Buying a used gen 2 for $4,000
Discussion in 'Gen 2 Prius Main Forum' started by Travis Davis, Apr 7, 2017.
  1. biglew8
    biglew8 Active Member
    170
    114
    Seattle
    If the dealership tells you it's a transmission fluid flush, RUN! It's supposed to be drain and refill. There's many posts on how to do the drain & refill yourself. If not, Toyota of Bellevue charges about $125 for the service. I believe Toyota of Renton charges around $115.
    Front brakes at 8mm is pretty good. According to the Toyota multipoint inspection report from my recent oil change, 7mm to 12mm is considered good and in the green. For the rear drum brakes, 3mm is good too. 3mm-4mm is in the the green. 2mm is in the yellow and 1mm is in the red. I'd recommend a brake flush if the Prius hasn't gotten one before. How are the tires?
  2. Travis Davis
    Travis Davis New Member
    27
    Seattle
    Yeah, I will just do the drain and refill myself. Looks like i will need to invest in one of those suction guns due to tight access. The tires are 7mm in front, rears are 4-5. They had a blowout a year or 2 ago, and decided just to replace 2 tires instead of all of them. I'll probably end up replacing them more towards the end of the summer as i knock some of the more important things off my list. I already got a quote from costco and the michelins aren't expensive at all. They quoted me i think ~$525 for the michelin defenders. Im used to payin $1k+ for SUV tires. I may end up opting for something just a little more stick than those defenders though. The treadwear was 820. Or do you think those are fine on a vehicle like this?
  3. biglew8
    170
    114
    Seattle
    I would look through the tire thread to see what people like. My tires are still new so I haven't really looked into tires yet. I usually get Michelin tires from Costco for my cars. If you do end up getting them at Costco, wait until they have the $70 off coupon.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    There's plenty of room to reach the drain/fill bolts from underneath after taking off the splash guards. You'll need a long tube and funnel to pour the new fluid in from above the engine bay. Tip: loosen the fill bolt first. It's its stuck for some reason but you've already drained the old fluid....... :eek:
  5. Travis Davis
    27
    Seattle
    I do wonder if the traction battery is on the way out. After parking with nearly a full charge last night, the battery was at like 2 or 3 bars when i woke up this morning. I averaged 41 mpg (per the in-car display) on the drive home yesterday, which was 60 miles on the freeway.
  6. JC91006
    16,936
    8,647
    You would need to run the car before the battery SOC will start dropping. It shouldn't do it while it's off
  7. Travis Davis
    27
    Seattle
    So if it is dropping with the car off does that mean the battery will ned replacing soon? I saw a video online where the guy rebuilt it himseld by just replacing the bad modules. I may try that also.
  8. JC91006
    16,936
    8,647
    If the module fails, you would have a hybrid warning.
    You can find out a little more about battery rebuilding at hybridautomotive.com. They sell a grid charger that will help you rebuild and balance the battery. It's a little more involved than just replacing a module.
  9. Moving Right Along
    Moving Right Along Senior Member
    739
    596
    Not entirely true if the battery is going bad. Nickel metal hydride batteries will self-discharge when they get closer to their limits, and the car would still be powering the smart key system, so that's a small charge that is demanded even when the car is powered off.
  10. JC91006
    16,936
    8,647
    The cars ecu does not register the hv battery SOC when the car is off, will need to be powered on before it can detect the lower SOC.
  11. dolj
    dolj Senior Member
    8,646
    4,398
    Wellington, New Zealand
    When the car is OFF, the power is supplied by the 12 V battery for the likes of SKS, ECUs, the accumulator pump, etc.
    The other thing to bear in mind is that there can be a lag with the Energy Monitor display, so for example if you did the last 200 yds in EV and then switched off, the battery might not be updated with the current SOC until the car was restarted later, which would then appear to show a sudden drop while the car was OFF.
  12. Travis Davis
    27
    Seattle
    Apparently I was mistaken about the battery. I actually took a picture last night of the battery status and when I came out this morning it still had the same exact amount of charge. Looks like everything is all good!
