buying new house from builder, what option should i pick
Discussion in 'Prime Plug-in Charging' started by jbpersmail, Dec 20, 2016.
  1. Billy sharpstick
    Billy sharpstick Junior Member
    Micanopy FL USA
    2019 Prius Prime
    I put in a line to a charging station out by the driveway that has 3 - #6 and 1 - #8 for a possible future 50 amp circuit, and 2 - #12 and 1 - #14 for a regular 110 outlet. It currently has 20 amp breakers and separate outlets so the Prime and a regular tool can be used at the same location. This allows for future upgrades if I our a future owner needs more current for higher power car or RV. I considered a 50 amp panel that could be more versatile in the future. The bigger wire was a bit more money, but worth it for future upgrades. (Don't forget GFI circuitry for outdoor circuits.)
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    Do they actually have power in Micanopy now ?? :)
    (Sorry, couldn't resist.)
    Nice little town.
    Is there such a thing as GFI for a 220/240 circuit ??
  3. Elektroingenieur
    2,515
    3,284
    Three Touring
    Yes; you can get two-pole GFCI circuit breakers up to 60 A in Square D’s QO series, for example.
    GFCI protection is required for most receptacles installed for EV charging (National Electrical Code 2017, 625.54); this doesn’t apply to existing receptacles, for which GFCI protection might be required by other code provisions.
    edthefox5 likes this.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    You can never have enough receptacles. Especially in the garage. I would have a quad box every five feet I swear if I was building a house. At least that's what I installed in my garage.
    Code in Fla is no point along a wall must you be more than 6 feet from an outlet.
    In my town new code is Arc Detect breakers in addition to GFI's in wet areas. When I installed my new panel I looked it up and passed on my first inspection. Had my ac drop to the house buried too.
    If i was building a new house all breakers would be AFCI and a generator lockout bypass.
    #24 edthefox5, Sep 7, 2020
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Are you sure about that?
    The usual rule is that there has to be an outlet within 6 feet of any spot, meaning they are 12 feet apart.
    jerrymildred likes this.
  6. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Sorry worded that wrong.
    At no point along a wall must you be more than 6 feet from an outlet. I looked it up.
