buying (high?) mileage Prius
Discussion in 'Gen 3 Prius Main Forum' started by Yzvessel1, Nov 14, 2021.
  1. Yzvessel1
    Yzvessel1 Junior Member
    Michigan
    2019 Prius
    LE AWD-e
    Yea this one has 70k miles. Ran the vin and turns out it’s a 2010 not 2011 don’t think that matters much.
    still going to have mechanic check it out to be safe.
    royrose and bisco like this.
  2. PTS
    PTS Member
    100
    50
    Austin, Texas
    2013 Prius v wagon
    Interesting input
  3. Hi_prius3
    Hi_prius3 Junior Member
    46
    Honolulu,HI
    I liked it. It mainly highlights good common sense and checking the maintenance history.
  4. Yzvessel1
    Michigan
    2019 Prius
    LE AWD-e
    Thanks everyone for all the help.
    The update so far is I didn’t go with the 2010.
    I’m currently waiting to hear back about a camry hybrid and recently found a 2015 Prius with 80k miles in budget.
    For my sanity can I get a confirmation that in theory 2015 shouldn’t have many issues like earlier Gen 3.
    thanks!
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,974
    Texas Hill Country
    A 2015 has the improved rings and pistons along with five years newer than a 2010. The video above by the Toyota MasterTech suggests its a good compromise over a 2010-14 when a reengineered 2016 is not available. Note he has comments about early Camry hybrids as well.
    Yzvessel1 likes this.
  6. Mendel Leisk
    42,352
    Partway through model year 2014 is when the piston ring rev happened. See attachment for VIN’s.
  7. 1Utila
    1Utila New Member
    Southport, NC
    My first post! I have a 2013 Prius with 218,047 miles on it and it runs great with no mechanical issues. I bought it new and have always taken it to the dealer for regular service.
    Tbkilb01 and royrose like this.
  8. Mendel Leisk
    42,352
    Have you looked into EGR (Exhaust Gas Recirculation) circuit cleaning, including the intake manifold? Toyota issued a Warranty Extension a few years back, but Toyota's attitude seems to be to wait until there's an appropriate code, or pronounced misfire symptoms. And then start replacing parts.
    My 2 cents, EGR cleaning should be done preemptively, by 100K miles (at the latest(, and then every 50K miles (at the latest) thereafter. Further, that waiting for codes or symptoms, you're basically waiting for head gasket failure, brought on by the clogged EGR.
    Here's one (of many) threads on the subject:
    Toyota USA Refuses to Honor Extension of Warranty Coverage for Sticking EGR | PriusChat
    Many, myself included, are installing oil catch cans (aka air/oil separators), patched into the hose between PCV (Positive Crankcase Ventilation) valve and intake manifold.
    See the first link in my signature, for more info/links.
    Tbkilb01 likes this.
  9. want2know
    want2know Junior Member
    CA
    I have a 2005 which had 285K miles on it when I purchased. I have never considered a car with that many miles. However, I didn't have a lot to spend, did some research and talked with a hybrid shop that services Prius over 400K miles running strong, saw that the owner had receipts for fairly (about a yr) new 12v and hybrid batteries. Given the reasonable price (pre pandemic), I decided to go for it. The car has been great, and smooth driving! Ive been consistent with oil changes and just had one maintenance thing yesterday. I figure even a few years of use was worth it given the reasonable price.
    Bottom line, you can get a better price with higher mileage typically and it could be worth it.
  10. rjparker
    11,116
    6,974
    Texas Hill Country
    I would buy a 2005 with 285k before I bought a 2010 gen3 with the same miles. Especially if it had a recent new hv battery. New as in really new, not rebuilt, reconditioned, repainted, Dorman or straightout honest used.
