Buying Advice
Discussion in 'Gen 2 Prius Main Forum' started by Druhzin, Jan 10, 2016.
  1. Druhzin
    Druhzin New Member
    Indiana, United states
    Hey there I was hoping I could get some help/information. I'm looking at 2 cars right now, one is a fully loaded (not touring though) 2007 Prius with a rebuilt title and 100k miles for 5k. The other is a 2005 Prius probably mid package with 101k for 4500 and a clean title. The 2007s inside isn't pretty and has a bit of a smell, but that can be fixed with a good cleaning. It also is through a small dealership that repairs salvage vehicles and offers 120 day warranty. The 2005 is about 300 miles away from me so I'd have to take a greyhound to look at it. Any advice? The car will be used for up to 100k miles a year for my job.
    52,791
    welcome to priuschat! i have no advice, but i wish you all the best.(y)
    i mean, if you're gonna put 100k a year on her, i expect you can fix anything, so the salvage would be fine.
  3. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Go for: Clean tittle, No accident records, Ask for Carfax(dealer's expense), Maintenance Records; Hi-res Photos before going,
  4. imlkrsfn2
    imlkrsfn2 Junior Member
    23
    Stockton, CA
    Never buy a salvaged vehicle regardless of the car. Always go for a clean title with as few owners as possible.
    Paying that much money for a 10 year old prius may not be a good idea. I don't think the hybrid battery will last much longer if it is still the original. I would suggest getting a newer prius if it is in your budget, otherwise you may want to consider a regular gasoline car such as a corolla.
  5. Patrick Wong
    18,210
    6,517
    Your income presumably depends upon having a reliable vehicle. Neither of the choices you suggested would be on the top of my list of reliable vehicles. A vehicle with a salvage title is an especially large risk. You have no idea whether the vehicle was competently repaired nor do you know what shortcuts were taken.
    Have several thousand $s available as a repair fund if you decide to buy either of those cars.
    dorunron likes this.
  6. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Out of all responses so far, I think Patrick Wong nailed it. I too would not take a risk on either of the two vehicles you mentioned. If I were to buy either one, I would definitely have quite a few thousand put back for unseen repairs further down the road.
    100K a year is a lot of miles. If it were me, and I was going to drive that much, I would start with something BRAND NEW, not something that is already used and abused.
    Best of luck to you and welcome to Prius Chat!
  7. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    The salvage is worth maybe $2500. I wouldn't expect a car with 100,000 miles on it to reliably last another 1 or 2 years putting 100,000 miles on it every year.
    Buy a leftover 2015. It may cost 4x as much (maybe not) but should last more than 4x as long.
  8. Druhzin
    Druhzin New Member
    I've got about 6k to spend. I'm taking 4 months off to help out a friend (making pretty much nothing) so I can't afford a new vehicle. When I get going again I'll be making enough to cover any repairs np. I always keep 2k spare just in case. Reason I was going for Prius is the gas mileage and the fact I can fold down the back seats and sleep back there. I'm waiting on a response from someone now with another 07 with 91k, new 12v and full bar battery.
  9. dorunron
    3,318
    1,105
    Houston, TX
    A/C Repair 1 to 2K
    Transaxle Repair/Replacement 3 to 4K
    Traction Battery Repair/Replacement 1K to 3K
    Inverter Repair/Replacement $1K to 2.5K
    Prius is not cheap to repair
    2K repair fund might not be enough for the age of Prius you are looking at.
    You might consider a regular gasser like a Camry, Corolla, Scion, etc.
    YMMV
    If you must go salvage route, contact Autobeyours (Google it). They are in Indiana and are well respected here on Prius Chat.
    Patrick Wong likes this.
  10. Patrick Wong
    18,210
    6,517
    "full bar battery": that means nothing. You can make the battery of any Prius show 8 green bars on the MFD, simply by shifting into D, pressing the brake pedal with your left foot to hold the car stationary, and flooring the accelerator pedal a few minutes. This is called "force charging" the battery. That technique is not advisable for routine use as this potentially will overheat the transaxle, not to mention the battery itself.
    I agree with the suggestion to look at autobeyours.com considering your limited purchase budget.
  11. minnyprius
    minnyprius Member
    141
    45
    Twin Cities
    Do you have a vehicle now? If you do, and if I were you, was planning on not working for a period of time, I would put the money you have in savings and drive what you have. then IF it dies during the time you are not working, you have some money to go buy a replacement. And that replacement, or if you don't currently have a vehicle, I would recommend something like a Toyota Yaris or Scion xA/xD... They're solidly reliable and pretty inexpensive, and there's nothing fancy to possibly break on you. Save the Prius for when you have an income coming in and can be ready for emergencies.
    Good luck in your decision and journey!
  12. bisco
    52,791
    0% financing on a leftover '15? by the time you run out of cash, you'll be working and able to make payments. plus, you won't have any repair downtime.
    otoh, financially, a non hybrid might work better, especially if gas stays low for awhile.
