buzzing noise upon braking from lower left area under dash
Discussion in 'Gen 3 Prius Main Forum' started by Americanbeech, Feb 22, 2019.
  1. Americanbeech
    Americanbeech Junior Member
    Safety Harbor, Florida
    RE: 2011 Prius. I just wanted to put this info in here, in case it would help someone else. So far it has saved me over $2,100, which is what my Toyota dealer quoted to replace the accumulator pump along with a couple other items. I have had the car over 4 years with no problems...love the thing, but about 8 months ago it started making these wierd buzz-like short term noise when I stepped on the brake. It got pretty bad, doing it several times when I would be at a light or stop with my foot on the brake for a couple minutes. Long story short, I talked to Toyota and a Prius specialty repair shop. Both said it was the accumulator pump, the master cylinder and I can't remember the other item, but these parts would be replaced along with the accumulator pump. Here's what worked: I sucked out all of the brake fluid from it's reservoir (master fluid), as much as I could with a new turkey baster and smaller ear syringe and replaced it with brand new (unopened) brake fluid, filling to the max line. It cured the noise in a couple miles on my test drive (about 4 months ago) and then the noise started again recently. I went and bought another canister of new brake fluid and did this procedure again, praying it would work. It did. I live in Florida a few miles from the ocean... humidity galore ...and I can only assume there is some contamination getting into my system...someway. I don't have a clue but I'm thinking maybe a vacuum leak?? I do know brake fluid has the ability to pick up moisture, making it....bad. So, if you have some in your garage...don't use that if you want to try this. Buy new. That's my story...and it's true. Hope it works for you. The Prius shop said it wouldn't work and had nothing to do with my problem. WRONG, at least so far.
  2. ChapmanF
    18,905
    Keep us posted!
    Raytheeagle likes this.
  3. nicoj36
    nicoj36 Active Member
    518
    162
    Umm, all priuses do this? my prius do buzz sometimes everytime i brake. I would say mine buzz 5 out of 9 times i step on my brakes. And i've driven other people's priuses and its the same. They all buzz. Mine's been doing it ever since i got it at 25k miles used, and now I have 135k. No big deal :D
  4. ChapmanF
    18,905
    Every time you brake, you use up a little pressure from the brake fluid accumulator.
    When the pressure gets low enough, the pump runs and pumps it back up.
    Completely normal. When it isn't normal is when the pump starts and stops frequently even when you're not using the brake. In that case, the pressure isn't being held in the accumulator for some reason.
  5. bisco
    52,721
    This is very interesting. I’m sure o/p would know if the buzzing was abnormal after four years.
    Were there any trouble lights and codes?
  6. Americanbeech
    No codes or other indications of a problem. In response to the other replies, there are lots of noises in a prius that one gets accustom to. This was a new noise, and rather irritating. Also, I took the car to my prius specialist (he has a lot where he sells nothing but prius' and also does some mechanical for his customers. He listened to the noise and told me it was the accumulator pump. He is also the one though, who told me changing the brake fluid wouldn't change anything. I was cautious not to jump to conclusions after the first brake fluid change (because I was so hopeful it would help), but it obviously took care of the noise. Then as I had previously discussed, it did come back in a few months and I did the same deal again...worked again. Maybe my discription of the noise as a "buzz" isn't very accurate, but I can assure you it's not a normal noise for my car. In fact, that was demonstrated by the fact it was getting worse with just about each stop. With regard to the noise, if you would choke a duck, he might put out this short (1 second) objection!
  7. bisco
    52,721
    A lot of brake quaking/honking is mostly harmless, and you can drive for years like that
  8. Americanbeech
    Pretty sure the 12V battery is good. Since it's not making the noise anymore, I'm just going to ride it out. If it starts again, I will probably change the brake fluid again to resolve. Although, getting the codes read seems like a good idea. I stay as far away from the dealers as possible...can an autoparts store read the codes...do you know? I'm not positive how to navigate this site, so forgive me please if I screw up. Based on history, very likely!
  9. nicoj36
    518
    162
    I forgot to mention you could try the zero calibration method to reset the ABS braking system. It takes less than 5 minutes. Try this and let me know if it works out for you.
  10. ChapmanF
    18,905
    Best way to read codes if you're dealer-avoidant is to have your own laptop / Techstream rig.
    Americanbeech likes this.
  11. Americanbeech
    Thanks much. I am afraid to try this due to my lack of electrical knowledge...car mechanics knowledge in general...but I did watch the video and wanted to mention to you that my ABS break light is not on. The noise I was hearing has indeed started to come back also, so I guess it's another break fluid change for me. Let me ask you this. Is it possible in your knowledge, that I could have a vacuum leak allowing moisture to enter my breakline system, causing the breakfluid to get contaminated. Thank you for your input...I appreciate it for sure.
  12. nicoj36
    518
    162
    That's possible but with our car's integrated electrical system. Sometimes it is not mechanical but electrical. I encourage you to try the ABS zero point calibration reset. It does no harm to our vehicles. All you have to do is insert a paperclip to the number 4 slot, and number 13 slot of the OBD plug under the dash/steering wheel. Turn the vehicle on, wait about 1-2 mins. Turn it off, remove the paperclip. Turn it back on. Then see how your vehicle feels after the recalibration. Its a harmless, easy way to reset the system. And I have a feeling that could help with your buzzing noise issue with your brakes.
    I know my prius' buzzing was reduced when I did the reset. It was still buzzing every once in a while, but not often. Try it man. I've done it a few times before. You will have no issues.
  13. latitude500
    latitude500 Junior Member
    austin, tx
    Mind you I don't know anything yet about the prius, but couldn't this be a bad rotor or pad. Or am I thinking to simple here.
  14. Accordlayingkit
    Accordlayingkit Senior Member
    1,618
    1,748
    377
    Colonial Heights, Va
    Unknown ending I see!!
    2012 here Prius Five model. I have noticed the "robot electronics" sound quite a bit lately and read it's just my breaks and it's normal. Well, I was driving to pick something up about 1.5 hrs away the other day and my cruise control went out, the work BRAKE is lit up, check PCS system flashing, triangle flashing and ABS light on or either flashing. Continued to drive and come back.
    Was able to check battery in my menu with engine off on my screen and was showing 10. 3 at first then jumped to 11.3. I immediately thought battery. Bought a battery tonight, put it in and all lights still on even after a short 10 min drive.
    Even out of the car looking under the hood trying to see where the robot sound is coming from, it sounds like it coming from under the brake fluid reservoir or right near it and it's every few seconds. Brake reservoir is near the low limit but not quite there. Not sure what the heck it is now or where the fluid has went too. Maybe it is the accumulator?? Would the constant noise and all the lights happen if it was just low of brake fluid ya think??, I've checked all the ABS fuses under the hood and they check out ok.
