Buying my first Prius/hybrid and need help.
Discussion in 'Gen 2 Prius Main Forum' started by glen68, Jan 17, 2014.
  1. glen68
    glen68 Junior Member
    53
    16
    Iowa City, Iowa
    In a month I'm buying a new car well new to me. I'm going to buy a used Prius and am wondering what I should be looking for and checking to make sure it's a good buy. I've bought plenty of normal vehicles so I'm familiar what to look for there but have no clue as to what to check on a Prius.
    SPH-L710 ?
    52,863
    you should run carfax reports and similar. you want to know about # of owners, maintenance, accidents and etc. take a new one for a test drive so you'll have a frame of reference and become familiar with the controls. learn how to reset the average mpg's so you can see what the one you're buying is getting. take a good long test drive, watch the mpg's and the battery meter. the meter should register 5-6 bars generally, with some instances where it may or may not go down to 2 bars and/or upto full bars. think back to how the new one you drove compares as you test drive. and kick the tyres!(y)
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  4. glen68
    53
    16
    Iowa City, Iowa
    Thanks but I've read that before and I'm positively getting a prius
    SPH-L710 ?
  5. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    If you look at a Gen 2, do a quick engine water pump check to make sure it's not leaking. That's the only repair I've had to do so far. Under the hood, look down the left side of the engine, near the bottom for a large, black pulley--that's the water pump. Look inside the pulley for pink crusty buildup that indicates coolant leakage. It sometimes also forms a pink line on the underside of the hood. A leaking engine water pump costs about $100 to replace at home, or about $390 at the dealership service department.
    All the water pumps on the Gen 3 are electric and haven't been showing the leaking issues.
    As the others mentioned, a thorough test-drive and crawl-around are good ideas, as always. Check for leaks, uneven tire wear, condition of the fluids, etc.
    glen68 likes this.
  6. glen68
    53
    16
    Iowa City, Iowa
    Got a 2010 Toyota Prius 2 yesterday with 63000 miles on it
    SPH-L710 ?
    krmcg likes this.
  7. bisco
    52,863
    all the best!:)
  8. doglegleft
    doglegleft Junior Member
    Coastal NC
  9. glen68
    53
    16
    Iowa City, Iowa
    I've only had the car a couple days but have had the cruise control kick off twice without me touching the switch or the brake or gas. Any ideas?
    SPH-L710 ?
  10. Patrick Wong
    18,210
    6,526
    1. Intermittent connection in the wiring harness leading to the cruise control switch.
    2. Brake pedal switch needs to be adjusted.
  11. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    559
    Tucson, AZ
    2021 Prius
    I believe activation of the VSC (vehicle stability control) will boot you out of cruise also. This is usually preceded by the VSC yellow dash light blinking. This could be caused by traction problems with the road surface, uneven tire diameters, low tire pressure, or faulty wheel sensors. There may or may not be some DTC's to check.
