Burning oil at same rate regardless of oil thickness --- What does it tell us?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AllenZ, Dec 13, 2013.
  1. Britprius
    Britprius Senior Member
    5,194
    1,920
    Herefordshire England
    Could you please check and see what oil viscosity it says on the filler cap of the engine? and let us know.
    My 2008 gen2 in the UK says 0w/20 as do all gen3's. OP Grumpy Cabby noted on PC that when the dealer used 5w/30 his fuel consumption rocketed. In the UK/EU handbooks it states that if an oil other than 0w/20 is used it should be changed at 5000 miles "5000 miles early" and refilled with 0w/20.
    John (Britprius)
  2. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    John,
    I used 0W20 synthetic before, gone very quickly. :)
  3. Britprius
    5,194
    1,920
    Thanks, but I was just trying to establish the recommended grade of oil in Oz for the gen3. It is strange that for gen2's some use oil while others at the same millage do not. However some oil use "we use pints or litres here" say half a litre or more in 5000 miles I would consider quite acceptable. It is not so long ago that this would have been good for a new car. As you know I have only ever used 0w20 "apart possibly from what came in the factory fill" for the last 100,000 miles.
    John (Britprius)
  4. AllenZ
    640
    63
    Chicago
    OK, I did some research, and decided to pick the cheap route first (I did not do oil ring flush, my mechanics was busy that day, and I can't park my car there over night). The MMO (Marvel Mystery Oil) cost $6/32oz at Autozone. The Gunk Motor Flush (32oz?) $5.
    I used Gunk just before changing oil. Pour in to cold engine. Idle for 5 minutes and flush.
    Then use generic conventional oil, and the big filter ST3600 on Prius. Added 1qt MMO. In 3 days, drove 250 miles. MPG back from 38 to 41 at even colder temp (5F colder). I felt like when starting up in cold morning, the engine seems a little rougher than before, just a little bit. But once warm up, back to normal. The first two days, mpg stays at 38. Today, it is 41.
    The oil burning is not stopped yet. My mechanics actually over filled the oil by almost 2cm on stick. In 250 miles, it is now 0.5cm over max mark.
    I also received Auto-RX, 2x12 oz bottle for $50 shipped (ouch!). The owner will not allow me to return, saying the shipping company can not pick it back. That sounds reasonable. But he can not even allow me to drop off (I don't think I will, actually, since he is not close to Chicago). I will not go that route unless no other choice. I will put it for sale later, if MMO works good enough.
    I'll keep you updated.
  5. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Here it's 5/30. That's going by the Manual. Nothing on the filler cap except a handle. Much hotter than Pommy land.
  6. Britprius
    5,194
    1,920
    Yes I do understand that, but what I stated goes for all of Europe including places such as Greece and Turkey where summer temperatures run at 40 to 45 C.
    John (Britprius)
  7. Feri
    Feri Active Member
    761
    144
    Hi John,
    I've attached a copy of the relevant page from the Oz manual. That's all I can go by.:unsure:
    Another thought! Greece and Turkey get colder in winter than we do in most places.
  8. uart
    uart Senior Member
    4,220
    1,209
    Australia
    I'd be careful about using some of those really heavy duty diesel oils in an oil burning Prius. The one thing that he does have to lose is the catalytic converter. Some of those oils literally have about 3x the amount of additives which potentially can poison a cat (compared with a standard api sm/sn oil). For example, someone over at bitog posted a virgin oil analysis of "Delo Gold" and it had very high amounts of additives. Can't remember the exact amounts but it was huge, something like 1700 ppm Zn, 800 ppm Mo and 300 ppm Bo.
  9. AllenZ
    640
    63
    Chicago
    Tivoboy,
    When ARX is doing its work (adding 12 oz to 4 qt oil), doesn't the oil+ARX solution also rinse the loosened sludge at the same time? Why need additional oil change to "rinse". It contradicts to common sense. I wonder if that's their strategy to add the "mystery" for the marketing.
    It's like saying: "yep, I don't want to or I can't tell you why, but it works. Trust me!"
    MMO does not require such special Rinse cycle.
  10. Britprius
    5,194
    1,920
    Hi Feri, Thanks for the PDF.
    From reading the page from the manual 0w20 is a recommended grade of oil for you in Australia, covering the same temperature range as 5w20 and 5w30.
    It does not state preferred viscosity 5w20 or 5w30 although the wording is somewhat different to the European manual where as I previously stated "if a higher viscosity than 0w20 oil is used this must be changed for 0w20 after 5000 miles".(n)
    John (Britprius)
  11. Feri
    Feri Active Member
    761
    144
    I guess Toyota would have done their research and have reasons. Our reccommendations go with 10,000km oil changes.
  12. tivoboy
    tivoboy Junior Member
    SF Bay Area
    They claim the ARX is attracted to the metal like the true synthetic oils (ie group 5 oil) and you need a regular G2 or G3 synthetic to rinse properly
    My translation is ARX sticks to and loosens the stuff and you need to rinse it off with plain oil. That is why I don't like to call it a "Clean" cycle - gives the impression that the gunk is removed in one step.
    In my case, the "treatment" phase freed the oil ring(s) and reduced the oil consumption - maybe the subsequent rinse cleared it out or flushed it off the engine surfaces and into the filter
  13. AllenZ
    640
    63
    Chicago
    I used to buy large qty of piston rings to assemble gasoline engines (up to 900 cc). The ring is pretty hard material, and to put it onto piston, you need some kind of tools to help. It is highly elastic. Once the piston is assembled, the ring seals the gap tightly.
    I can't imagine that carbon deposits will make it "stick" to the piston, and not seal the piston wall, especially when piston moves constantly.
    It is a mystery to me. But obviously, I don't have experience fixing cars.
  14. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Hi John. Yes I don't see anywhere in the posted manual page that says 5w30 is the preferred. I think what Feri is saying is just that the Toyota Australia chooses to use 5w30. This may be as much to due ease of availability as anything else.
    In any case, the manual definitely makes it clear that 5w30 is no problem for any temperature range that you can experience here.
  15. AllenZ
    640
    63
    Chicago
    Quick update 1200 miles after using MMO
    Before changing oil, poured in 1qt Motor Flush when engine almost cold. Idle for 5 minutes and changed oil.
    Added 0.7qt MMO into 10W40 regular oil.
    First 900 miles nothing significent. Oil very clean. MPG seems back to 43 from 40. Temp were really low here in Chicago, average 25F.
    At 1200 miles, the oil seams getting dirty. Oil cap super clean now. Lost about 1qt oil. So the burning is still going on, almost same as before. MPG back to 47 on a warm day of 37F. Today 25F, mpg = 45.
    Filled oil again, added 20% MMO. Let's run/clean another 1000 miles, see what's going to happen.
  16. Former Member 68813
    3,524
    983
    US
    It happens all the time in some Toyota cars (as well as Saturns) . I had that in my RIP corolla.
    When that happens, you get accelerated ring/cylinder wear and nothing will help at that time. The time to act is when oil consumption starts.
  17. Former Member 68813
    3,524
    983
    US
    The reason you see improvements is due to removing piston deposits that accumulated during oil burning.
    Since you had no oil consumption improvement after the initial cleaning, it's probably irreversible. When I had my corolla, engine flush/piston soaks would work for 3,000-5,000 miles (depending on oil type) and then consumption would come back. Clearly the piston oil holes were plugged up, but there was no severe damage to rings yet. Now, that was at the 70,000-90,000 miles mark.
  18. AllenZ
    640
    63
    Chicago
    Thanks Jacek!
    Since it's only 1200 miles so far, I will keep the MMO cleaning for another 2000 miles maybe, see if the burning will stop. If not, I will replace the engine soon.
  19. dzhantim
    dzhantim Junior Member
    Maybe this can help (snippet from another thread):
    " If a PCV valve gets gummed up, you will burn some oil. It is a genarally good protocol in most cars to replaced the PCV at regular intervalls..."
  20. AllenZ
    640
    63
    Chicago
    PCV was replaced 5K ago.
