Burning coolant need suggestions
Discussion in 'Gen 2 Prius Main Forum' started by oil_burner, Nov 1, 2018.
  1. oil_burner
    oil_burner Active Member
    249
    126
    Hi all, my 2006 has been well maintained with 268,000 miles starting to have some issues. Recently I noticed a very strong coolant or burning sweet odor coming from the exhaust. The car also uses a bit of oil about half a qt each 1000 miles. The oil is not milky so I suspect possibly a very slow leaking head gasket. The coolant levels seem to not be dropping or dropping so slowly I have not noticed yet. There are no leaks under the car the smell is coming directly out of the tail pipe.
    I'm curious if there are any other areas that could be leaking coolant into the intake that I may not be aware of. Could the coolant hose into the throttle body leak into the throttle body itself?
    Also wondering how involved it is to swap an engine myself. I have a fair bit of experience turning wrenches but I am limited to working in a garage with jackstands, can the engine be pulled from the top or does it have to come out the bottom? The rest of the car is in great shape so if I could fix it for under $1000 I would like to keep it.
  2. Mendel Leisk
    42,289
    This involves a Prius v engine swap, very similar to 3rd gen, but I think the main principles are very similar. In a nutshell, he disconnects the passenger side motor mount, and the transaxle connection, then pulls it out through the through the top with a chain hoist.
    Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v | PriusChat
    There's a few peripheral items, water pump and intake manifold, that he removes prior to engine removal. He also struggles for quite a while to get the EGR system off (not present on second gen), and I'm pretty sure that could have been left till the engine was out. Similarly with the exhaust manifold: he loosens all the bolts on it, then as he's lifting the engine out realizes it's still attached, and cleared ok.
    It's hands down the best video I've seen, lots of good advice, not a slick Toyota video, the real McCoy. Kudos to @Ragingfit .
  3. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Honestly I don’t know why anyone would not want to drop the engine down rather than up. I did my Nissan Sentra that way and had no problems. Hardest part was getting the front of the car high enough to clear the transaxle. Layed it on a sturdy piece of cardboard and slid it out. I did use an engine lift to lower it to the ground. You will need to borrow or rent one of those.
  4. oil_burner
    249
    126
    I don't have jackstands or a jack tall enough to lift the car that high. Tallest I can lift is about 20"
  5. Skibob
    2,912
    1,505
    Northern California
    Once the transaxle is on the ground the front of the car is much lighter. I believe I used stacked 4x4’s to get the height Just don’t go under the car like that. Or you hook the engine lift to a sturdy part of the car and lift it that way. 2 guys could probably lift the front of the car without the weight of the transaxle in there.
    #5 Skibob, Nov 1, 2018
  6. ski.dive
    ski.dive Active Member
    967
    247
    Hutchinson Island,FL. Mt. Snow,VT
    A 12 year old Prius with 268,000 miles and a possible BAD HEAD GASKET=
    Time to get rid of it!!!
  7. Skibob
    2,912
    1,505
    Northern California
    He’s 30 and might not have a lot of money. You are retired and own 2 houses. Can’t you remember back 40 years ago when you were that age? Give the guy a break.
  8. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
  9. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Oops, OP in Canada. Although I’ve found some listings there in the past...
  10. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    I was just in your situation (loosing coolant due to a bad head gasket @ 243,000 miles), I had some spare time and bought a head gasket set and put it in myself.
    It took me about twelve hours total and I'm sure the additional knowledge I gained doing this project will come in handy down the line.
    m.wynn, 05PreeUs, Raytheeagle and 2 others like this.
  11. oil_burner
    249
    126
    Did you have to break the timing chain to remove the head? I could replace the gasket but i have lots of spare time coming up and I think a lower mileage engine swap would make more sense. It's not so much about the money, I just have this car setup nicely how I like it with good hid head lights, tow hitch, spare winter tires on rims. I recently put in new shocks and springs and still gets great mileage no battery issues at all. Would really hate for the car to go to a waste if I could get it repaired for about 6-800 and a bit of wrenching.
  12. IMkenNY
    477
    303
    Tropical Buffalo NY
    Four Touring
    Timing cover has to come off, there is plenty of room to work in passenger side wheel well once motor mount is removed
    The timing chain comes off easily in one piece and I found my chain, guides and tensioner all to be in excellent shape.
    The colored chain links made timing the cams to crank very easy, it was a nice engine to work on.
    Skibob and m.wynn like this.
  13. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    ANY time you open an engine the potential for a problem exists, same is true to swapping an engine with experience (be it used, "rebuilt" or whatever) into a vehicle.... you NEVER REALLY KNOW what you are getting.
    An engine that fails a leak-down test is due for replacement or rebuild, while a leaking HG is nothing serious IF AND ONLY IF the engine was never overheated or run with low coolant. If neither can be confirmed, plan on a new head, but only after a leak-down test shows the bottom end is serviceable.
  14. oil_burner
    249
    126
    Thanks, I do have the equipment to do a leakdown so I'll give that a try first.
    Raytheeagle likes this.
  15. oil_burner
    249
    126
    Ok now I have a bit of a conundrum. I pulled the plugs and cylinder 1 was quite bad, the plug was oil fouled and lots of deposits on it. The rest looked ok, I did a leak down and all cylinders measured well, the worst was #1 at 10% but the rest all between 4-6%. No bubbles at the filler cap for the coolant. So what now? Should I try a piston soak in #1…?
  16. oil_burner
    249
    126
    Here are the plugs which have about 40k on them.
  17. Skibob
    2,912
    1,505
    Northern California
    Why just cylinder #1? If your going to do a piston soak you might as well do all 4.
