buying (high?) mileage Prius
Discussion in 'Gen 3 Prius Main Forum' started by Yzvessel1, Nov 14, 2021.
  1. Yzvessel1
    Yzvessel1 Junior Member
    Michigan
    2019 Prius
    LE AWD-e
    Hi all,
    We are thinking about picking up a second Prius. With how crazy the used market is right now, most 3rd gens within our budget have between 100-120 miles. I know these things can last a lifetime but what are your thoughts and things to look out for when purchasing a higher mileage car?
    I've been looking at carcomplaints but it hasn't been helping too much.
    Looking forward to hearing your thoughts. We are in Michigan which also seems to limit our search and trying to stay under $15k (Which is nuts considering our 2019 AWD Prius we paid $19k in Dec 2019) but the average going price for gen 3 seems to be around 12-14.
    Thanks!
  2. Yzvessel1
    Michigan
    2019 Prius
    LE AWD-e
    I should specify that I am looking for a 2013-14 Prius. Given some of the threads about 2010-2011s I have stayed away. What are you thoughts on this? Those seem a bit more reasonable to my budget and have found some under between 60-80k miles with asking prices between 10-12k.
    Most of my reading leads me to think that head gasket and other issues don't typically (if at all) show up till around 150k +. Thanks again for any advice.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,974
    Texas Hill Country
    The 2010-15s have similar problems primarily due to piston ring, brake booster, inverter and egr design flaws. Hybrid batteries are always a concern as they age. The 2015s and some 2014s have redesigned pistons and rings.
    It requires a 2016 gen4 redesign to ensure the best reliability. I would buy a 2016 or newer or get a conventional car in your price range.
    Use last six digits in the attached reference
    Yzvessel1 likes this.
  4. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    Yes, unless you're a big DIY person you want to stay away from Gen 1 and Gen 2 Priis. (1997-2003) Gen 3's have some issues so if looking at those you'll want their maintenance history and have a mechanic run an advanced scan on the car as well as a visible inspection....since you seem to be in the rust belt, also want to check for how much rust is underneath. Look for anything 2015 or newer, Gen 4.
    I would NOT want to be in the market for buying a used car right now! My friend (who hates Toyota, makes me angry) ordered a Jeep Wrangler a few months ago and it just came in but the dealer tried to pull a fast one and now wants $10,000 OVER MSRP! I told him if he has a paper from them where they quoted the MSRP then he needs to see a lawyer and not pay that ridiculous amount. (Should also report them to the BBB, IMHO)
  5. Yzvessel1
    Michigan
    2019 Prius
    LE AWD-e
    Yeah, the market right now is awful. But now that we are both needing to commute another car is a must. This is why we are looking at another Prius. We'll adjust our search for a 2015 or newer but I think that will be at the very top of our budget.
    We thought about a conventional car, but already owning a Prius we kinda got sucked into a Prius all-or-nothing midset.
    Thanks for all the advice.
  6. Yzvessel1
    Michigan
    2019 Prius
    LE AWD-e
    If the VIN doesn't end in 791355 does that mean that the oil consumption problem shouldn't be as big of a risk? I typically change oil every 5k anyways... Thank!
    EDIT: ah, I think it read it wrong... if the VIN doesn't match then there may be a problem.
  7. Colorado Boo
    307
    202
    2021 Prius
    LE AWD-e
    Wow, you're right about those prices. I just searched my local places and 2015 Prius 2/3's are going for 17-18,000....dang. My 2017 Prius was $21,000 NEW (MSRP was 26,000 but I'm a good bargainer.)
    Do you have to get a Prius? I saw a 2015 Camry Hybrid with 117,000 for $17K....that's what I'd be looking at I were buying.
  8. rjparker
    11,116
    6,974
    Texas Hill Country
    The last six digits are a sequence number. Bigger means the revised pistons are in the engine.
  9. Yzvessel1
    Michigan
    2019 Prius
    LE AWD-e
    How ironic, a friend of mine sent me a link to a 2012 Camry XLE for 13k with 102,000 miles. I hadn't considered a Camry because I like the hatchback styling of the Prius but since we already have a Prius, this may be an option to consider.
    #9 Yzvessel1, Nov 15, 2021
    Colorado Boo likes this.
  10. Colorado Boo
    307
    202
    2021 Prius
    LE AWD-e
    You may to also check out Mazda's, especially the CX-5's....my daughter has a 2016 and it's very impressive and getting 32 mpg. Older Mazda's had a horrible transmission (Jatco) but Mazda wised up around 2013 and now have their own transmission which is almost as good quality as Toyota's these days.
  11. Yzvessel1
    Michigan
    2019 Prius
    LE AWD-e
    Okay…new development. Asked my co-workers if anyone knew someone selling a Prius and I found a 2011 w/ 70,000 miles.
    Still need to get vehicle history but from the sound of it, it was babied. Nevertheless, don’t want to take just their word for it.
    Ignoring the gasket issues, oil consumption etc… would this be something to consider. They are asking 10k. I feel with a price that low it allows for a contingency if something breaks.
    That being said… 2010-11 from what I’ve been told are more prone than the 2012-14 to issues. And thanks to earlier I know 15 and newer really are the best (loving our 19 AWD)
    Obviously it’s risky and everyone will have their own opinion but luckily that’s what I’m asking for! Thanks!
  12. rjparker
    11,116
    6,974
    Texas Hill Country
    As long as you ignore the issues it is a great car. The brakes last forever, you get good mpg, the transaxle and ac are solid, plus the body fit and finish are above average.
  13. Yzvessel1
    Michigan
    2019 Prius
    LE AWD-e
    Granted I don’t want to make a “stupid” decision and obviously the gasket issue etc are very real. But there are also 2010s hitting 250k miles and running pretty great
    This is a second commuter car only… the 2019 will be the one putting in the heavy road trip miles.
    Thanks for the insight rjparker!
  14. bisco
    52,862
    agreed. we have no idea how many high mile gen 3's are running great with no major work. all we see are mostly problems.
    could be 99% for all we know. there was a lawsuit against toyota from a dealer in cali, not sure how it turned out.
    edit: he got 16 million over the inverter problem.
    here's an interesting writeup on the brakes:
    2112
    #14 bisco, Nov 18, 2021
  15. Yzvessel1
    Michigan
    2019 Prius
    LE AWD-e
    Having a Prius specialized mechanic take a look at the car tomorrow.
    Next question, should I look into a 3rd party extended warranty. Obviously would need to read the fine print ( I don't think many cover things like a hybrid battery) but would a warranty that covers drivetrain etc cover things like head gasket and egr if there was an issue?
    Perhaps, a better question, can anyone recommend a 3rd part warranty they've used?
  16. rjparker
    11,116
    6,974
    Texas Hill Country
    It is very difficult to "inspect" for excessive oil consumption. Even Toyota requires a 1200 mile period to judge the amount of oil lost.
    A gen3 brake booster is "good" until it fails. However frequent running every minute or less is a bad sign and its soon to fail. Most mechanics would think "no codes no problem."
    The best hybrid mechanics can only tell you that a gen3 head gasket is currently good. "Currently" on a gen3 head gasket could mean right now but no telling if it was good two days ago when it was started cold. Characteristic gen3 early stage rattling often only occurs on a cold engine that sits overnight. Any rattling even for a minute should be a no go on that car.
    An average mechanic may think its all good if there is no overheating when driven hard, no coolant loss on the test drive, no milky oil and no coolant gasses in the reservoir.
    A decent test is a quality borescope inspection through the spark plug hole. A steam cleaned piston is a bad sign. Obviously late stage gen3 head gasket failures will rattle frequently, even when warm, may have obvious coolant loss and if they are blowing white smoke, may be past an easy gasket replacement.
    I would want a six month or better guarantee over a third party warranty. Those warranties are usually full of exceptions and limitations.
  17. Yzvessel1
    Michigan
    2019 Prius
    LE AWD-e
    Yikes ^^^ thanks for all the advice, wouldn’t have thought even a Prius specified mechanic wouldn’t help.
    Seems like maybe a gen 3 Prius just shouldn’t be in the cards… which is really too bad considering I think the gen 3s have the best styling. (Can’t afford a 2015 or newer and need a car in the next couple months)
    Perhaps we’ll pass on the gen3 and take the earlier advice of looking into a camry.
    Appreciate all the help but have scared scared the shit out of me with this car. Lol
  18. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    If you are not going to put a lot of miles per year, then a 2011 with 70,000 is a great choice. All of the problem people are talking about are very unlikely below 120,000 and then unlikely until 150,000. Yes, they can happen but some people make it sound like brake booster, head gasket, etc. are sure to fail which they are not.
    I suppose I'm biased with my 2010 at 104,000 running like new.
    How many miles per year do you expect to put on it?
  19. Yzvessel1
    Michigan
    2019 Prius
    LE AWD-e
    less than 10k a year.
    Thanks for the feedback!
    #19 Yzvessel1, Nov 20, 2021
  20. Mendel Leisk
    42,352
    The gasket issue could be more aptly called the EGR issue. Are you ok with cleaning it? Stick with 5K mile oil change interval, and get on the EGR; you should be fine with any third gen year. Especially if you can get one well under 100K. More info in first link in my signature.
    rjparker likes this.
