mileage. I have checked the oil and surprisingly it isn't low yet??? Current miles are 295,592. See you in the 300k club, then off to the 350k and 400k club. This engine is strong and built stronger than all of your other Prius engines.
  8. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    These are good right?
  9. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    If all that oil was in the spark plug wells on the porcelain side of the spark plug before you removed them, you have a leaking gasket on the valve cover. You will need to replace that gasket (or have it replaced) otherwise you will just foul the coils again.
    Did you clean out all the oil in the spark plug wells before changing the spark plugs?
    Fatmatt86 and kenoarto like this.
  10. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    Yes the spark plug Wells have all been cleaned out. I believe the excessive oil in the wells was caused by me not using a funnel when adding oil. Going forward I will be using a funnel and will check the spark plugs and coils in a month
  11. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    I'm up to 299,598 miles on it now. Fastly approaching 300k
    Bunce and Mendel Leisk like this.
  12. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    2 and a half years later and still running strong. I'm up to 299,598 miles on it now. Fastly approaching 300k
  13. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    Still running strong 2 and a half years later. I'm up to 299,598 miles on it now. Fastly approaching 300k
    SFO likes this.
  14. Fatmatt86
    Fatmatt86 Member
    85
    93
    Fort Worth
    Haven't thrown a piston yet. 2 and a half years later and I'm up to 299,598 miles on it now. Fastly approaching 300k. Plenty of life left in her
    TMR-JWAP likes this.
  15. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Gen 2s are tanks!!
  16. sam spade 2
    7,035
    2,804
    2017 Prius c
    You can repeat that over and over a hundred times and it won't make it any less a case of just pure dumb luck.
    You already have a good head start on the 100.
    I hope it doesn't decide to lock up on the freeway so that you DIE as a testament to how unwise this little adventure really is.
    Not to mention how irresponsible it is to be spewing out that much oil onto the roads.
  17. Samuel Williams Jr
    246
    Dayton NV
    Is this for real?
  18. fuzzy1
    10,717
    I wonder how many of us have managed to survive engine "lockups" or stalls or fuel starvation or other failures on cars in motion on the highway, so many times.
    Passenger car engines are nowhere near the reliability levels of commercial aviation power plants. Sudden failures to propel are quite common, vastly exceeding the known highway death rate.
    And even then, a large majority of the deaths are the result of other driver misconduct, not from some sort of mechanical failure.
  19. Rmay635703
    Rmay635703 Senior Member
    2,704
    1,730
    Somewhere in Wisconsin
    2013 Chevy Volt
    Tiny fists of furry don’t fade me mow
  20. Moses Bruh
    Moses Bruh Member
    97
    29
    What a beast, still surviving and still burning 3.9 qts of oil??? Im sure everyone wants updated photos haha!
    Limey Geoff likes this.
