bZ4X - Start Your Impossible
Discussion in 'Toyota Hybrids and EVs' started by john1701a, Apr 12, 2022.
  1. drash
    drash Senior Member
    2,599
    1,339
    Upstate NY
    XLE AWD-e
  2. hill
    9,022
    52,807
    if you can't buy one, 'start your impossible' is the perfect slogan
  4. Trollbait
    12,817
    Toyota didn't simply add another motor to the other axle. They replaced the front motor with one of identical power to the rear motor. The AWD's combined power rating is 13hp more than the FWD's single motor. The draw from the battery will be nearly the same between the two.
  5. drash
    drash Senior Member
    2,599
    1,339
    Upstate NY
    XLE AWD-e
  6. drash
    drash Senior Member
    2,599
    1,339
    Upstate NY
    XLE AWD-e
    Summer of 2022.
  7. hill
    9,022
    The web link says 2023 ... & the order link (tried multiple zip codes) just landed on an existing inventory page
    Than I tried my mom's SoCal zip code (very 1st deliveries going to be here) and I got this: Screenshot_2022-04-12-13-40-09-75_5ebe7ceed023e5c4dba122424f079699.jpg
    Limited inventory ...
    #27 hill, Apr 12, 2022
  8. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    Here is where Toyota is currently using Hydrogen .. Have an extra 6 minutes of your day to take a sneak peak.
    youtu.be/6-Sw-TmNB6k
    translate.google.com says
    You can see the video of "FC Module Utilization Case Study (North America)" screened at FC-EXPO 2022 Spring Exhibition.
    You can see examples of customers using Toyota FC modules in North America.
  9. drash
    drash Senior Member
    2,599
    1,339
    Upstate NY
    XLE AWD-e
    So if Toyota is trying save weight and money it may make sense they may use one of the same DC-DC converters for one of their motors for their DC input. Seeing as how it is only 80 kW going out they would beef it up a little to bring in 100 kW (and of course derating). This is purely conjecture on my part, but looking at a teardown picture of old I'm seeing most of the hardware for recharging is pretty much located in the front. For the front wheel drive model with a 200+ kW DC-DC converter they wouldn't need much to make it accept 150 kW.
  10. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    I used Build 2023 bZX4 at the Toyota website and requested a quote from a dealer.
    Build Your Own Toyota | Toyota Configurator
    Just received a call from the closest Toyota dealer. They said, they are not getting any bZX4 and they are not taking any orders. I don't know how much of what they said was true, but the reason was that the general manager of that particular dealer decided that the car is not built for the cold climate and not enough range in winter in our region. Haven't checked any other Toyota dealers, but that basically makes it impossible for me to get bZX4 and drive home. The second closest Toyota dealer is further away than the rated range of base model bZX4. And we have no DC fast charger between my house to there. :cry::cry::cry:
  11. Trollbait
    12,817
    You mean a DC-DC converter between the battery and motor is used between the battery and DC charger? With the front motor being 'down sized' for the AWD model, the DC-DC converter was also down rated to match it. Which leaves the car no longer able to accept the DC charging rate of the FWD model.
    Which means any 'low power' BEV could also be slower charging on fast DC, regardless of battery size.
    That sounds more like a cover for the actual reason they won't get the car, and I think they would be up front if it was because of long expected delivery times from Toyota.
    You do have limitations to BEV ownership there, but that apparently hasn't kept Nissan and Tesla from selling cars.
  12. Salamander_King
    11,024
    8,978
    New England
    Nissan yes... Tesla, I don't know for sure. I am sure I can order it online and have it delivered to my home, but there is no Tesla retail or service shop in my state. As for the Nissan, they have been selling Leaf since it was released. The problem is that the closest Nissan dealer is again too far away for the base model to drive home. :cry::cry::cry:
    I have checked, Mach-E, Kisa EV6, and Hyundai Ioniq 5, they are all listed on the dealers closest to me, although I don't know if they really have them in stock or not. Historically, I could not find the original Ioniq EV anywhere, but I think that vehicle was not produced in large numbers.
  13. drash
    drash Senior Member
    2,599
    1,339
    Upstate NY
    XLE AWD-e
    Well there is an inverter between the motor and the batteries. It may more of an ECU limit which may be doing double duty to minimize the chip issue and it is seeing limits put in place by Toyota on both the inverter and dc-dc converter. Don't know why you would want to go through the inverter for DC input but the ECU may be part of the inverter.
    Yeah I'm not buying that. I think it has a lot to do with cost savings. Build it for speed or build it cheap. I personally don't see any differences in the front between the break down of the FWD and the AWD. The biggest difference is that it has a separate inverter for the back motor on the AWD.
  14. Tideland Prius
    16,675
    For reference, the Canadian prices are competitive for the L FWD, LE FWD and XLE AWD. The XLE AWD w/ Technology Package is very much overpriced. (CAD$62k vs. the US' Limited at US$48k? No thanks!)
    The pricing structure is designed to meet our federal EV incentive (like every other manufacturer) but I feel that $62,750 is really stretching it for Toyota Canada (maybe to recoup losses on the lower models that were designed to meet the EV rebate thresholds? or to offset the US' eventual loss of the federal incentive?).
    CAD$62,750 is waay more expensive than the competition. EV6 tops out at $61,995. Ioniq 5 tops out at $59,995. ID.4 AWD Pro S tops ouat at $57,995. And there's nothing in the bZ4X that really stands out over the competition. The only things I can think of are: radiant heating for front seats, digital key, ICS, 8.1" of ground clearance and Subaru's e-AWD with X-Mode. I guess a longer warranty too on the battery (haven't seen the numbers but they've been touting 10 years/240,000km).
    The Hyundai/Kia models offer much more power (320hp vs 215hp), more features (family friendly features on the Ioniq5), faster AC and DC charging. The ID.4 is substantially cheaper and offers slightly more cargo room, massaging front seats and OTA (latest one bumps the DCFC rate from 125kW to 135kW).
    That said, I would take the bZ4X over the ID.4 (can't live with the buggy infotainment system or the obvious cost cutting) but only in lower trim level (so LE FWD or XLE AWD for $50k or $55k respectively).
    drash likes this.
  15. PriusCamper
    PriusCamper Senior Member
    13,428
    5,421
    Pacific Northwest, USA
    Gokhan likes this.
  16. Gokhan
    Gokhan Senior Member
    6,709
    2,660
    Paramount CA
    It is strange that BEVs only come in shades of gray these days.
    These days you can't buy any new Toyota by walking in to a dealer. You need to place an order and make a deposit, and you will get your vehicle after about six months. So, if you place a bZ4X order now, you should be able to get it by late 2022.
  17. Gokhan
    6,709
    2,660
    Paramount CA
    Forget it @Salamander_King. Stick with the Prius Prime. Or bite the bullet and get a Mach-E.
    I saw a Mach-E on the freeway yesterday. I saw the Mustang emblem behind me, but it didn't look like a Mustang. After it passed me, I looked from the behind, but it looked like an SUV. It only later occurred to me that it was the Mustang Mach-E because it had carpool stickers. Man, they ruined the looks of this classic muscle car. LOL
  18. hill
    9,022
    EPA combined City Highway of 100 MPGE . . . . . over 20% less efficient than a Model Y . . . . less range, less charging infrastructure, less power .... why would anyone wish so many forms of 'less' on someone
    Gokhan likes this.
  19. Gokhan
    6,709
    2,660
    Paramount CA
    Anyone who prefers a well-handling muscle car over a boring crossover?
