Buying (very) high milage Gen 4?
Discussion in 'Gen 4 Prius Main Forum' started by EugeneV, Apr 4, 2020.
  1. EugeneV
    EugeneV New Member
    San Diego
    Hi everyone,
    I'm in my mid-20s and recently entered into the work force. I'm still driving my parents' Gen 3 and have been interested in a Gen 4 of my own. Since I'm looking to add OpenPilot to the car, I want to get either a 2016 Gen 4 (Three Touring or Four Touring) or 2017 of any trim as they all have the required TSS-P hardware.
    Since I'll be paying for everything, money is a concern. I understand Priuses are some of the most reliable cars on the road and, if that's the case, would it be a reasonable idea to buy a Gen 4 Prius with 175k+ miles on it? I saw one 2016 Prius with a clean title and 175,000 miles going for $9,200! That's nearly a $5,000 discount from a 2017 Two with 50k miles, and I could fix a lot of problems for $5,000.
    Any input is well appreciated!
    Thanks,
    Eugene
  2. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Just remember the HV battery is out of warranty now and although it could possibly go on for another 100K miles, it would cost a good chunk of that $5,000 if it does fail. But not much else is likely to fail apart from wear and tear items like wheel bearings, suspension joints, shockers and the usual brakes and tyres etc.
    amos, EugeneV and Tande like this.
  3. Tande
    Tande Active Member
    556
    339
    Mich.
    Well.......FWIW......Me/Thinks, 125000 fewer miles for an extra $5000, is a bargain.......again, FWIW.......ymmv
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Last fall, I did the same thing and around here I found more choices on used 2018 level II's since AFAICT they all come with TSP 2.0 starting in '18 than trying to find a higher level trim '16 or '17 with the right options to get full TSP. And yes, OP works great with it. I wanted the longest factory warranty possible for the lowest price.
    GOOD LUCK with your search.
    EugeneV likes this.
  5. pianewman
    pianewman Active Member
    264
    183
    DallasFortWorthTEXASregion
    2018 Prius
    Advice: I own both 2018 Touring and Two. If you like a nervous ride, go for the Touring. The Two is much more sedate, and I'm at an age where I prefer it. I don't think the aesthetic trade-off is worth it (17"s vs. 15"s, combined with stiffer, very slightly lowered suspension)
    I haven't been near San Diego in over 10 years, but if the roads aren't ribbon smooth, you might regret the 17"s. They're just too fussy (I drove rather aggressive Audis and VWs for 40 years), and slapping the 17"s on the Prius, with it's unrefined suspension, isn't for everyone.
    ...and yes...125000 FEWER miles? I'd pay the extra $5k for that...or...shop for the 2018 Prius Two.
    #5 pianewman, Apr 5, 2020
    kithmo, EugeneV and dbat23 like this.
  6. EugeneV
    EugeneV New Member
    San Diego
    Hi everyone, thanks for your replies! I definitely want a smoother ride so that rules out the 2016 touring models. And high milage... it could be great or it could be a lemon. It wouldn't hurt that much to save up at least another $3,000 and get a 2017 model around 100k at around $12,000 in that case.
    Another question is: are you happy with the trim level you bought? As for me, I don't really need much in the way of features. Is there any reason I shouldn't look for a fleet-owned Prius One / Two? At the very least, it should have been maintained well.
    Thanks again!
  7. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    I would wait for the Covid-19 mess to pass first. You have a job today, tomorrow you might get laid off. Just keep driving the parent's Gen 3 and save up them dollars.
    amos, PriusOffroad, SFO and 3 others like this.
  8. EugeneV
    EugeneV New Member
    San Diego
    Yeah, that's a good plan. Best to save up to have a healthy savings then get the car. Hopefully this all will all pass in a few months! And, if this Covid-19 disease is showing us anything, it's that there are more important things in life than a self-driving Prius :)
    MichelleStone and SFO like this.
  9. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I've bought quite a few older cars myself over the years, and helped my children buy "University cars" which inevitably were old and high mileage. Most worked out fine - but there were some inevitable repairs required.
    It's never easy - and you take a risk with anything that isn't brand new. Get it checked out by a reliable mechanic, preferably one who knows PRIUS.
    The battery - from what I can see with the few I've read about failing, tend to fail by time, not distance - and most get to 10 years or well past. Here in Australia, TOYOTA is putting a 10 year, unlimited kilometre warranty on new Hybrids (for private owners) - ours are all NiMH.
    EugeneV likes this.
  10. fotomoto
    5,639
    3,815
    So. Texas
    For me, the only thing my '18 level II is missing is Apple's CarPlay. I can get that with a radio swap which is easy and relatively cheap since the car uses a conventional "double-din" setup unlike the higher trims with the big vertical screen (and no volume knob).
    EugeneV likes this.
  11. pianewman
    264
    183
    2018 Prius
    THIS DRIVES ME NUTS!!!!!!!
    EugeneV likes this.
  12. Prodigyplace
    12,713
    11,848
    Central Virginia
    I believe the TSS-P was an added option only available on some trims for 2016. Some safety was standard for 2017 and then they added more features in mid-2017. The available features will depend on the build date. I have an early 2017.
  13. Prodigyplace
    12,713
    11,848
    Central Virginia
    In California the 2017 would still be under hybrid warranty, I believe.
    kithmo likes this.
  14. CooCooCaChoo
    962
    544
    Cow-lee-fornia
    2023 Prius
    No this Prius is well outside of warranty for the battery. In California, I believe its 10 years or 150k miles whichever comes first. I would totally pass on this, but that's just me.
  15. Prodigyplace
    12,713
    11,848
    Central Virginia
    A 2017 Prius Two with 50K miles as mentioned is well within that warranty. That extra $5000 provides 50K miles of Hybrid warranty.
    MichelleStone and Tande like this.
  16. ken2116
    ken2116 Junior Member
    40
    17
    Northern CA
    2019 Prius
    All else being equal, I would pay $5000 to get a newer car with 125,000 fewer miles (that's only 4 cents/mi for less wear and tear, a very good deal). Be sure to review the maintenance records for anything you buy - timely fluid changes, especially oil and coolant, are extremely important to longevity. At 50,000mi. it's probably okay to have the original coolant (but you should have it tested), but by 175,000mi. it probably should have been changed at least twice. Somewhere before 175,000mi. transmission fluid should have been changed. By 3-4 years brake fluid should be changed, or at least tested for boiling point reduction and copper ion build up, (a measure of corrosion) - not just eyeballed.
  17. orangecones
    orangecones Member
    46
    28
    NZ
    Yes - have the 4th trim out of 7 in the JDM lineup. Its the lowest of the trims to include BSM and RCTA - which are features I most definitely wanted. For a car with compromised rear sight lines - I really wanted that BSM. This was decided after considering 1 tier lower which was basically equally equipped save for those 2 things, despite the price premium.
    Definitely don't worry about any head unit features as that's a double din swap away - easy as to add something with Android/Carplay if you want. As for 15" vs 17" - objectively the 15s are better for ride quality (taller aspect ratio), deliver a few more MPGs theoretically all else being equal, and are cheaper to replace when you need to do that. But it's not that huge of a difference.
