Bus Bar Mistake
Discussion in 'Gen 3 Prius Technical Discussion' started by Noahdoge, Jun 15, 2022.
  1. Noahdoge
    Noahdoge Active Member
    219
    148
    Mississippi
    911D8920-2C76-4140-8E0B-491E90DEAD52.png So after watching Jack’s new video I realized I made a mistake. I used the aftermarket nuts with those grooves in it. Should I switch back to oem asap or do you think I will be fine? I checked my resistance in the dr Prius app before and after the change there is no change. Hopefully I did not damage anything.
    Attached photo is driving on a very hot day.
    davev1pa likes this.
  2. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    If resistance is ok I would leave it.
    Noahdoge likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,467
    5,434
    Pacific Northwest, USA
    Haven't watched that video yet so don't know Jack's point, but the main reason for not using nuts with grooves in it for me is because NiMH are prone to corrosion and the nuts create more room for the corrosion than a flat surface nut. However, you no longer have a NiMH that creates corrosion like that, so it's fine, nothing to worry about.
    Higgins909 and Noahdoge like this.
  4. Noahdoge
    219
    148
    Mississippi
    Thank you for putting my mind at ease!
  5. VZvrtny
    VZvrtny Junior Member
    24
    The nuts you have will work fine since they only provide the clamping force to the bus bars, but if you were to work on your battery again at some point, I suggest using the ACENBAY brand nuts Wide Flange Nuts.jpg
  6. Noahdoge
    219
    148
    Mississippi
    I got the old acenbay design in 2021. I swear they changed their design right after i purchased mine unfortunately. Though my battery is still going strong, and internal resistance + voltage difference is the same from 2021.
  7. AzusaPrius
    AzusaPrius Senior Member
    2,257
    950
    You can save some cash using code azusa over at AcenBay.com
    VZvrtny likes this.
  8. AzusaPrius
    2,257
    950
  9. Noahdoge
    219
    148
    Mississippi
    I knew that was coming soon…
    Paul E. Highway likes this.
