Bus Bar cleaning
Discussion in 'Gen 2 Prius Main Forum' started by OBJUAN, Jul 24, 2022.
  1. OBJUAN
    OBJUAN Member
    166
    canada
    GOOD NEWS EVERYONE, well a tip at least :eek:P
    Electrolyte from the neg post corroding bus bars is a pain!
    Easy way to clean the bars is (vinegar/salt soak takes a long time):
    Leave bus bars in the plastic frame or make your own frame so you have clear access and can flip
    the bus bar over.
    Get a 1/2" socket, the deep style.
    Get ~12" of emery cloth from plumbers roll.
    Roll up the emery cloth and stuff in the the socket.
    Attach the socket to your cordless drill.
    Run the socket back and forth over the bars inside the frame, 5-10secs ea.
    Flip the bars over and repeat.
    Nice clean bus bars...
    rogerdpack and Ernie stires like this.
  2. Tombukt2
    Tombukt2 Senior Member
    13,848
    2,515
    Durham NC
    As I bust up batteries sometimes I save the bus bars the copper ones I just have them shaken in a brasive cleaner down at the place and they look brand new using again I want to try some of these harder silver metal ones see how they do coppers always going to get dirty after I put the rack together I spray them with the CRC terminal protectant the red stuff it's the light coat.
  3. PriusCamper
    PriusCamper Senior Member
    13,450
    5,430
    Pacific Northwest, USA
    Not another bus bar cleaning post. <sigh> I said it before, I'll say it again. Put them in a rock tumbler and add water and go to sleep. When you wake up in the morning take 'em out, rinse 'em off and you're done. They'll look brand new with a high quality matte finish.
  4. OBJUAN
    OBJUAN Member
    166
    canada
    You can say it until you are blue in the face: Not everyone has a ROCK TUMBLER laying around but most DIYers have a 1/2" deep socket and emery cloth, it only takes seconds per bar not all night friggen night...
    beardlesswhelp and rogerdpack like this.
  5. PriusCamper
    13,450
    5,430
    I got like 8 battery packs worth of bus bars and I'm about to borrow the rock tumbler from my neighbor again. Do you realize how long it would take to hand clean 8 packs worth of bus bars? Beside you get a 100% consistent finish on every bus bar. No other method does that as quickly.
  6. Mendel Leisk
    42,324
    Bench grinder?
  7. PriusCamper
    13,450
    5,430
    Grrr....
  8. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    Bench grinder with brass wire wheel.
    beardlesswhelp and Mendel Leisk like this.
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Muriatic Acid takes about 15 seconds per battery. Dissolves pretty much everything except glass, plastic and copper. :)
    Takes even less time if one just uses a new wire frame #2 harness :):), which also eliminates the chances of failed sensor tabs.
    kutcht1 and Ernie stires like this.
  10. PriusCamper
    13,450
    5,430
    And as I'm successfully stocking up on wire frame #2 and am gonna be installing lots of brand new upgraded v2.0 Project Lithium packs in November because they're even higher performance than existing ones, I'm gonna have to start getting rid of lots of unneeded busbars. :)
  11. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    I will second the Muriatic acid. Had some left over from years ago garage floor cleaning project. Threw the busbars in a small jar with the acid and literally seconds later they looked completely clean. Left them in for 10 minutes for good measure, rinsed off with water and good to go.
  12. Tombukt2
    13,848
    2,515
    Durham NC
    I have muriatic acid from pool work I didn't even think to use it I just throw them in my daughter's rock Tumblr quickest thing I could think of
  13. pasadena_commut
    pasadena_commut Senior Member
    3,045
    946
    Southern California
    Rock tumblers are typically run with a mild abrasive. I believe that it will remove a layer of corrosion, but it will also induce a very large number of microscopic scratches. For a part which is coated copper, some of these might be deep enough to get all the way through the outer metal and into the copper beneath. Once the copper is exposed, that section will corrode rapidly. It think this might be especially a problem for flat metal like the bus bars, where the edges could smack into each other, which would magnify the damage (versus flat to flat impact). Is it really a problem? I don't know, but acid treatment will not cause these sorts of mechanical damage. Not that it is entirely safe, it is still possible to burn all the way through a preexisting weak point in the outer layer, or to accelerate the part's aging by thinning that coating.
  14. Tombukt2
    13,848
    2,515
    Durham NC
    Used fine carbodurum powder soak in acetone after.
  15. OBJUAN
    OBJUAN Member
    166
    canada
    with the constant electrolyte leaks, I just replaced them with the 304 stainless version, done with it.
    Then I'm going with Lipo4, enough of the life sucking Nimh...
  16. pasadena_commut
    3,045
    946
    Southern California
    While I understand the sentiment, the jury is still out on the actual lifetime of Nexcell packs. Conversely, there are 15 year old NiMH packs still in use (one is in my car.) My experience with other Lithium batteries was generally "very short lifetimes", as in laptop battery packs. Never more than a couple of years. None of these were the LFP batteries as used in Nexcell though, and LFP is supposed to be quite long lived. But nobody really knows for sure, as commercially available batteries using that chemistry have only been around for a few years. Also, chemistry isn't everything. Honda Civic Hybrids also used NiMH cells (cylindrical rather than prismatic), and those were far less reliable than the Prius cells. If a Honda NiMH pack reached 7 years that was exceptional, whereas pretty much all Prius packs survived far past that. See the table here:
    2015 Subaru Outback and Legacy | Video Review - Consumer Reports
  17. drone13
    drone13 Active Member
    140
    115
    SoCal
    @pasadena_commut I have read a few articles relating to the early failure rates of Honda hybrid batteries and they all pretty much agreed that the difference from the Prius models with the same battery chemistry was Honda's aggressive use of the batteries. IOW, they allow deeper discharge and higher charge rates and voltage. Toyota was smart to be very conservative with the useable range of charge that the Prius can use and charge rates.
    I've never tested this so I can say for sure, but I have seen reports about it.
  18. pasadena_commut
    3,045
    946
    Southern California
    Cooling may also have been an issue. The design of the pack didn't guarantee that all the sticks were at the same temperature, so parts of the pack could age (due to thermal concerns) at different rates.
    Two other big problems. First, Honda did not make arrangements for a continuing supply of the original batteries, so after a while if a pack died they would supply one containing used batteries for a failure under warranty. As you might imagine, these did not last very long. (First hand experience.) The second problem was that the Chinese companies which sprung up to fill this void (also for other cars, like Ford's C-Max) made products which were, for lack of a better word, crap. Or at least, highly variable, which made building a good pack extremely challenging. I bought a pack made with these for our HCH 1, but it failed in two years (-ish, I don't recall now the exact period). No way I was going to spend that much, that often, on batteries.
    As I have said before, regarding the Nexcell modules, we also don't know that the NiMH modules Toyota has now are as good as the ones they sold 15 years ago. However, we have reason to suspect that they might be, since Toyota at least cared enough to maintain a supply chain for them.
  19. OBJUAN
    OBJUAN Member
    166
    canada
    I have had a 70 pack of headway's in for the past 2 years but they go out of balance quick and fuel economy crashes.
    I attempted rehydrating the old nimh cells but the 2mm holes leak even when sealed with nylon or stainless screws
    and covered JB weld plastic epoxy. Course the negative posts still leak corroding the copper bus bars(never ending trials).
    I want to go with A123 8ah pouch cells rated at 30C (C/D) and operate -30C to +50C.
    Should fit in the pack fine just have to deal with cooling...
  20. Ernie stires
    Ernie stires Member
    107
    30
    Colorado
    Good idea, fast and easy to do without removing things.
    rogerdpack likes this.
