buzz/hum when car is off and unplugged
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Phausto, Jun 11, 2012.
  1. Phausto
    Phausto Junior Member
    75
    16
    Pacific NW
    Twice I've come into the garage and (after getting over the shock of seeing a new PiP) heard a fairly faint buzz or hum seemingly coming from the car. At first I thought it was the fluorescents overheard, but after turning them off and walking around the Prius I believe it to be coming from the rear of the car. (Next time it happens I will go find my old stethoscope and better localize.) The car was off and not plugged into the mains. I got in and hit the power, and the sound quit. Anyone else have a similar experience? Apologies if I'm missing something obvious I should have seen in the manual...
    Thanks.
  2. retired4999
    2,652
    627
    Eau Claire, Wi.
    I have heard the same thing. I just thought it was the car conditioning the battery. Just my guess!
    52,819
    although i have not heard it, could it be the cooling fan?
  4. retired4999
    2,652
    627
    Eau Claire, Wi.
    I don't think so it has a sound with kind of a low continuous click click click real fast. I have heard it maybe 3-4 times seems to only last a few minutes 1-2.
  5. bisco
    52,819
    is it after driving? how long after?
  6. retired4999
    2,652
    627
    Eau Claire, Wi.
    I don't remember exactly but a number of hours 3-5 maybe? maybe even longer.
  7. Jozo
    Jozo PIP PIP HOORAY!
    145
    27
    Sacramento
    It's just the normal sound made by every Prius after they're turned off. No cause for alarm. I think it's the battery and engine 'readjusting' themselves. I'm certain the engineers on board can give a more precise explanation. But the main idea here is it's nothing to worry about.
  8. retired4999
    2,652
    627
    Eau Claire, Wi.
    Oh! I was not worried about it, I just chimed in to let them know someone else has heard the noise. I never heard it on my 2005 that I had for 7 years! It was just a completely different sound than I have ever heard. A real fast Purrrrrrrrrr noise almost like it was quickly checking every 57 cell to make sure they were ready to charge or something. It was not a fan noise. I'm not worried car is running great and getting about 16-18 miles of electric every day. :)
  9. Phausto
    75
    16
    Pacific NW
    retired4999: "fast Purrrr" sounds like what I'm hearing. This hours (3-5 perhaps, as your experience) after having been driven, maybe an hour after the recharge finished.
    I have to get accustomed to "cars as sentient beings"...
  10. PRPrius
    PRPrius Active Member
    327
    198
    The noise that you are hearing is caused by the Evaporative Emissions System. It is the noise of the system running a test to check for possible leaks. It is always done several hours after the car is turned off. The sound comes from the fuel tank area.
  11. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Thanks for the explanation. I heard it once when the garage was cool, the car had not been run or charged in several hours, etc. I was waiting to catch it again and see if I could come up with a good description, as has been done here, before posting a question.
  12. retired4999
    2,652
    627
    Eau Claire, Wi.
    Thanks for the answer, Evaporative Emissions System check, would have never thought that might be answer!
    Thanks again! (y)
  13. retired4999
    2,652
    627
    Eau Claire, Wi.
    Phausto, Good call on the car being a sentient being I think your right, it's made the step! :D
  14. plugged-in
    plugged-in Junior Member
    22
    irvine
    You can also hear the noise if you have not driven the car in awhile, and then open the driver's door.
  15. bisco
    52,819
    isn't that one under the hood?
  16. PRPrius
    327
    198
    The noise linked to the driver's door is from the Brake Accumulator pump. This assembly is located right underneath the driver side wiper area. This noise can also be heard while the car is on.
