C block heater
Discussion in 'Prius c Accessories and Modifications' started by Nic Lechner, Jul 4, 2012.
  1. KYBlue
    KYBlue Active Member
    227
    112
    I bought a $12 outdoor heavy duty timer. It's programmable by the week day with different on/off schedules. I have it set to M-F, 5:30am till 7:15am (I leave at 7am).
    I found this at ecomodder.com:
    If its 400 watts @ $0.10/KWHr then 3 hours is 12 cents per day or $23 for 180 days more or less.
    I'm running mine an hour and half a day and so far so good. When it gets colder I may up the run time....
    As it stands, 40 degree mornings, I have heat in less than 1/2 a mile. The car runs a lot less just to warm the engine up, and I went from not being able to break into the 70mpgs at work (which was normal) back to doing it pretty easily again.
    My biggest concern now is attracting rodents to the engine bay since it'll be nice and cosy...
  2. col127
    col127 Member
    345
    Illinois
    Where exactly is this transmission vent thing? So you take it out and put the block heater in its place?
  3. Hodr
    Hodr Junior Member
    23
    The timer sounds like a good idea. This part I quoted has me a bit confused; is the heater rated for 400 watts, or did you just quote the above to explain how someone would derive the cost (if they were unaware)?
  4. KYBlue
    227
    112
    The heater is 400w, just replace the kw/h costs with your own.
  5. Bohica
    Bohica Junior Member
    You almost can't see it. It's right in front of the hole where the heater goes in. View of it is blocked by the radiator hose. Bend down, look under the left side of the hose. (Your left , facing the engine compartment.) Push the hose to the right. You may need a flashlight. NOW - it is part plastic. YOU CAN break it . I broke mine. @#%&* it. Does anyone know the part number of this thing?
    Toyota parts men looked for an hour at which point we all gave up. BUT I WILL NOT BE DENIED! Ahem, excuse me. He He .
  6. Fluxuated
    Fluxuated Member
    133
    53
    Guelph, ON
    SO just to Clarify, I'm looking at a Block Heater for my wife's 2013 Prius C. You people are saying a 2009 Prius Block heater should be the same??? The local parts store could only list a part number for an '09 and I'll get it tomorrow. Just want to make sure I'm not wasting my time. Thanks.
  7. Mendel Leisk
    42,343
    That's a good time. We invariably use more, I'll aim for 2 hours, and getting out of the house sometimes involves even MORE time, due to she who must be obeyed, but 1.5 hours is good, except for very coldest times, as you say.
  8. Flying White Dutchman
    4,376
    313
    not sure thats the best thing to do i already plugin my PIP with my neighbors.....
    i wurry that maybe with 2 the fuse will pop :p
  9. navyjoe1987
    navyjoe1987 Junior Member
    25
    17
    Is this worth investing for in somewhere like San Diego, or is this a colder weather concern/benefit?
  10. Bohica
    This is a help anywhere. A warm engine is a happy engine. Used regularly it will extend the life of the engine .
  11. HiC
    HiC Junior Member
    23
    16
    Northern, MN
    2014 Prius c
    Sorry to dig up an old thread, but I have some info to share regarding aftermarket heaters.
    I recently attempted to install the Kat's 31813 cartridge heater in our 2014 c2. It does not work because the large end of the heater element does not clear the wiring harness that is routed across the top of the transmission housing.
    Tonight I tried a Zerostart 1100129 cartridge heater and it will clear the harness the Kat's element does not, but is 3/4 inch too long. The plug end of the element hits a large metal bracket that appears to hold down a large wiring plug above the transmission. This interference keeps the element from lining up with the hole in the block.
    I guess I will have to try the Canadian Toyota kit or the one on the PriusChat Store.
    #51 HiC, Nov 9, 2014
