  1. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Is C1241 the hybrid battery or 12V Battery? C1241 means c1241 high or low battery positive voltage because I got a red triangle on my car this morning and can’t figure it out thanks. 09 Prius.
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Priuslover09 and SFO like this.
  3. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I tested the voltage and it was to super high do you think it was overcharging the 12v? It tested at 14.2V? Can I discharge it to 12.7V? I have a discharger. The Feels Hot When I Touch It
    #3 Priuslover09, Feb 27, 2020
  4. valde3
    2,002
    745
    Finland
    That's all normal. You need to test the 12V battery with the Prius turned off. Your discharger feels hot?
    Priuslover09 likes this.
  5. SFO
    SFO Senior Member
    5,289
    4,228
    Northern California
    If the 12v battery is that hot, then the battery is most likely failing and has at least one bad cell.
    Raytheeagle and Priuslover09 like this.
  6. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Does it need to be replaced or discharged. to 12.7v?
  7. SFO
    SFO Senior Member
    5,289
    4,228
    Northern California
    Like @valde3 kindly mentioned above, test the battery when the vehicle isn't charging it (eg. OFF).
    The reading of 14.2 volts is because you were testing the battery while the vehicle was "ready" or "on".
    You'll most likely be replacing it, so take the battery to an auto parts chain store and have them test it, either in or out of the vehicle.
  8. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I can do that tonight I’ll take it autozone tonight
  9. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    So I got the 12v replaced at auto-zone than I went to chick-fil-a for supper then I got back in the car and drove less then 2 miles and the light and came back on with the same code c1241 any ideas?
  10. SFO
    SFO Senior Member
    5,289
    4,228
    Northern California
    Did they check the battery health before replacement?
    Ok, assuming the new battery is within normal voltage range [Step #2 in the above workup, and the manual claims standard is 10-14v], continuing on to the next step (#3), on page 6 of 8 in the above workup for DTC C1241, it tells you to now "CHECK BRAKE CONTROL POWER SUPPLY".
  11. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    It was at 12.8V when I just checked it.
  12. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Do u think it’s the charging system?
  13. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Ok it’s the charging system I believe because the hybrid Battery isn’t charging either I don’t have the hybrid battery code but my car hv battery went down 1 bar when driving today
  14. valde3
    2,002
    745
    Finland
    Is your discharger still getting hot?
  15. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    It was the 12v getting hot not the discharger
  16. valde3
    2,002
    745
    Finland
    So you have normal charge voltage (14.2v) and 12v battery gets hot. That has to be a bad 12v battery. Just replace it and your Prius is fixed.
  17. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I did it was autozone replaced it. It still got the trinagle after 10 minutes of driving battery was still hot Thee hybrid drained to 1 bar.
  18. valde3
    2,002
    745
    Finland
    New battery has to also be bad or you measured the voltage wrong.
  19. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    U mean they gave a bad battery again?
  20. valde3
    2,002
    745
    Finland
    Check the charging voltage. If that's correct and battery is getting hot then it has to be a bad battery.
