Busted toe, bust rear wiper arm
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Laura G., Jan 17, 2017.
  1. Laura G.
    Laura G. Junior Member
    4 months with my 2007 and I'm loving it. Until this week. Busted twould toes. Hobbled out to put the cover on the car and started to trip and fall and grabbed at the car cover- and accidentally grabbed rear wiper arm and twist and shout and snap! Seems the actual mechanism workso, just no wiper on anymore.
    Is this an easy fix for someone who has replaced alternators on a Spitfire and a wiper motor on a Ford Probe?
  2. JC91006
    16,889
    8,625
    Probably just need the wiper arm, held together by 1 metric nut. Should be plenty of these used parts available
  3. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    You can also get the cheap Chinese made wiper arm and blade package. For example: Rear Wiper Arm & Blade set FOR TOYOTA Prius (2004-2009) ,OE:8524147010 | eBay
    I have one of those in my Prius as I wanted the slimmer US rear wiper arm and it has been working good for almost a year already.
    Like JC91006 said it’s easy to replace just open the one nut. Then wiggle the arm to get it off from the mechanism. And then just put new one on to correct position and tighten the nut.
