Burning oil at same rate regardless of oil thickness --- What does it tell us?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AllenZ, Dec 13, 2013.
  1. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    Just passed emission test.
  2. frodoz737
    frodoz737 Top Wrench
    4,699
    2,497
    33
    Good for another year.
  3. AllenZ
    640
    63
    Chicago
    If it does not break now, it may last more than one year I believe. Let's see.
    I've saved about $8000 on gas just by switch to this car 100K miles ago. One more year, the whole car will be free, including all the maintenance money (~$1000), even tax, that I paid. May I even say that one year from now, it will start to "make money" on my initial "investment"? :)
    Can't complain on such a great car, even if I have to replace a new engine, at the cost of less than one year's gas saving!
  4. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Hi Allen. I've heard it said (meaning I don't have 1st hand experience) that bad oil control rings often cause oil consumption that is relatively independent of the oil grade used. The rational is that with thicker oil the rings are wiping a thicker oil film, so that tends to negate the natural tendency for thicker oil to be more resistant to getting past the rings.
    So I think the piston soak idea is definitely worth a try. Do some research to find the best product (autorx or kreen or MMO for example) and remove the spark plugs and give it a soak. I'd try gradually adding it in over a period of a few days to give it a real good soak. Remember to turn the engine over without the plugs inserted to let it expel any excess crude before replacing the plugs. You might need to use inspection mode to crank it, I'm not sure (but I'm sure there's other members here who could tell you how to do it).
    AllenZ likes this.
  5. Patrick Wong
    18,209
    6,510
    I would suggest that the crankshaft be turned by hand, using a wrench on the center crankshaft bolt. Especially with no plugs installed, that will be a very easy task.
    blaisep and AllenZ like this.
  6. AllenZ
    640
    63
    Chicago
    That sounds like a great project for me. I will do some research and let you know the result. Thanks a lot!
  7. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    I also have come across the theory of a thicker oil possibly causing more oil use, and in my opinion has some merit. Thinner oil does flow more easily, but is also more likely to flow through partly blocked piston drain holes and be wiped more easily from the cylinder walls by the oil control rings. Obviously the opposite affect will take place around the valve stems. The thinner oil flowing down the valve guides more easily particularly on the intake stroke on an inlet valve with negative pressure at the valve head end.
    John (Britprius)
    uart likes this.
  8. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Remember that you want to really to force any liquid remaining above the rings to literally be blown out the spark plug holes though Patrick. Allowing the engine to crank certainly does this (spark plug holes blow out air like a breaching whale). I'm not sure if hand cranking would achieve this.
    Yes, that is exactly what I was getting at John.
  9. Patrick Wong
    18,209
    6,510
    Good point. In that case the OP can just try starting the engine with the spark plugs removed. Hopefully MG1 will spin the engine sufficiently to achieve this purpose before the engine ECU logs DTC associated with no-start. A gas/air mixture will be introduced in the cylinders via the fuel injectors, while the engine is trying to start but hopefully most of that will also blow out of the spark plug holes.
    Then if the 12V battery is disconnected, the DTC will clear.
  10. AllenZ
    640
    63
    Chicago
    Ha, I was just wondering how to start the engine without spark plug. :)
    What's the procedure/setting to force the engine to run when power turned on? Generally it does not run until you start to drive it. Obviously I don't want to "drive", or move the car in this process.
    Thanks!
  11. Patrick Wong
    18,209
    6,510
    When you first make the Prius READY from a cold resting point, and leave the gear selector in P, after a brief pause the gasoline engine will spin up. This is because the engine ECU wants to heat up the catalytic converter.
  12. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Just leave the plugs out (though still connected to the igniters if possible). The prius has no sensor to know that the plugs are out, so a few seconds after you turn it on (make ready) it will try to start the engine for the normal warm up cycle. If you're in very warm conditions and it doesn't try to start the engine, you can always force it by holding the brake with one foot while giving the accelerator a tap with the other.
    BTW. It will probably only crank for a short time (though plenty long enough for our purpose) before throwing an error code due to engine non start. Disconnecting and reconnecting the battery should fix that. I'd just leave the 12V disconnected while you replace all the spark plugs.
  13. AllenZ
    640
    63
    Chicago
    Sounds like something worth video documentation. I will talk to my mechanics, since I don't have the tool/skill/garage to get this done. Give me a week or so.
  14. JC91006
    16,768
    8,565
    Is this correct that thicker oil causes more oil use? I thought older engines usually tend to go to heavy grade oil to reduce oil use? Shouldn't going from 5-20, 5w-30 to a 5w-40 grade reduce oil usage?
  15. AllenZ
    640
    63
    Chicago
    Between Jun and Sep, 5qt of 10W40 lasted 6700 miles on my Prius;
    Between Sep and Oct, 5qt of 20W50 lasted 5050 miles on same Prius.
    Between Oct and Dec, 5qt of 5W30 lasted 3500 miles only.
    No filter change during this period.
  16. JC91006
    16,768
    8,565
    I wonder if using a 20w-50 grade would cause engine damage, being such a heavy weight oil. Looks like the winning formula for you is 10w-40. So basically you added 15 quarts of oil for half a year without changing anything out?
  17. Britprius
    5,194
    1,921
    There are to many variables in an older or high millage engine "using" oil. The consensus of opinion says use thicker oil. This probably works well in the area of the valve guides, and maybe on piston ring ware. It will also reduce noise from excess clearances of the valves, bearings, and piston to bore.
    However the thicker the oil the thicker the oil film left on cylinder walls the more oil control ring have to remove and pass through the drain holes in the piston skirts that are probably already blocked or partly blocked. Flow is restricted further by the thicker oil. If the rings are stuck in there groves and do not wipe the cylinder walls the thinner oil will flow more readily up into the combustion chamber.
    John (Britprius)
  18. AllenZ
    640
    63
    Chicago
    Actually the oil burning started 50K miles ago. I was adding 5W30 at the rate of 1qt/2K miles for a long time. Things getting worse recently, that's why I changed to 10W40, and the rest.
    Just ordered Auto-Rx, and will try it soon.
  19. AllenZ
    640
    63
    Chicago
    John, when you say "drain holes in the piston skirts", do you mean this?...
    http://www.stangtv.com/forum/attachments/2751d1259173805-srp-now-offers-piston-skirt-coating-srp-professional-skirt-coating-500x500.jpg
    If that's partially blocked, it will slow the cooling of the piston, and may causing more carbon deposit there? Is that the reason using too thick oil will cause engine damage?
    Thanks!
  20. JC91006
    16,768
    8,565
    This is really unfortunate for the Prius, such a great car but many are using excess oil around 140k-150k mile mark. Even my car at just over 125k is starting to burn some oil. I was planning to keep this car for another 10 years but with this oil issue, not sure what will come of it.
