Buying Used Prius Agonizing over Details : }
Discussion in 'Newbie Forum' started by daisy555, Aug 11, 2015.
  1. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Kool & the Gang--that's one of those "new" groups. ;)
    I use RainX on the outside of the windshield. On the inside I have a microfiber pad on the end of an arm. Wetting the pad with water works about as well as anything else. I also treat it with a product to combat fog.
    Be careful (or at least aware) cleaning the dash. Part of the instrument cluster is reflected so you don't want to push dust & crud down onto the glass in front of the speedo. A good way to freak someone out is to put a piece of paper there. The unobservant will think there's something wrong with the dash.:eek:
    Can't help with the fogs, sorry.
    daisy555 and WilDavis like this.
  2. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    I'm driving like a grandma and parking away from other cars!
    Trying to catch up on errands and chores now that the search is over.
    My car buyer backed out which wasn't a shock. Now I'm scrambling to find another. Unfortunately there are now two more listed on craigslist. Older but in better shape. Same color and location too!
    Positive Vibes please! It has to sell. Will list again on craigslist today if back up buyers aren't interested. So much for a peaceful sleep!
  3. JTM2955
    JTM2955 Active Member
    475
    185
    He was upset you wouldn't leave it blank? You did the right thing. The right buyer will come along.
  4. JTM2955
    475
    185
    So, how are you liking Priusing?
    Prius+Driving=Priusing. Have you filled up with fuel? Just curious...
    daisy555 and Kramah313 like this.
  5. daisy555
    1,729
    716
    CT
    He finally agreed to not leaving blank and then overnight his wife helped him realize he could get stuck with car if his daughter couldn't fix her financial situation. She owes town taxes and presently unable to register a car. I may be gullible but he seemed like he was telling the truth. No point in making up a story like that.
    Other two buyers don't look promising now. What do I expect after needing to stall for two months. Oh well....
  6. daisy555
    1,729
    716
    CT
    Loving it but will take time to get used to the noises and need to stop glancing over at the mpg display! : )
    Salesman filled tank so I have a little ways to go. That last private seller said he always fills tank to the max despite this not being recommended. I will stop when it registers at full. Still need to read up on the special tank although I don't want to read about the problems. Ha! I remember something about it shrinking in the colder weather.
    The previous private seller with last service history entry being "Major Engine Diag" stated car with full tank ran out of gas after only 200 miles of driving. Her regular mechanic thought something was wrong with hybrid system. Something obviously was wrong plus running out of gas is a big no no with this car right? Despite my need to live frugally I don't usually let tank go below 1/4 left.
    Does everyone here use premium gas? Top tier means the most expensive of the three options right?
  7. DFW
    DFW Member
    39
    31
    Dallas
    Top tier gas info:
    Top Tier Gasoline
    No need for premium unless your car is designed for it. You won't get better mileage with higher octane gas, only better knock protection (which isn't needed if your car is designed/tuned for regular, like the Prius and most cars on the road).
    daisy555 and JTM2955 like this.
  8. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    No need to use premium gas - the ChuggyPig uses the Jungle-Juice (87 octane) and seems to love it. Fill to the 3rd "click" (i.e. fill slowly until pump stops automatically, repeat, repeat, replace cap, turn cap to 1 "click", job done! If you regularly overfill, you might damage the emission control charcoal canister thingamajig! (expensive :cry:)
  9. daisy555
    1,729
    716
    CT
    Too funny, Wil! Thanks for the details.
    I forgot to ask...does this mean I can't go to full service and have them pump gas for me? I usually go to this great gas station over RI border that costs less than pumping myself elsewhere. It's the one luxury I allow myself. I guess I can tell them exactly what to do.
  10. JTM2955
    475
    185
    I agree with WilDavis. The carbon canister takes the fuel vapors that you fuel tank makes while sitting in the sun. The vapors are stored there until they can be used by your engine.
    Then using engine vacuum and a series of valves opening and closing, pull those vapors out and burn them. Now, let one of those valves stick or not open and the "check engine" light may turn on
    I say MAY because this system uses two trip logic. The first time a valve sticks, the computer stores that that valve didn't open. How does it know? Pressure sensors tell the computer that the command was accomplished. It sees either a drop in pressure or an increase.
    This helps reduce emissions. Also, your engine burns those hydrocarbons as part of the mix.
    Just don't use a Prius as a bass boat. Those poor folks in South Carolina, with all that flooding, that is very rough on any vehicle.
    daisy555 likes this.
  11. WilDavis
    2,493
    2,155
    49
    I've never used "full-service" although I've driven on the New Jersey Turnpike with friends, and was surprised to find that there, drivers are not allowed to pump their own gas! o_O (not sure of the reason, had it explained to me at the time, but seldom am in that area so doesn't really affect me!) - I would monitor them carefully, but keep well away from them whilst they're pumping just in case! :eek:
  12. JTM2955
    475
    185
    It is the state law in New Jersey you can't pump your own gas. Also, gas stations change their prices only once a week. In Indiana, its daily sometimes hourly. Which, IMHO, is absolutely stupid. Its the same fuel in that underground tank, it can't change 20 to 50 cents over night.
  13. Kramah313
    Kramah313 Active Member
    411
    326
    Dallas, TX
    I like that - priusing. I know I am loving priusing. I am actually finding I am getting a lot better mileage in power mode...I think it's because I got so used to driving the Corolla which has a very front loaded gas pedal. Don't be afraid to give it some gas, it works better that way because you spend less time accelerating. In my opinion it would be silly if they made a Prius that required premium fuel...that would probably wipe out most of your gas savings over a corolla type vehicle
    JTM2955 likes this.
  14. JTM2955
    475
    185
    My Father was a big fan of the Hudson Terraplane ( yes, Virginia they really do exist). While driving that car, it was called "Terraplaning".
    I inherited my Dad's love of cars and working on them. He was a flight engineer in the Air Force for many years. I gave him a ride in my Prius and he smiled during the entire ride. So, Priusing is something we all do almost everyday. Daisy is just starting to feel the difference in how the great car operates. The "Invisible Hand" is the feeling you get when you feel the torque coming on strong.
    By comparison, a Corolla is about the same size but doesn't have that powerful feel. The Prius has it, and the Hybrid Camry gives it even more. My Dad said it felt like a six cylinder to him.
    Kramah313 likes this.
  15. johnnyb588
    johnnyb588 Member
    193
    73
    Tempe, AZ
    I
    Oregon is another full service state. Count me in the group of citizens that doesn't understand that quirk in the slightest. Seems like nothing other than an opportunity to try to squeeze another tip out of me (not happening).
    JTM2955 likes this.
  16. JTM2955
    475
    185
    I remember that the thinkology behind having a full service fuelling station was there would be fewer fuel spills (yeah, right). I throw the B.S. flag on that one. I've never let anyone fuel my car, not even my wife or my daughters.
    Yes, fuel can blow out of the filler neck, the pump fill handle can stick causing fuel to spill, too. I've never had this with my car.
    On a different note, winter is coming which means fuel bladder shrinkage. Don't try to stuff more fuel in just so you don't have to fill so often. Doing it just turns your fuel gauge into a "guess gauge". Also, don't be alarmed if after a fuel up all the ten blocks or pips don't light up. Mine will light nine but ten may show up later. Ten may not turn on either until the temp goes to 50 degrees or more sustained.
  17. Mendel Leisk
    42,368
    We've lived in Coquitlam for over 25 years. AFAIK it's the last bastion of full-service-only-policy in the lower mainland. North Van used to be too; they finally smartened up. It's a head-shaker. Anyway: I think I've filled in our fair community once.
  18. Kramah313
    411
    326
    Dallas, TX
    That is definitely how I feel about the Prius vs the Corolla. The battery gives it a lot more punch even though the HP figures are close (Corolla has 130). Power mode is getting addicting...throw in 3-5 mpg improvement for me vs regular mode on my work drive and this car is becoming even more fun!
  19. daisy555
    1,729
    716
    CT
    Just saw someone post they received $2300 for their trade in that had KBB value of $1500. I know it's just a numbers game especially with new cars but.... Stupid move on my part to not at least ask them what they would give me for trade in on my car. I didn't ask because before my car was hit by a ladder one local Toyota dealer told me they would give me $1700 max and other said $3000 but that's because their Prius was overpriced by about $2000. At that point my Vibe needed tires and AC was;t working.
    My buyer who fell through was literally emailing me every week asking me if I'd found a Prius yet. I knew he could find another deal any day but he wasn't in a rush and was looking for a fixer upper. I learned my lesson although this final dealer probably would have given me $500 if I was lucky. Kicking myself anyway....should have insisted he give me a deposit to hold car for him although I'm too nice and would have given it back. As it was I would have felt awful trading it in after promising car to him. Live and learn again!
    Back to all things Prius as they say!
    Husky or Weathertech? Looks like Husky floor mats have a taller edge although Weathertech cargo mat seems to have taller edge in photos. I like lifetime warranty with Husky.
    I really want to get a hard plastic bug shield for my perfect (for now) hood. I like the one Wil has but apparently they've gone up in price over the past few years. They're now $169 through two websites. Don't see any on Amazon or eBay.
    Should I be posting these detailed questions as new topics?
    I'm apparently not done with agonizing over the details.... : )
  20. WilDavis
    2,493
    2,155
    49
    Have you looked in the Ye Olde PriusChat Shoppe (give them a call, and ask to speak with Danny (he's the BossFellah) and it was he who recommended the Husky floor mat for ChuggyPig's cargo area (he showed me one at the 2GoB4 get together I mentioned earlier. I've used it ever since last October and it hasn't worn out yet! As to the bug-shield (or mini-bra) ChuggyPig came complete with that already fitted and the window thingies (I think they were made by WeatherTech??? (take a look at the pics in my photo album to see to what I'm referring!)
    IMG_8549.jpg | PriusChat
