Buying Used Prius Agonizing over Details : }
Discussion in 'Newbie Forum' started by daisy555, Aug 11, 2015.
  1. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    http://iaspub.epa.gov/otaqpub/display_file.jsp?docid=24724&flag=1
    ^^^ That is an very interesting EPA memo about CARB states but i have no idea what exactly what they are saying.
    It seems to say after 2011, CARB-certified vehicles can only be sold in CARB states and contiguous states to CARB states, but that contradicts that Prius are sold in all 50 states.
    In any case, that memo goes way beyond what you were asking, funny they sent it.
    Keep in mind for Prius CARB warranty, we are talking about Toyota rules not EPA rules. Although EPA would dictate CARB states, Toyota has warranty policies somewhat unique (I assume legal but I've wondered).
    #61 wjtracy, Aug 18, 2015
  2. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    The memo was confusing to me but EPA rep sent primarily for the chart which spells out states and dates for older models. The column for passenger cars "PC" was the info I was requesting.
  3. JTM2955
    JTM2955 Active Member
    475
    185
    I would add that almost any Prius is going to last a long, long time.I am at 156k miles and still have the original HV battery. I changed my 12 volt battery after almost ten years. Yes any car will need service. But, I will predict that most Prii will last as long as you don't trash it. Mine has been the best and most reliable vehicle I have ever owned.
    What I have saved in fuel would more than pay for a New HV battery.If it drives well, starts and has no warning lamps ON then its probably good to go. Have the HV battery checked by a Toyota dealer. If it needs it, they. Should be able to tell you. Good Luck and don't panic. Prius is one of the best vehicles ever.
    LG G3 T-MOBILE phone ☎
  4. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    ...I think the one sentence says the automaker may choose to make 50-states cars that are certified for both California and Federal. So that's what Prius is: certified for anywhere sales.
  5. daisy555
    1,729
    716
    CT
    More detail questions about history on 2009 silver (88K miles) listed as a touring but supposedly isn't. (16"wheels/6 spokes) I haven't seen it in person yet to check struts due to distance and schedule. One owner...
    I know Carfax is only as good as those who report maintenance and things can be hidden. This car has no history for 2009 (purchased 9/08) and no history for 1 year mid 2014. Dealer says he bought and maintained car from July 2014 until present. He listed the car overpriced with two failed offers due to financing and recently reduced price. May be repeating myself...sorry.
    Carfax shows this car having rear shock absorbers, PCV valve and water pump replaced at 30K miles. Toyota said water pump was a recall issue. (I asked them because one car I looked at had 2 water pumps replaced). Rear shock absorbers at 30,000 miles on Prius...isn't this unusual or is this an upgrade? Serpentine belt replaced at 71,000? Most recent repair was the part that signals car is in park when starting it. Dealer states all original panels but states front or back bumper (I can't remember which) was repainted and has a spider crack in it. Could the shocks and belt simply have been a dealership taking advantage of someone?
    Dealer has been very upfront about this car and replaced tires with Nokian. Repairs on this car are either a good thing because replaced parts are a bit newer or it means this car has had some issues. Despite usually driving cars until they expire, resale value is important to me. Do you think this history has been a factor in car not selling sooner? Yes, slightly stupid question. I want to make sure I'm not overlooking something.
    Thanks!
    JTM2955 likes this.
  6. JTM2955
    475
    185
    Well the Prius does not have a serpentine belt it has one built the turn the engines water pump. As for why didn't sell lot of people out there get scared when a car has over 100,000 miles on it.
    At a minimum, the dealer is telling you what has been replaced. Yes, I can see replacing the rear shock absorbers. But, that also tells you that they have carried lots of weight in the rear of the Prius. More more weight equals more wear. How does it drive? Will they allow you to do an extended test drive? Will they allow you to take it to a different mechanic to have it checked out? Sounds like a good car to me, but this is also diagnosis by wire. Please keep us informed. JTM
  7. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Nobody replaces shocks so that is strange, but possibly the owner was trying to make the car respond to his liking
  8. daisy555
    1,729
    716
    CT
    Actually this is the car that had water pumped replaced at 30K and 70K. The belt was replaced during 70K repair. I thought it was Gen 3 that didn't have belt. My Vibe needed repairs that don't typically need repairing so I'm a bit gun shy.
  9. les.warden
    les.warden Junior Member
    22
    Central illinois
    We have a 2008 Prius. Bought new, had to wait 2 mos for it. Since then, I've had regular maintenance (oil change, tire rotation, filters, etc.) done on it. There were also a couple recalls that were remedied. It's 200 miles short of 100,000. When the original battery died, I replaced it. Just put the second set of tires on it. That is really all that's been done other than drive it. Very reliable!!!!! I expect to get 200,000 from this car. I've also read the forums about the hybrid battery replacements. Mine still have another year warranty, but if/when they need replaced, I plan on going for a new bank from Toyota. If you go with "revamped" battery banks, let's face it, you're still getting used batteries with a limited lifespan. I don't need that hassle. Good luck on your decision!! Oh, and I'm from central Illinois. Not hilly, not overly hot, not overly cold. Just lots of beans and corn!
    JTM2955 likes this.
  10. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    The pumps are routine for Prius the Gen2 water pump was a leaker. But I kept mine and the leak stopped and now I have almost 150k miles on orig water pump. There was another (inverter) pump replaced under recall. If the owner had extended warranty the water pump was covered to that's why maybe they did it. I did not have extended warranty so I did not jump to replace it.
    #70 wjtracy, Aug 19, 2015
  11. JTM2955
    475
    185
    If you mean the inverter water pump, I am on my second one. And at 140k miles, Toyota replaced the engine water pump. So, where is this car from? Heat seems to be the biggest killer of batteries. Keep it cool and seemingly they last longer.
    Now it's up to you. You will not make a bad choice with a Gen II or Gen III. Or go lease a new one, they have some great deals going on right now. It's up to you!
  12. daisy555
    1,729
    716
    CT
    Thanks for more info. Cars I'm looking at are from New England. I'm pretty sure I'll be happy with a 2008/2009. Can't afford newer.
    JTM2955 likes this.
  13. JTM2955
    475
    185
    I like the fact that I don't have to deal with keys. I like my auto dimming mirror (though I modified mine with a piece of tape and a needle, to make it darker sooner).
    My headlamps are HID. This is Godsend at night, anything else seems dim.
    I love the quiet operation on the highway. It fits my lifestyle very well. Is it for everyone? No, some folks have big families, some haul trailers or have other activities that require a different vehicle. As a commuter car, it does great. Think about how many cars and trucks you see on the streets and highways with just the driver? I have hauled ten bags of mulch. Another time I hauled a single bed mattress and box spring (yes, the hatch door was open). I have helped both of my girls moving to and from college. Prius is truly an amazing vehicle.
    Oh, did I mention it does very well on gasoline?
    WilDavis likes this.
  14. daisy555
    1,729
    716
    CT
    Switching to questions on the other car - struts and smart key replacement
    2008 with 63K (listed as touring but has wheels with 6 spokes). I've included photo of struts. Don't these look like touring struts? Red and pink stripe or did I mix up my details. Maybe owner upgraded struts? From what I'm hearing, I would probably be happier with touring but I know they aren't easy to come buy and I'll be fine with standard.
    Carfax on this car gives just basic maintenance no parts repaired except what the dealer recently did which includes replacement of lower control arms, control arms (listed separately?), sway bar links, stabilizer bar links, washer pump and new Sailun tires. Rear bumper repainted at some point and a tear at bottom of from bumper.
    Awfully rusty under there : / which I suppose is normal for cars by the water. Dealer took photo for me.
    He only has one smart key. I tried looking up current cost of replacing. Should I call service dept with vin # or can these be purchased elsewhere? When I searched about smart key on forum someone mentioned be sure key has silver emblem otherwise might not have access to smart key feature? Amazing details and I really need and want smart key.
    I'm only asking all of this so I can learn exactly what I'm dealing with for negotiating purposes. I guess before I take the hike to see it, better be sure he has active smart key. He's going to love me calling about this. : }
  15. Mendel Leisk
    42,330
    Rust on suspension seems to happen pretty fast on Toyota Prius. I raised ours (low mileage 2010, garage stored) and was surprised at how fast the structure and bolts were rusting.
  16. Ashlem
    Ashlem Senior Member
    754
    503
    WI
    2017 Chevy Volt
    daisy555 likes this.
  17. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    The lower-optioned cars have their advantages. Some prefer the sound of the standard audio system to the higher-up, JBL system. The HID headlamps are less reliable than non-HID (I find the standard headlamps to illuminate very nicely) the tires on the Touring are more expensive and less fuel efficient and the suspension is less compliant.
    That may have just been a typ-o up there, but Touring: 16", 7-spoke wheels. Non-touring: 15", 6-spoke wheels.
    The external belt on the 2nd gen would be considered serpentine, even though it only drives a water pump, since it contacts pulleys on both sides of the belt.
    To check for leaking engine water pump on 2nd gen, look down the passenger side of the engine for the large, black pulley near the bottom. Look inside and around the back of the pulley for pink and white, crusty material that indicates a leaking pump.
    Mendel Leisk and daisy555 like this.
  18. daisy555
    1,729
    716
    CT
    Ok you guys...I just got a call from a non toyota but big name dealer who is willing to sell me a 2009 with 94 K (leather) for $8500 including removing $300 doc fee which seems a bit strange unless they will probably make more money selling me this way rather than sending it to auction. They would also bring car down to me so I could register. Obviously I would get car checked by independent mechanic which is an entire different dilemma. Do I get it checked by a competing Toyota dealership?
    They have both smart keys. Will test drive both of these cars tonight. Obviously 63K is much better than 93K but price is my big issue. This car shows regular oil changes and serpentine belt changed at 70K too.
    Here are struts.
    #78 daisy555, Aug 19, 2015
  19. daisy555
    1,729
    716
    CT
    Yes, typo...it has 15", 6 spoke wheels. Thanks for noticing!
  20. JTM2955
    475
    185
    The last photo appears to be a bird bath.
    Has the car you are considering purchasing been rustproofed? I purchased mine new and went to Ziebart. It shows no signs of rust after eleven going on twelve years of Indiana salt and molasses mixture on our highways
    All cars will rust, and the bottom of the car rarely gets washed. The struts and shocks in the photos look original to me. Will the dealer give you any warranty other than the normal hybrid warranty? That would be a plus. What other options does this vehicle have? In the words of John 1701a, just drive it. Don't worry, just do the routine maintenance and drive on. Somewhere on the Tapatalk site, there is a gentleman that uses a Prius with 600000 miles or about 1000000 kilometers with the original high voltage battery. Now that says a lot about quality and engineering, doesn't it?
