Buying 250K Prius C?
Discussion in 'Prius c Main Forum' started by Yzvessel1, Aug 19, 2023.
  1. Yzvessel1
    Yzvessel1 Junior Member
    Michigan
    2019 Prius
    LE AWD-e
    My neighbor is selling their Prius C 2012 with 250k miles. I have a RAV4 Hybrid but am looking at a second car for driving around out small town etc.
    Would have a mechanic look at it but for under $5K is there any major reason not to get it?
    Assuming battery is diminished some- but would probably be putting less than 6k miles a year.
  2. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Far too many miles to not start getting significant costly problems. This from my own experience and from reading a lot of posts on here.
    From what I understand after about 150,000 miles Priuses become maintenance hogs. Some will disagree, and that’s fine.
    A prius with 250k+ miles would have to be really cheap to be worth gambling on. You might be lucky of course. And the car market is still crazy. Good luck.
    Yzvessel1 likes this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,053
    6,925
    Texas Hill Country
    The c is somewhat underpowered, noiser, harsher riding and is far less safe than your 2019 Rav4 hybrid. So be sure to drive it and understand those compromises.
    You can count on the hybrid battery failing rather quickly unless it was changed with a new cell battery in the last 75k-100k.
    Most mechanics and even Toyota have no way to predict failures except for guesses based on miles and age. The hv battery in that car is overdue on both counts. They can more accurately evaluate the conventional systems on the c such as suspension, tires, brakes and corrosion.
    Hybrids are not magic 300k-400k mile vehicles. Taxis sometimes rack up those kinds of miles but they think nothing of expensing hv batteries and engines to keep one of many revenue generating vehicles on the road. Having one down for a few days is no big deal.
    Hybrids are very complex combining most elements of a conventional and an ev vehicle. With that said, the 2012 c has a better engine than a 2012 hatchback or v. But a 250,000 hybrid is still a gamble and they will nickel and dime you at $500-$1000 a pop even without a major failure.
    One of my car trading rules is never buy or sell to a friend or neighbor. Makes for a dicey situation when problems occur. Finally, just a couple of years ago a ten year old Prius with 100k miles would sell for $5k. We may soon get back to that market as new car volumes increase. Those numbers are already matching pre-pandemic volumes and new car discounts are back for GM and other vehicles.
    #3 rjparker, Aug 20, 2023
  4. Leadfoot J. McCoalroller
    8,278
    7,788
    Pennsylvania
    2018 Prius c
    The c is harder on its battery than some of the other models, mostly because the battery is slightly smaller.
    This means you should expect that it is more than "diminished" at age 11- more like an any minute now situation.
    Remember that the primary way a Prius provides value is by giving good gas mileage. If you are only driving 6000 miles a year, this car can't possibly save you much vs. other choices, especially when the cost of a battery replacement is added in.
    Don't get me wrong, I absolutely love the Prius and especially the c hatchback version. But every tool has its best and worst uses, and a Prius is very bad at being an old, lightly used extra car.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    I absolutely agree with this.
    In fact, I would not consider ANY vehicle with that many miles to be a good gamble.
    Especially not a hybrid that has more things to go wrong.
    Unless you also want it as a "project" and to learn about hybrids,
    I suggest that you pass.
  6. sam spade 2
    7,035
    2,804
    2017 Prius c
    Good post but this part is WAY off base.
    ALL of my C's.....4 total.....got about 50 MPG if driven conservatively.
    The Rav4 I rented last month was struggling to get 30.
    Pri3C likes this.
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    A wild guess that I think is invalid.
    It also has an engine that is slightly smaller.
    And I believe that it uses the battery somewhat
    less than it's bigger cousins (but that is a guess too)>
  8. bisco
    52,807
    under 6k for a car with a quarter million miles? what planet are we living on? dealer is offering me 8k for my 12 with 86k
  9. Yzvessel1
    Michigan
    2019 Prius
    LE AWD-e
    Thanks for everyone’s replies! I agree that it would be a gamble. I love my rav4 but needing a second car for a small commuter I wanted everyone’s opinion.
  10. rjdriver
    rjdriver Active Member
    411
    172
    Rhode Island
    Wholesale value is about $1600.00, so the asking price is way too high. No more than $3000, and even then, only if your neighbor can provide a complete maintenance history. Otherwise, you called it right - a gamble. A big one.
  11. rjdriver
    411
    172
    Rhode Island
    Wholesale value is about $1600.00, so the asking price is way too high. No more than $3000, and even then, only if your neighbor can provide a complete maintenance history, and the body is in reasonable condition. Otherwise, you called it right - a gamble. A big one.
  12. JohnPrius3005
    423
    235
    In todays crazy car market it’s probably not reasonable to try to buy a car by taking a hard line approach like that. While you are totally correct, that doesn’t change the market.
    Palmoyas likes this.
  13. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    The Prius C is known to get to far higher mileage than the non C, and it has proven to be far more reliable. 250,000 miles on a Prius C, still safe to buy, i have seen them with 300,000 miles and more.
  14. Sonic_TH
    575
    96
    Puerto Rico
    2016 Prius c
    The Prius C is not harder on the hybrid battery, the Prius C actually cools it less due to cabin noise, i have tested it, if i do not turn on the fan with an OBD 2 the hybrid battery gets too hot to be good for its lifespan, like 90° F and up even with the A/C at full blast. The modules that are on the center get even higher, like 96° F.
  15. Leadfoot J. McCoalroller
    8,278
    7,788
    Pennsylvania
    2018 Prius c
    I've suggested that the c is harder on its battery. Why? Because the published curb weight of the c is almost as much as the Generation 2 Prius, which has a very similar hybrid system including the same 1.5L gas engine. But that car has 14 modules in its battery, where the c only has 10. That's a 40% difference.
    I look at those numbers and conclude that they're trying to do more with less, and when that happens the parts often need to work a bit harder.
    Also, Toyota offers shorter warranties on the c battery. If they don't think it will last as long, I'm willing to believe them. They've done this more than me.
  16. Sonic_TH
    575
    96
    Puerto Rico
    2016 Prius c
    That might be the reason why the modules on the Prius C get hotter, and hence last less.
