c foglights
Discussion in 'Prius c Accessories and Modifications' started by Lenwood, Apr 20, 2012.
  1. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    Anyone seen a better deal? None listed in the Prius Store. Need some mud guards also.
    Dan
  2. kkim
    kkim Active Member
    386
    133
    kauai, hawaii
  3. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Please provide videos of installation of this new fog light kit and verify if it recognizes in the dash as per installation details. In my case I need to figure out how to connect from the stalk to the computer :( if not I go with this also.
  4. TxTkd
    TxTkd New Member
    16
    Received my fog light kit today. Not sure if the pictures will showing up as thumbnail or full images? :)
  5. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
  6. WD0AFQ
    619
    152
    Dexter, Mo.
    I like what you have shown us. I had planned to already have these ordered but seems xmas is right around the corner, and we have 16 grandkids. Will wait a little longer. I did read the instructions on the website and this looks like a very straight forward hookup, taking little time.
    Now, being so low to the ground they may be easily broken. There was a guy on the Vibe website that made lexan covers for Vibe fog lights. I got a set after breaking out a fog light lense. Might be a good idea here also. Super locking "velcro" type stuff held them on. Since I totalled out the Vibe I am going to grab the ones from it and see if I can use them here.
    Thanks for your time posting the fotos.
    Dan
  7. TxTkd
    TxTkd New Member
    16
    I completed the installation late last night, I followed the instruction that was provided on the website, with minor tweaks. My dash not recognize the fog light, I guess that what the switch for :) .
    Below are few things that will be helpful to whoever doing the installation:
    • Use floor jack to raise the front of the car, it will helps open up the wheel well, easier to run the wires through the firewall.
    • Unscrew a 10 mm screw, before release the tabs holding the fog light cover. I guess they missed that step on number 24, 25 page 7 of the pdf.
    • A 3M silicon sealant will be handy, because the rubber gasket between the wheel well and carbin is small. For me I just add a bunch of sealant there, in case heavy rain :) (I bought the sealant at Academy, in the marine equipment section :) ).
    • On step 15, 16 page 5. Personally I recommend to 16, then 15, because there a bunch of purple wires :) (I actually tapped to the wrong purple on the first try, but realized my mistake when not able to find the pink wire). I believed picture 15 on page 5 is reversed (or just because I have a C1 ?!) . On C1, the top of the connector is the right side of the figure. and pins(32-40) will be on the left column. Kind of confusing, but if you just locate the pink wire first, then verify the proximity of the purple.
    Hope these help. fogInstall1.jpg fogInstall2.jpg fogInstall3.jpg fogInstall4.jpg fogInstall5.jpg
    Hawkeye63 likes this.
  8. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Great, thanks for sharing the installation, well I have no choice to go with this kit to finish my installation.
  9. WD0AFQ
    619
    152
    Dexter, Mo.
    Correct me if I am wrong here. Once custom wheels have been installed on a C, the fog lights are the only distinguishing outside appearance that separates a model 2 from a model 4.
    Dan
  10. DKTVAV
    DKTVAV Active Member
    510
    101
    I would say fog lights are the only thing separates model C4 from the rest.
  11. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    there is a larger antenna base on the 3 and 4... so there's also that to look for.
  12. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Don' forget the sunroof
  13. KaliforniaKid
    KaliforniaKid 2013 Prius v Five 2012 Priuc c Four
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    The faux leather Softex found only on a C4.
  14. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Where I can get the wiring diagram for a PC4 for fog lights? Specially from steering wheel to Computer to dash. Asked Toyota in local dealer but they supposedly don't find it.
  15. WD0AFQ
    619
    152
    Dexter, Mo.
    We put the real leather in our C-2.
    Changed my antenna.
    Thanks,
    Dan
  16. WD0AFQ
    619
    152
    Dexter, Mo.
    Having to hold onto my wallet trying not to order these yet. Wish the Prius site would add a few options for the C. I always check here first but just ame o same o. So, we buy them where we can.
    Thanks for all of the comments. Who knows the difference in the C models anyway other than another owner???
    This is a great site.
    Dan
  17. PartsNinja
    PartsNinja Junior Member
    26
    There you go. Hope it helps.
    • ewd.pdf
      File size:
      22.8 KB
      1,471
  18. kwhubby
    kwhubby Junior Member
    27
    San Jose
    Nice, a wiring diagram! Do you have any wiring diagrams relating to the P.C. 2 (fuse box, relays etc)? I opened my P.C. 2 and found the fog light harness wiring going up into the fuse box. I couldn't find a fuse or relay point for the foglights.
    I'd like to use a slot in the fuse box/ pre-existing wiring harness even if I have to bypass the ECU part that the P.C. 4 has.
    The previously mentioned kit in this thread is wiring directly back to the battery, this seems counter-intuitive to me if one could tap into the large 12V feed that goes up to the front.
  19. PartsNinja
    26
    This is probably what you are looking for. See page two. You sound skilled. But be careful poking around in there. I would feel bad if something happened. I just want to help the project if it would work.
    • ewd2.pdf
      File size:
      64.7 KB
      1,505
  20. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    I installed the fog lamps and the Stalk with factory wiring (PC2) but there is no cable from the stalk to the computer to the dash at least when installed. that why I want to know how to resolve this issue, I don't want to buy the kit before I can solve this, if not then sell the stalk and then move to the kit.
